Question about E-Machines eMachines Desktop PC
Rebooting problem Hi I'm the one writing about the rebooting problem. I rebooted and held down the del key and now I have a Phoenix bios screen. Can you tell me what I need to do next?
  • Colleen Schneider
    Colleen Schneider Jan 23, 2009
    Hi I got the windows to come back but it gives me a check everytime it is rebooted then it takes hours to go through. It shows several file segments that are unreadable. What does this mean and what do I need to do about it?
  • 3,940 Answers
Look for the listing for the hard drive (Primary Hard disk ) or some such) and see if there is an ie=dentification of the hard Drive (Normally a size and model are listed) if it says NONE then the drive is not being detected.
If that is the case, then you open the tower, and ensure all cable connections are tight and try booting again.
Most likely, the hard drive has failed and will need replacement
Posted on Jan 22, 2009
  • IQUIT Jan 23, 2009
    CHKDSK running on every boot indicates several bad sectors on the hard disk drive. Backup any important data and replace the hard drive.
Enter bios
This depends on your bios.
But the most common are F2 or the Delete key while the machine is rebooting. Just hold the key down and ignore the beeping. till the bios screen displays. Good luck!
Mar 23, 2014 | HP TouchSmart IQ804 Desktop PC
Usb drive bootsect
It may be that your BIOS is not setup to boot from CD before HDD. To get to the BIOS, look for the message for getting into the BIOS on the first screen after rebooting. There are many versions of the BIOS depending on the computer, but usually its F1, esc, del, F2, F3. It should say which to push on the first screen after rebooting. Look in the BIOS fot boot order, then put CD drive as the first boot order. Then save by either hitting F10, or pressing esc. This will make it so it looks for a boot.ini on the CD before firing up the HDD. Some CDs/DVD's will boot on their own, but usually it will say 'Press any key to boot from CD'. Press that and go from there.
May 30, 2013 | HP Compaq nc6220 Notebook
Samsung Sens X06 bios fail
see this steps and proceed .God bless you
    • 1 Download a crisis recovery program designed specifically to restore damaged or otherwise non-functioning copies of Phoenix BIOS. Read the instructions for using the recovery program to make sure that no specific changes or configurations need to be done to it before it is used.
    • 2 Place the Phoenix BIOS recovery program and its files onto a blank disc or a USB drive according to the program's instructions (this usually simply consists of extracting the files from an archive.) Once the program and its files are in place, insert the disc into the computer's drive or plug the USB drive into an available USB port.
    • 3 Hold down both the Windows key and the "B" key on your keyboard and press the power button on the computer. (On some laptop computers, you will need to press the "Fn-B" keys instead.) Wait for the disc drive light or the USB drive access light to start flickering to show that the computer is accessing the Phoenix BIOS recovery program, and then release the keys.
    • 4 Wait patiently while the Phoenix BIOS recovery program overwrites the damaged sections of the motherboard's current BIOS installation. Depending on the computer and the recovery program used, the computer may or may not reboot once BIOS recovery is complete. If the computer does not reboot on its own, wait at least 10 minutes before manually restarting the computer to make sure that you do not interrupt BIOS recovery. Eject the disc or remove the USB drive before rebooting to prevent accidentally reloading the recovery program.
    • 5 Reboot the computer and watch to make sure the Phoenix BIOS screen appears as normal. Once the BIOS loads properly, your operating system should launch as normal.
Oct 18, 2012 | Computers & Internet
How do i get into setup?
Watch the screen when you press the power button for which key to press to get into System Setup or Bios. Press Del repeatedly once you hit the Power Button.
Sound like you've got a memory issue.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 20, 2012 | Toshiba Tecra Computers & Internet
When I shut down the computer, the DWA 556 wifi card causes it to reboot. How do I stop this?
There are settings in the BIOS setup of most computers that allows the computer to be powered up by the Wake On Lan signal This allows you to remotely power up the computer by sending a signal to your network card. This setting is normally found in the Power Management portion of your BIOS setup.
