Question about Brother MFC-260C All-In-One InkJet Printer
Reset ink level brother mc 260 - Brother MFC-260C All-In-One InkJet Printer
2 Suggested Answers
  • 8064 Answers
SOURCE: How to check ink level on brother MFC-9440CN?
Run the Brother Control Center. Click Device settings. Click where it says Inklevel.
A simpler way is Start-->All Programs-->Brother--> ...-->Status Monitor.
An icon will lodge itself on the tray (a printer). When icon is clicked on, the inklevels will show.
Hope it helps.
Posted on Sep 03, 2009
After changing ink cartridge incoming faxes won't print. Does something have to be reset?
Some machines recognize you changed the ink cartridge and some do not. If you shut it down and restart it, this usually helps it reset.
Feb 28, 2015 | Brother Mfc-j6710dw Multifunction Printer...
Indicates black ink empty when its not.
Try removing the cartridge and shaking it. Brother printers use an optical ink monitor with a float inside the cartridge. The float can get stuck sometimes and indicate incorrect ink level.
But keep in mind that printers often indicate 'empty' (on purpose) while there is still bit of ink left in the cartridge, to prevent running out of ink during printing. If shaking doesn't help, replace the cartridge.
Aug 25, 2014 | Brother MultiFunction Center MFC-440CN...
My brother mc 240c print in yellow but not black? It connected to my laptop throw usb connection.
Clean the print heads and then make sure the drivers you installed recognize all of the ink cartridges ar their proper ink levels. Replace ink if necessary.
Aug 24, 2011 | Brother Multi-Function Center MFC-240C...
All ink printing probleum brother mfc-260
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Jul 28, 2011 | Brother MFC-260C All-In-One InkJet Printer
Canon pixma mini 260 is printig blank photos ink cartridge is full
Jul 22, 2011 | Office Equipment & Supplies
I replaced the inkjet cartridges in a Brother 210c All in One and it still shows low ink levels in the color cartridges (Black is fine). Where do I need to troubleshoot?
Just unplug the machine and plug it back in while you hold the stop key for about 10 seconds. Usually clears up and resets ink levels.
Nov 25, 2009 | Brother MFC 210C All-In-One InkJet Printer
How do I get the ink cartridges out of the mfc 290c???
its in the right frontal corner, there you can change the catridge, i got a problem too with Brother MC-290, it just keep saying CANNOT DETECT YELLOW INK REPLACE IT SLOWLY... this **** cant print just with the black one? ireally need to print something right now
Oct 04, 2009 | Brother MFC-290C Printer
Brother DCP-115C
good chance....Print head is blocked very common, what sort of inks were used?
 Not economical to repair, buy new!
Oct 19, 2007 | Brother DCP 115C All-In-One InkJet Printer
Brother MFC-260C All-In-One InkJet Printer Logo
21 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
