Question about Dell 3100cn Laser Printer
Card stock will not feed in my dell 3115cn - Dell 3100cn Laser Printer
2 Suggested Answers
SOURCE: Dell MFCP 3115cn Error Message
From what I have read, it has to do with the scanner arm is jammed or locked. You may be able to toggle the plastic slider above the scanner glass near the hinge from the locked position. That didn't work in my case, but if you tear the scanner down, you may be able to free it. Otherwise a new scanner portion may be required.
Posted on Sep 27, 2011
How can reset all setting dell 3115 cn
"Here is what I did to reset the Dell 3115cn Laser Printer. In the users manual for the 3115cn in section 6 "Changing System Settings" "Resetting Defaults" refers to page 64 where it says, " For more information, see "Reset Defaults" in the User's Guide. Only I did not get a User Guide with my Dell. So I Googled "3115cn user guide" and downloaded it to my desktop and then went to Resetting Defaults. In the attachment "Initializing NVRAM for Network Settings" is what I did. Hope this helps someone else."
May 07, 2014 | Dell 3115cn Multifunction Color Laser...
My Dell 3115cn MFP prints 3 blank pages between prints or copies if I print more than 1 copy how do I fix this? What is causing it?
I will do first a full printer cleaning, that mean take off all dust and anything can that can be inside the printer (ex.bugs and dirt accumulation).
Second try to locate the printer rollers and check if they are in good condition.Printer rollers need to be in good condition because those are the parts that move the paper inside the printer.
Also when you feed the papers into the feeder make sure you air the paper so they don,t stick together.
May 07, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
Getting a constant "Paper Jam 071-100" error when printing from Tray 1 (no jam found).
You need to replace the paper pick up, feed rollers and separation sub-assebly.
Nov 27, 2012 | Dell 3115CN
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    Paper doesn't feed right.
    Normal 0 Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
    Worth a try, as I have fixed a number of printers this way, saving costly repairs.
    Hope this helps. Bud
    Jan 07, 2009 | Dell 924 All-in-One InkJet Printer
    Paper is jamming
    Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
    Jan 05, 2009 | Dell A920 InkJet Printer
    Ordering Belt Unit Dell 3110cn
    Yes there is, I found something on amazon, here: Amazon com dell 3110cn belt. I hope this one helped you. have a nice day
    Mar 13, 2008 | Office Equipment & Supplies
    Dell 3100cn Laser Printer Logo
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