Most motherboards allow you to access their BIOS settings by pressing the DEL key while your computer is first turned on. The first screen that shows on your monitor will normally have something similar to "Press DEL to run Setup" across the bottom of the screen. Whatever key is displayed is the one that you want to press as soon as you power it up. Once inside your BIOS look for the Power Management menu across the top of your screen. Once you choose that menu item the next screen should have either "Wake On Lan" or a "Power On By PCI Devices" setting. Make sure that this is turned off. You should then save your changes and exit your BIOS. Usually across the bottom of the settings screen, or on the side, you will see the keys you need to press to do so. Once you press the key or keys, your PC will save the changes and then reboot itself. Just to ensure that the change was made go back to the Power Management screen and make sure the setting is still off.
If your computer is still rebooting itself then the next step is to ensure that you have the latest driver for your adapter. Go to the following website:
http://www.dlink.com/products/?pid=549
You should see a black bar with Overview, Works With, and Support Resources labeled in the bar. Choose the Support Resources. When the bar changes you will then want to choose Drivers. Download the latest drivers for whatever version of your Operating System that you are using. Install them, then reboot your computer. Your computer should then recognize your adapter and install the new driver files.
If after all of this you are still getting reboots the problem might be the PCI slot you are using. Power down the computer, and remove the cover of the case. Remove the screw holding down your adapter and move it to another PCI slot. Re-assemble the case and power up your PC. If you are still getting the reboots then the issue is probably the adapter itself. Try and boot the computer without the adapter installed. If the reboots are gone then the card is defective. If you are still getting the reboots then you have a hardware issue with your motherboard. At this point you should have it looked at by your local repair shop. Due to the price of new motherboards it us usually cheaper to buy a new board rather than try and find someone who will repair it.
One of these processes should resolve your issue.
Mar 27, 2011 | D-Link DWA-556 (ASKU58510) Wireless...
I have a Phillips PC i bought in 2006 and around a year or so i rebooted to its original state and consequently I forgot the password to the only user account. SInce then I have rarely used the PC and...
to remove the hdd password do the follwing
1) Restart your computer. Note that during computer restart, the screen goes blank for 3 to 5 seconds. Text then appears and the operating system boots up.
2) As soon as the first text lines appear on the screen, press the "Del" key on your keyboard to enter the BIOS setup
3) Navigate to "Security" in the BIOS menu using the arrow keys on your keyboard
4) Navigate to the option "Hard Disk User Password" and press "Enter
5) Navigate to a hard drive, press "Enter" and select "Disable" to remove the hard drive password.
6) Press "F10" to save and exit the BIOS settings. Computer booting resumes.
this will remove the hdd password
Jan 17, 2011 | Philips Computers & Internet
Tower wont boot only beeps. cant get picture on screen.
OK follow this steps Bro.
perhaps you forgot to boot first the hard disk.
Note this steps is only for phoenix BIOS hardware.
1. reboot your system unit by pressing the combination short-cut key (alt+ctrl+del).
2.press delete button to check your BIOS configurations while on reboort mode.
3.select BOOT from menu to set your hardware configuration.
4.select hard disk codename or serial name using the arrow-up or down button to high-light the selected hardware and press plus button to replace the high-ligh color=equivalent to ascend the specified high-light.
5.press F10 to save the configuration.
6.the system hardware automatically reboot you machine in order to save your system hardware configurations after pressing the F10 button.
7.your done.
I hope this one will help you and God bless.
Nov 20, 2009 | Computers & Internet
NTLDR is missing
it means press ctrl+alt+delet at the same time and then you can turn of things from there
Jun 23, 2009 | HP Compaq Evo n400c Notebook
Replaced 512M DDR with 2G DDR2, only sees 512M
This often occurs as a result of fast/quickpost settings in your bios.
You will need to shut down your system, boot it, then quickly read the black and white screen.
Then press whatever button your system displays as the setup or bios button, generally Esc, Del, F1 or F2 but can be anything.
Once in your BIOS just browse around until you find the setting marked Quickpost, Fastpost, Quiet Post, etc.
When you find the setting, Disable it, save the settings and reboot. Once you're done rebooting, check the system properties. This should do the trick, then repeat the steps to re-enable the quick mode, and reboot again. It only needs to be disable for one boot sequence to allow the computer to find and add the new hardware to it's BIOS setup.
Hope this helps FixYa,
Chris
May 05, 2009 | Computers & Internet
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
