Question about Frigidaire FEF336BC Electric Kitchen Range
Frigidaire Gallery Range (FGES3065KFC) makes an intermittent brief buzzing sound
Frigidaire Gallery Range (FGES3065KFC) works fine but makes an intermittent but consistent buzzing sound that lasts a couple of seconds. It sound too regular to be an arc, possibly more like an errant relay. Any suggestions?
yalmer
  • 552 Answers
SOURCE: Frigidaire Gallery gas range, oven door will not remain open
There may be a broken spring that helps the door stay open.
Posted on Apr 02, 2008
SOURCE: gas range
I have a frigeidaire classic gas range 12 years old worked fine until a pot of water leaked over the stove top burners. now the door locked lite is on and the door lock is activated , the oven door is open and won't close. The oven also does not work now, although the stove top burners work fine.
Can you help ? Thanks, Tom
Posted on Oct 20, 2008
  • 7 Answers
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
Posted on Jan 30, 2009
duby1990
  • 370 Answers
SOURCE: I have a frigidaire gallery stove. The bake not working
Your oven ignitor has gone out. This is located under the pan in the bottom of the oven. This is held in with 2 screws in the back portion of the pan. This will expose the ignitor and then 2 screws take it out. Replace this and this will fix it. very common problem
Posted on Feb 11, 2009
SOURCE: Is it possible to make the control display
or try this
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Posted on Jan 08, 2010
The cooling fan for the stove top stays on due to a burner showing HE but not on or hot
Hello Chris Lowman, thanks for your inquiry!
I understand that your Frigidaire range, FGES3065KFC, is flashing the error code "HE". However, it appears "HE" is an invalid error code. We should try resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes.
If resetting the power does not correct the issue and you continue to receive an "HE" I would recommend reaching out to a professional. He or she could come out and perform an accurate diagnosis on your range to assure the repair is completed properly. I hope this information is helpful. -Matt
Nov 04, 2014 | Frigidaire Kitchen Ranges
Frigidaire gallery gas range temperature display lights are very dim
Hello Peter Robinson - If the display LED's are dimmed on the range but it is working, then it sounds like more than likely the EOC (electronic oven control) or wiring failure will need replacing. I personally recommend contacting a professional for an accurate diagnosis and to assist with the repairs. You can often locate a qualified provider by visiting the manufacturer website.
Mar 04, 2013 | Frigidaire Gallery 30" Self-Cleaning...
I have a Frigidaire Gallery Professional Series Stove and Oven unit. The oven temperature indicator light has been fading for years and is now barely visible. Everything else on the control panel (timer,...
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
Oct 08, 2012 | Frigidaire FGEF3031KB Gallery 30"...
The lower burner in the oven of my Frigidaire Gallery Gas Range will not come on. The upper burner works fine.
The ignitor often goes bad and causes them to fail to light. The igniotr is easy to replace and will fix your problem.
This tip will help you understand this more.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Jan 27, 2010 | Frigidaire Gallery 30" Self-Cleaning...
Frigidaire FRS26R4AW5 buzzing sound not cooling
Something has stopped your compressor. The part could be the start relay, start capacitor, overload or the defrost control board. where are the buzzing sounds coming from ? Sea Breeze
Dec 20, 2009 | Frigidaire FRS26R4A Side by Side...
1998 frigidaire wall oven intermittant f1 code
F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Aug 02, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire gallery model plhs267Za
It sure sounds like a compressor problem to me. The buzzing sound is the compressor trying to start followed by a click which would be the overload protector tripping.
May 30, 2008 | Refrigerators
Frigidaire FEF336BC Electric Kitchen Range Logo
37 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
