Question about GE Microwave Ovens
I have a wall mounted microwave ge jtp90s0m1ss humming when door is closed and heat up the micro wave
SOURCE: GE Over range microwave, JVM1660
It happened to me too. Thanks for the part #.
Posted on Feb 12, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave humming when you shut door
Do the inside light, turntable and internal cooling fan ALL come on when the door is closed (without pressing any keys) , or just one or more of those?
Does it actually heat when you shut the door (without pressing any buttons)?
(You can put a cup of cold water in it for a minute to test it)
I would first suspect a shorted door switch.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's not a door switch issue, I would say it has a stuck relay on the control circuit board.
We regularly repair these for customers nationwide with our guaranteed $39.95 service in about a week.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 25, 2008
  • 234 Answers
SOURCE: door latch hook broke on bottom, when closing
You can find the parts at a GE appl.dealer.
Posted on Mar 19, 2009
sams_trix
  • 93 Answers
SOURCE: GE JVM1850CH06 microwave no heat with loud humming sound
With the details you described, the high voltage diode might be shorted( usually HVR 1X). It is connected from the Capacitor and the chassis, or else the capacitor is the one at fault,but not common .
Posted on Aug 29, 2009
  • 574 Answers
SOURCE: Kitchenaid KCMS185JSS-3 microwave - no power
Well your gonna have to take it down a take apart the microwave more than likely. Probably have a shorted HV diode,magnetron, shorted winding in HV transformer.burnt or frayed HV wire insulation
Posted on Sep 03, 2009
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    When I close the door and begin to try to heat something I immediately hear an abnormal low buzzing sound. If I let it run I smell what seems to be something burning. Obviously this does not sound safe...
    There is no easy fix on a micro wave oven. It is an extremely dangerous appliance and any repair is best left in the hands of a qualified repairman.
    Jan 30, 2011 | Microwave Ovens
    My microwave starts however food does not heat up.
    Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
    Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
    Why would my microwave no longer heat or cook?
    micro waves use a tube inside that generates micro waves and like a light bulb they eventually blow out. the tube is not considered replaceable and cheaper to just get new unit.
    Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    GE 1800 XL not heating, no power, except fan works and clock also
    Hello :
    It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
    The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
    or it could be problem with the control panel .
    good luck .
    please rate !
    Mar 29, 2010 | GE XL1800 1100 Watts Microwave Oven
    Micro wave stopped heating. All other features
    Check the door safety interlock switches. Magnatrons are pretty tough but the little switches are not.
    Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Micro wave has come loose from hanger on bottom. Need to know how to reattach microwave to brackets. maytag mmv5100
    MOST OF THEM YOU CAN TAKE THE SCREWS LOOSE FROMTHE TOP OF THE CABINET OVER THE STOVE, YOU NEED TO PPL, REMOVE TOP SCREWS HOLD IT AN TILT IT AN THEN PULL IT AWAY FROM THE WALL, MOST WALLL BRACKETS HAVE A HOOK THAT THE MICRO MOUNTS TOO IT 90%OF THE WEIGHT IS BEEN HELD BY THE WALL. GOOD LUCK LEAVE SOME FEEDBACK.!
    May 28, 2009 | Maytag MMV5100A Microwave Oven
    Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
    Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
    A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
     Q - My microwave is running and sounds like it is working but will not heat up anything.
    A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
    Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
    A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
    Mar 03, 2009 | Amana Radarange Microwave Oven
    MICRO WAVE RUNS BUT IT DOES NOT HEAT
    Generally, the most common causes of a failure to heat are:
    - bad door switches or door switch mounts
    - loose connection at the magnetron
    - problem or loose connection on the control unit circuit board
    - bad magnetron or other high voltage part such as high-voltage rectifier diode
    If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and
    replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
    You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
    Nov 01, 2007 | Microwave Ovens
    Microwave Ovens Logo
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Shekar Avadhani
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
