Sharp X-Flat 32f630 cuts off screen. All sides are slightly cut off so I do not get the full picture. It is extremely annoying when I try to read text at the top or bottom, but can't because it's cut off 3/4 of the way. How do I fix this? I want the full picture.
    Top Expert:
  • Televison & ... Master
  • 75,283 Answers
It might be due to some wrong settings to digital channels. Check this link to know more about the proper settings.
Posted on Jan 11, 2013
Coldcut
  • 1554 Answers
SOURCE: Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Posted on Mar 08, 2008
SOURCE: picture is cut off at top and bottom
I had the same problem with my westinghouse 47 inch HDTV. It turned out that someone had inadvertently hit the "format" key on my satellite (Direct TV) TV remote controller. If you have satellite TV you might want to check this out. I set it back to the previous setting and I get the entire screen. Hope this helps someone.
Posted on Mar 13, 2009
  • 3 Answers
SOURCE: high def picture is cut off on the sides
I have a Toshiba 50HP15 PLasma flat screen TV. Its been working tone for 2 years now. All of a sudden without warningm the right 1/3 of tghe picture is missing and is black, where as the other 2/3rd of the picture is great picture and in HD. When I press DISPLAY on the remote control is says FULL 720p. When I press the Picture Size button on the remote the message NOT AVAILABLE come on. Anyone with suggestions. Thanks
scotto
Posted on Apr 19, 2009
MNfisherman
  • 11896 Answers
SOURCE: Picture is cut off at the top and bottom of the
Look on your remote to see if you have a picture butto or you can try and go to the menu settings and see if you can adjust the tv format from widescreen to regular or 4:3 or 16:9
Posted on Sep 23, 2009
budmrtn
  • 11361 Answers
SOURCE: my picture on the LG 37LC7d is too big for the
You need to adjust the aspect ratio, look for button on remote called 'ASPECT', 'ZOOM', or 'SIZE'.
You can download your TV user manul here, it will explain how to set aspect ratio.
http://tv.manualsonline.com/search.html?q=LG+37LC7d+&submit.x=27&submit.y=14
Posted on Nov 14, 2009
The picture is too big for the tv and seems to be growing bigger. how to reset picture size
On some remotes there is a button with Aspect/Zoom, try pressing that until you get the desired picture.
Sep 06, 2014 | Sharp Aquos Televison & Video
Why does the screen cut off slightly when connected to laptop via HDMI?
There should be a button in the menu to fix this issue under picture.
Aug 22, 2014 | iLO LCT32HA36 Television
The picture is cut off on all sides, and we have tried every button on the remote control - still no solution... Help!
U have the tv original wright?Yes?U tries push the VIEWMODE button pushes it couple times and pick Side Bar, S.Stretch, ZOOM, Stretch to pick the picture on screen that fit ur tv screen u like.
Aug 29, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My screen does not cover the whole screen. It is not on widescreen mode, but it is a shortened picture and some of what I am watching is cut off.
A lot depends on what the TV station cuts off also.
If they are transmitting a 5 X 4 picture, your TV will try an reproduce it giving cut off edges or top and bottom. It won,t fit properly.
Hope that helps to explain it.
Jan 22, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Picture is cut off on sides of screen
What's the resolution of your display?
There's a display ratio selection option in Menu. try selecting unselected options in it and check.
There might be a picture adjustment option in menu. try that too.
Regards
Vineeth K.
Jul 05, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My picture is zoomed in. Cannot go back to 'normal' and see everything. Credit names, etc are cut off on both sides.
Hi
Thanks for using FixYa. First of all please check your cable box settings first. Sometimes the remotes have a picture size button on them, and someone might have pressed that by accident. Check the TV settings, press Menu Button & then go to Window/Image size. Now select Full Size.
Also check the settings of the converter box (if you are using it). The boxes also have a peculiar problem: Unless users manually change settings from show to show, the picture from many stations either won’t fill the screen, or it will be so big that part of the picture is cut off by the edges of the screen. The solution is to press the “zoom” button on the remote that comes with the converter box. That will expand the picture so it fills the screen.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 26, 2009 | Sharp LC46SB57UN 46 in. LCD HDTV
Picture size
http://media.onecall.com/Image_Products/Sharp/LC_GD6UManual.pdf
Please read page 39 or in your manual page 38
Nov 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sound level & Picture size
The screen height is easy, just press the "view mode" button on the controller and change the scaling thru that. As for sound I'm not sure on that, as I can hear mine just fine, plus I use a surround sound system.
Jan 14, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
