Question about Diamond Audio TDX-10D4 Car Subwoofer
Looking to see if there are rca hook ups on subwoofer
I am looking to find out wether diamond audio subwoofers have rca hook ups. Im interested in the model M612D4 if it has rca hook ups on it
  • 15,935 Answers
There are not RCA Hookups on any Raw Subwoofer. An amplifier takes an RCA input signal (DC) and turns it into AC to the speaker.
This is a raw driver. It has wire push terminals just like any other driver (speaker).
See here....
Thanks for using FixYa - A FixYa Rating is appreciated!!
Posted on Jan 22, 2009
How do i conect supwofer out put ?
You need a mono RCA subwoofer cable (http://www.amazon.com/Belkin-PureAV-Subwoofer-Audio-Cable/dp/B0001XGR1C/ref=sr_1_5?ie=UTF8&qid=1425294043&sr=8-5&keywords=Subwoofer+cable.
Down where the speakers hook up to the rear of the unit there is a subwoofer output RCA connection. Plug RCA cable in there and run it to the Input of the powered subwoofer.
Mar 01, 2015 | Sharp CD-DVD500 System
How do i hook up the wires from and to a sa wms 315 subwoofer
what r you hooking it to is #1 rca wires r the way to go when hooking up a subwoofer up .some subwoofers have 2 rcas on them one input and one output the in put is mono if what your going to hook it to has rcas on it then the left one is a mono output but if its an audio system then it mit have a subwoofer output on it
Jun 29, 2010 | Sony SA-VA1 Rear Speaker
How to hook up my subwoofer
It sounds like you're doing everything right. Did you define the sub to the Onkyo (Subwoofer = Yes, page 22)?
Let's prove the sub works. Set its volume about half-way, cutoff= 170Hz. Temporarily connect an RCA cable from its Line Input to one of the Tape Out connectors on the Onkyo and play some FM through it. If it's alive you'll hear the low end of the music.
Don't buy into the hype that there are different pedigrees of RCA (or speaker) cables that will make an audible difference. Save your money.
May 04, 2010 | Onkyo TX-DS696 Receiver
I want to hook up subs and a amp in a 2008 saturn vue how do i do it
If you are planning on using the factory stereo you will need a line level converter. You basically connect two of your speaker channels to the line level converter. That in turn will give you a line level out (RCA cables) That line level out can be fed to a two channel amp which would be where your subs would hook up to. If you do this however you will lose two channels of mid range and highs ( your rear speakers ). Downfall to this approach is that some line level converters are susceptible to alternator noise.
If you have an aftermarket deck this will be much more simple. You simply run your RCA outputs from your deck to your external amplifier. Aftermarket decks typically have front rear and subwoofer outputs. That means you can drive a four channel amp for your front and rear and a two channel amp for your subwoofer. This is the recommended way to go.
For hookups I just suggest buying an amp kit that is comparable in power rating to your amp. If you buy a 500watt amp make sure your wiring kit can handle at least 500 watts.
Feb 12, 2010 | Jl Audio M5122.4 Diamond Audio 12" Car...
I have 2006 ford five hundred limited im trying to install to 12" subwoofers and an amp but i wanna keep the factory radio installed what do i need and can it be done
Hi what you need to find out is if your head unit has sub out or any rca that you can hook up to as they send sound to amp though rca cable hope this helps
Oct 19, 2009 | MA Audio 800XL Car Subwoofer
Hook up subwoofers
use a split rca at walmart for $5
Jun 09, 2009 | Jensen VM9510 Car DVD Player
Best hook- up Polk psw10 sub woofer to yamaha rx-v663 receiver
You will not need to y connect your subwoofer, if you have only one RCA sub out on your receiver the other end of the RCA connector cable goes into the left input on most powered subs, there is no loss of signal, the option exist as some receiver do sport a double RCA sub out.
Feb 11, 2009 | Polk Audio PSW10 Subwoofer
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Diamond Audio TDX-10D4 Car Subwoofer Logo
    95 people viewed this question
    Top Diamond Audio Car Audio & Video Experts
    xxxxxx xxx
    Are you a Diamond Audio Car Audio and Video Expert? Answer questions, earn points and help others
