Question about Miele G880 Dishwasher
Miele g 870 sc dishes are dirty after a wash - Miele G880 Dishwasher
5 Suggested Answers
  • 177 Answers
SOURCE: Miele G 880 SC -- dishes not drying
Make sure you are using rinse aid. even if you are using tablets which has rinse aid built into the tablets Miele still recommend using rinse aid liquid as well.
Make sure you have the rinse aid setting on 3ml
Plastic will not dry as well as plates as it doesn't hold the heat.
You could call out a Miele service tech if it is still under warranty and he would be able to increase the drying time through his computer.
Hope this helps.
Posted on Apr 02, 2010
Richie_asg1
  • 1036 Answers
SOURCE: White film on dishes and still dirty.
Check rinse aid is actually dispensing - turn it up to max for a while to clear it, and check level is going down after a week.
If you suffer with hard water - your heating element may need replacing as it is probably furred up.
Posted on Jun 06, 2010
national_a_r
  • 148 Answers
SOURCE: My Miele G892 SC Touchtronic dishwaser is leaving
Make sure you have at least 125 degrees going into the unit. If your using detergent power make sure you don't over use rise aid. Many brands have rise aid already.
Hope that helps!
Posted on Dec 11, 2010
Daniel S
  • 4323 Answers
SOURCE: Miele G 870 SC dishwasher had blocked drainage due
Hi
The problem is with the float switch mechanism located at the bottom of the unit...either this has gone bad and should be replaced or the pump itself is bad & should be checked. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 26, 2011
We have a Miele G 870 SC dishwasher. The soap dispenser always opens properly to dispense soap if we run the Economy cycle, but it always stays closed if we run a Normal or Intensive cycle.
I would certainly check with the repairman and have it checked. It is possible that a connection may have been missed since the new dispenser was installed.
Oct 02, 2017 | Miele Dishwashers
Miele 870 dishwasher..timer works but doesn't wash goes thru cycle but no evidence washing or water swishing around.
I had this happen when my "water pump" went out on my dishwasher. It wasn't pumping the water up and into the machine or pumping it out.
Jun 05, 2017 | Miele Dishwashers
Miele dishwasher G646 SC plus water pump
I would suggest any appliance repair shop or appliance retail store should be able to order one in for you
Sep 06, 2012 | Miele Dishwashers
What is the most effective soap for thw Miele G870SC diswasher
the only dish detergents that work right now are the miele tabs, and finish has a product called finish all in 1 powerball. everything else on the market right now will leave your dishes dirty, and will leave residues behind making your glasses cloudy and your dishes dull. describe the noise better and i will try to help.
May 31, 2012 | Miele 24 in. G870 Built-in Dishwasher
Jun 06, 2010 | Miele G892SC SS Dishwasher
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Hope this helps.
Mar 20, 2010 | Miele G880 Dishwasher
Miele dishwasher G 1232 sc no longer dries
the problem with not drying is normally three things
1. not adding enough rinse aid to the compartment (dispenser) and adding to much soap.
ex rinse aid helps with drying,spots and cleanind the dishes. so if is none then you want get maximum cleaning.
3. make sure you run the faucet to get the hottest waster going into the machine this will make the other two do it job better because as you know you cant clean dishes properly in cold water.if this info helped please send me 4 thumbs post , thanks
Mar 01, 2010 | Dishwashers
No hot water, plates cold and dirty and wet
If you've installed it recently make sure the hot water tap was plumbed in and not the cold water tap, check the hot water tap temp in the house to make sure it's getting warm, there also should be a heating element located inside of the dishwaher that heats up to help the dishes dry at the end of the wash cycle, which is controled by a thermostat. If the heating element or the thermostat are bad your dishes won't dry.
Mar 25, 2009 | Miele 24 in. G638 Plus Free-standing...
Miele G892 SC dishwasher not heating/cycle won't stop
Miele have cold inlet only. Either element is open circuit, or the relay that switches the element has failed. My money would be on the element first, then the relay. The machine will sit in that mode forever as it is waiting for the temperature of the water to reach a certain temp before telling the electronic unit to move to the next part of the wash. If you need assistance in how to test & how to get to these parts just let me know. But you will need an ohm meter to test the element. Regards
Aug 20, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele G880 Dishwasher Logo
35 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
