Question about HP Compaq nx9020 Notebook
Battery Problems My Battery stopped charing some time back so the notebook will only run on AC power. I have purchased a new battery, but that seems not to charge. The same with a second new battery. Clearly all three batteries can not be bad, so something must be wrong with the notebook. Anybody else with the same probelm? Anybody got a solution for me as without the battery the PC is difficult to use as I travel a lot. Thanks Phil in Cambridge
  • 432 Answers
The battery charger on the motherboard is bad. A small daughter board that holds the charging circuit will need to be replaced. I sure the battery is fine.
Posted on Jul 04, 2007
I have an ACER M5-581 and when the battery gets low and I am working on it and I plug it in to an AC outlet and continue to work it will show a charge for a few seconds and then stop charging. I have to...
If the battery is actually taking a charge but it seems the battery only lasts a short time after charging... it's time to buy a new battery. They eventually won't hold a charge very long
Note this is a separate problem then the case where the AC cable is plugged in yet the battery takes NO charge (what happens when the power jack breaks its connection to the computer so NO power reaches computer at all via AC adapter.
http://www.aurabuy.com/cheap-4400mah-battery-for-acer-travelmate-8473t-8573-8573g-8573t-4370-5335-5340-7340-tm5742-4740z-8573tg-5742z-paypal.html
Mar 31, 2013 | Acer Aspire One PC Notebook
New battery not charging
Some aftermarket batteries don't play well with your Laptop, the "pin-outs" may not be correct. Be sure to buy a genuine Dell replacement. I have no idea where you purchased it, but inexpensive replacements found on-line can be a problem, and, at best, will not work correctly, worst case can be a fire hazard. Return it and find another.
Mar 30, 2013 | Dell Inspiron 4100 Notebook
When i charge my acer aspire the power button flashes
The DC jack in the laptop is showing early signs of intermittent issues, the jack is solded to the motherboard which sometimes breaks free over time, this is something that will eventually need to be addressed.
Mar 25, 2012 | Acer Aspire 5336-2283 Notebook
Battery is not chared while laptop is running with a.c. power
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Nov 03, 2010 | HP Compaq Evo n610c Notebook
ZHow do I charge battery (new user)
just plug in your adapter that came with the unit.....leave it for the recommended time for charging and there you go.....if you don't have an adapter...you'll need to find out the required power that it needs and then purchase an adapter that will supply the necessary power....and also of course, the plug must also fit the receptacle on the back of your unit...with the correct polarity......good luck
silvio
Jul 08, 2009 | Dell Latitude C640 Notebook
Dell Inspiron 6400 Battery
your miracle,most laptop batteries have a life span of 4 years tops,but that if you take care of it,but most dont realize over charging kills the cells in your battery,and if you have it plugged up make sure you go into power settings and put it on ac/dc power settings.and if you have it away from home without power,put it on best battery settings,and let the power die all the way down before recharging,that will give it a full charge lasting longer.but as for your battery it might be time for a new one
Apr 14, 2009 | Dell Inspiron 6400 Notebook
Replacement adapter will not charge battery
Did the old one do the same thing? If true, your battery sounds like it is dead.
Jan 17, 2009 | Dell Inspiron 1501 Notebook
Battery charging
Does the machine boot and work just on AC?
If it does then you may have a bad battery - Does the old battery charge?
If it does not work on AC then try another AC adapter - even the generic universal kits should be enough to test it.
hopefully that's all thats wrong. let us know.
Dec 27, 2007 | HP Pavilion dv4000 Notebook
R40 2724-BU1 Power Problem
Check the ac adapter. It seems your adapter is not charging it. Either the ac adapter or your dc port may be the problem. Is this the correct adapter, is it giving the correct voltage. These should be considered also.
Hope this helps you
Oct 20, 2007 | IBM ThinkPad R40 2722 Notebook
HP Compaq nx9020 Notebook Logo
146 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
