Question about John Deere Garden
Clutch adjustment gt262
Hard to shift gears in manual transmission
  • 95 Answers
SOURCE: My 98 Escort ZX2 manual transmisson seems to shift gear hard!
Clutch may be smooth but this is a sign of the clutch needing replaced. Some of these models have a linkage adjustment under the hood. Others are hydrallic and need fluid. Look under the hood where the steering is and see which you have and address accordingly. Good luck. Check on costs of clutch replacement.
Posted on Mar 30, 2009
rockitman187
  • 2559 Answers
SOURCE: 1998/99 Dodge Dakota clutch and manual transmission problems
clutch needing replaced, very common on all manuals
pedal travel adjustment,yes
gear shift adjustment,no
Posted on May 12, 2009
csmock132
  • 4669 Answers
SOURCE: Manual transmission will not shift into any gear,
The problem sounds like the clutch. If you put it in 1st., then start it up, does it try to move with you foot on the clutch? Does the clutch pedal feel different than normal.
Posted on Jun 24, 2009
SOURCE: 1997 sL1 Saturn manual transmission hard to change gears
The dipstick is behind the battery, below the master brake cylinder and is not the clutch reservoir. It has a red flip top handle instead of a ring like most dipsticks. It was hard for me to find due to engine grease. I had the same problem and was able to see that I was low on fluid (only a little) and adding fluid helped the problem. Questions? kurt1431 at comcast dot net.
Posted on Jun 29, 2009
  • 221 Answers
SOURCE: my transmission is stuck in gear and wont shift to
a common problem with riders that speed shift (not that i'm saying you do) is that the clutch plates wear into the basket and or the shift forks bend or break either way you may have one of these problems or even shift detent or drum may be bad
Posted on Jul 25, 2009
Cannot get it in gear with out jamming it in and it grinds going in.
Year make model?? I'm suspecting a manual transmission. Most hard shifts/hard to get in gear are due to a clutch problem. Suspect a worn clutch/defective slave cylinder/defective master cylinder/ improperly adjusted clutch cable just to name a few
Sep 06, 2015 | Cars & Trucks
Trans shifting problems
Try to adjust clutch if it is manual transmission.
Aug 30, 2015 | 1997 Nissan Maxima
1.2 manual reverse gear problum
Manual transmission does not change gears with transmission oil. If yours is the AMT type, get it scanned for error codes.If the problem is in shifting into R, get your clutch cable adjusted. Your clutch plate may have also worn out. If shifting is OK but the car just does not move, the gear linkage/cable may need adjustment. If all else is OK, the reverse gear in the transmission may have been damaged.
Feb 13, 2014 | Proton Savvy Cars & Trucks
2003 FJR 1300 clutch adjustment
Hi, Darrell_kauf and the usual suspects are:
1. Clutch not adjusted properly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. A loose shift lever on shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Clutch Adjustment Technical Mechanical Problems
How to do clutch soak or replacement on Yamaha FJR 1300cc Second generation
Yamaha 2003 FJR1300 Service Manual
OEM parts for Yamaha
Yamaha FJR1300A Owner Manual
Feb 08, 2011 | 2003 Yamaha FJR 1300
1995 1500, 4.3 L 6, 5spd manual. Is there a
Unless this transmission was replaced with one using Hydraulic means of shifting? I know of none as a standard transmission?? Usually difficulty of shifting is because the teeth of the receiving gear is burred or broken?
Jul 14, 2010 | 1995 Chevrolet C1500
Fuso manual transmission hard shifting in first and second gear?
May need a clutch adjustment or not enough gear oil in in the tranny or worn shift forks.
Mar 25, 2010 | 1996 Mitsubishi Eclipse
I have a 1992 Gmc sierra manual transmission, the gears are hard
It is an adjustment or clutch replacenment issue. Manual transmissions rarely have a lube issue unless you have seen a big puddle of very thick oil in the driveway.
I think I'd be looking at the clutch of this 16 year old vehicle. Unless you have the tools, time and skill to change the clutch, this is probably a job better left to a professional. Adjusting the clutch mechanism might help for a while but I think you will soon need a clutch job on your GMC.
Thanks for your question at FixYa.com
Jan 14, 2010 | 1994 GMC Sierra
I have a 2004 mazda rx-8 6 speed manual transmission...i am having a real hard time shifting into gears...sometime it won't even bulge into gear, and that's when i have to use excessive forces just to put...
You need to check the clutch hydraulics i.e. the clutch master cylinder and the slave cylinder for their function, even if its cable operated try to adjust it so as it opens the clutch fork a little more to allow the clutch plate to be free,thus easy selection of gears.
If this fails thn you will have to replace the pro-kit i.e. clutch plate, pressure plate and release bearing.
Hope this helps!
Jun 14, 2009 | 2005 Mazda RX-8
May 12, 2009 | 1998 Dodge Dakota
Mar 30, 2009 | 1998 Ford Escort
Garden Logo
118 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
