Question about GE 32GT740 32" TV
My piture is getting smaller and my color is gone
I need to know if it can be fixed cheep or if its worth it.its a ge 42in.8-10 years old tv.
  • 1,512 Answers
Hi Jwalden
The picture shrinking is an indicator the the regulated HT power supply rail is going low in voltage resulting in EHT supply for the tube doing the same. . This will relate to component failure in the power supply itself, probably capacitors. It will progress, and eventually the set will stop. To be totally honest with you, it could run to $180-250 to overhaul the power supply and a few other areas of concern in a set this age. They were always a little on the "cheap build" side to begin with, so I would not recommend you spend anything on it, your money would be better put towards a new one. I know that this does not fix your problem, but is advice from a TV tech that knows. Thanks for using FixYa. I am happy to answer any other questions you may have. A FixYa rating of this advice to you is a great reward for the time I have taken to address it with you. Cheers regards rbotek
Posted on Jan 22, 2009
When the tv stopped working, the colors just started getting really weird and broken up then the piture seemed to get much smaller and shift over slightly
Quick Fixes for TV Picture Problems - Cox Communications
www.cox.com/residential/.../tv/guidedhelp.cox?...
Cox CommunicationsLearn · Learn · Explore Homelife · All About Data Usage · Getting Started with your Cox Services ... Just sign-in, click the Reset button, and get back to watching the show. ...Select Your TV Picture Problem. Poor Color ... We're always working to make Cox.com Support better, and we rely on our customers to help us do it!
Fix for Samsung lcd TV colour display problem - YouTube
? 1:26
https://www.youtube.com/watch?v=Q1bg9qP_qic
May 3, 2013 - Uploaded by alwaysafix
Samsung lcd 40" tv with a serious colour issue. Checked ...+Troy Simpson Happy to hear everything is working now. Thanks for watching .... Weird thing is that it just happens somethimes and no one knows why. IMO it's some ...
Vizio VX37L Help fix "Reverse Colors" Problem - YouTube
? 1:29
https://www.youtube.com/watch?v=_BEEnOCVmn4
Jul 16, 2013 - Uploaded by Paul Reisinger
Feb 08, 2016 | Televison & Video
My microwave stop heating what could it be is it worth fixing
The magnetron is gone, or the inverter board, "if 7 years old or less" To answer your question, not worth fixing, cheaper to buy.
Apr 28, 2012 | GE Microwave Ovens
Have a plasma samsung hpt5054 i have sound no picture is it worth fixing thanks
On a plasma that usually means a problem in the power sections. You should be able to get an estimate from a repair shop or Samsung repair depot. On that size of tv it should be cheaper to repair than replace unless it is several years old. Usually on a smaller tv just out of warrenty the cost to repair is worth more than just going out and buying a new tv.
As long as you know your replacement cost and get an estimate you will come out on top.
Jun 14, 2010 | Samsung HPT5054 50 in. HD-Ready Plasma...
Freezer only getting 48' and frig side is only at 49 degrees
take the back panel off and see if the fan is running and if not see if it has power to it if it does replace the fan and see if ur problem is solved the coil underneath the fan should not be frozen even if the fan is gone out this could be a sign that the lil black element that runs through the coil is gone out now if all this is good and still same problem ur probably gonna have a freon issue and unless u know how to charge one i advise u call a tech and if its only 6 years old yes it worth trying to fix
Mar 01, 2010 | GE GSS25SGMBS Side by Side Refrigerator
The microwave makes a popping noise, then a loud grinding noise
this could be any thing? first ask yourself how old is it???
if its more that 3 years old you would be better off just dumping it as getting it fixed would cost more that its worth??
and there so cheep now too!
however dont go trying to get inside of it to see if you can fix it yourself
there is a lot of very hight voltage in there even if its been turned off for a long time,,this voltage is in the 1000's of volts and it kills
have you ever seen a stun gun working???????????
well this microwave has the stun guns very big brother inside of it,,
it dont stun,,,, it kills! is it realy worth taking a risk for a fuw bucks?
please play it safe
Oct 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I turned the TV on, a mild 'pop' sound, and it immediatly shut off. Now it won't power on at all. Is it worth fixing? Its 11 years old (July 1998). Thanks for any advice!!
you may have just blown a fuse. check and replace with same size and type. if you smell burning, you fried something, and it may not be worth replaing on a 11 yr old tv.
Jul 31, 2009 | Hitachi 50UX58B 50" Rear Projection...
Picture went out on my 36'' RCA television, still have sound.
do you have and big sound system if you do the move them away from youur tv. or you sould just bring it to a shop it must be the picture tube
Jan 26, 2009 | RCA 36V430T 36" TV
Proscan PS36700
sounds like the blue drive is gone..if so this will have to be taken to a repair shop.
Sep 09, 2008 | Proscan PS36800HR 36" TV
22 year old 20" Mitsubishi TV
i think its time to get new one ,for 22 years it has served its useful life now its in the end life when it will start giving problem even if you fix this one another one may likely come up at times this is usually the case as most of the parts are worn out after many years of service even humans so i think your best bet should getting new one .
hope this helps
Sep 09, 2008 | Televison & Video
GE spacemaker color television AM-FM radio
This is easily reparable by an electronics technician. AND is definitely worth fixing if you use the unit because they simply do not build this type of quality in newer models.
Aug 28, 2008 | GE SpaceMaker 05GP009 Television
GE 32GT740 32" TV Logo
196 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
