Question about Clarion SRR6934 Coaxial Car Speaker
Template Does anyone have a template for installing clarion SRR6934 6x9 3-way speakers? Would really appreciate the help.... thankyou!
  • 432 Answers
The first webpage template is the speaker plate. The second is the reardeck template. The third is a website for installation. http://www.brazeauracing.com/speakerfaq.htm
Posted on Jul 04, 2007
LABEL PRINTING
you might try downloading a template from avery.com that is what I use.
Mar 12, 2013 | Office Equipment & Supplies
I lost my instructions over the 6 years that I have been waiting to get a door thick enough to install the powerbolt 1000. Downloaded from internet but can't find template to mount the lock.
I understand that you have already downloaded the installation instructions but do not have the template. Just in case, this is the link to the instructions:
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
This is a pdf file, which requires that you have Adobe Reader installed on your computer to open it. If you cannot, get and install Adobe Reader from here:
http://get.adobe.com/reader/
Now, the template. Unfortunately, there is no download available for the installation template. I believe the reason is that a printer cannot print to exact scale, so the dimensions of your template printout would not be accurate and your holes would be slightly off. This is a feature that is purposely designed into all printers, mostly to confound would-be amateur counterfeiters.
So I have a couple of suggestions for you. You can contact Weiser directly and ask them if they can send you a template.
WEISER
19701 DaVinci
Lake Forest, CA 92610
1-800-343-9652 USA
1-800-501-9471 CANADA
Best time to call--during west coast business hours.
You may try finding a store that sells the Powerbolt and get the assistance of a helpful clerk who could photocopy the template, but be sure to measure your copy against the original and adjust the dimensions on the copy accordingly.
Good luck--and please provide feedback if this helps!
Sep 03, 2011 | Weiser Lock Powerbolt 1000 Lock
I need Template and installation instructions for GE Spacesaver Microwave Model JVM1630CJ02, built Jan 2005. Thank you.
You can download GE owner's manuals and installation instructions here.
If the installation instructions do not have the template, you can also find helpful exploded view diagrams and order needed parts by entering your full model number here.
Apr 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I need to find out how to mount stereo MA-10D speakers to a wall. I can't see any mounting capabilities on the back, sides, top, or bottom of the speakers. Has anyone successfully mounted speakers like...
Hmmm. .U don't have option given for speakers to fix them onto the wall. You have to do the following steps.
Things U need are:
  • Masking Tape
  • Level
  • Pencil
  • Keyhole saw
  • UL Class 2 speaker wire
  • Fish tape
  1. Locate the studs closest to where you'd like to install your speaker. You'll want to install the speakers in between the studs.
  2. Tape the template that comes with the speakers in the center. Check to make sure your configuration is level and plumb. Your template will tell you exactly what size hole to drill to insert the speakers. Trace the opening you need to cut into the wall or ceiling
  3. Cut the hole using a keyhole saw or a drywall saw. Keep the section you cut open in case you can't install the speaker and need to patch the hole you just made. If the hole reveals plumbing, you need to relocate the speaker
  4. Run the speaker wire through the wall, or fish speaker wire from an existing installation.
  5. Install the brackets to support your speaker if one is included with your speakers. Some speakers use clips to secure them to the inside of the wall.
  6. Strip the protective coating from the end of the speaker wire, and insert it into the speaker jacks. Test your speakers now if the wires are attached to an audio source. If not, locate the other end of the speaker wire and hook it up. Testing now will save trouble if you run into problems.
  7. Surround the speaker with insulation to enhance the sound. Secure the speaker into place, and do any necessary patching or painting
Aug 27, 2010 | Roland MA-10D Main / Stereo Speaker
Can you save a text template to be put on your texts every time
Yes, it is actually called a signature. Go to your message settings and you should see signature option, select that and then add the text you want to be on your messages. But make sure that your signature is turned ON in your message settings. Hope this helps!
Mar 28, 2010 | Samsung Propel A767 Cell Phone
Where can I find a template to hang my microwave MH1150XMB
Part numbers:
8184731 Upper Template
8183743 Wall Template
You can usually find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Your installation instructions are here.
Jun 23, 2009 | Microwave Ovens
I want to create an excel template that can automatically update the invoice number once i save it. say i have the excel template open with the curent invoice numbe as 5. once i save this file and i open...
Is it in a single-user environment? You can save the current invoice number to a text file then ope that and +1 (which is the way that the demonstartion Invoice in Excel 97 / 2000 used to do it ).
Feb 26, 2009 | Microsoft Excel 2000 Step by Step...
Template
Glad to hear it worked out.
Dec 30, 2008 | Kenmore 62702 Microwave Oven
GE JVM1650CH01 Microwave Template
Aug 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
Clarion SRR6934 Coaxial Car Speaker Logo
1,400 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
