Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
Ge PSS25SSNA vegetables freezing
Food in vegetable bins freeze
Sea Breeze
  • 4654 Answers
SOURCE: Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Posted on Oct 27, 2007
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
jumptrout51
  • 3361 Answers
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Posted on Feb 21, 2009
mastatech
  • 478 Answers
SOURCE: I have a GE side by side GS25LGM. The fridge side
try turning down the thermostat for the freezer side some times the controls seem backward. However most fridges are desighned for thwe freezer side with some thought giving to pushing some air to the refrige side. in most cases it easier to start back at medium settingsfor two or three days.
Posted on Mar 12, 2009
  • 323 Answers
SOURCE: vegetable and meat draws freezing everything temp@16 deg. f.
Turn your thermostat down. If all the rest of the food was even 45 degrees, it would be okay. The vetable and meat drawers will always be colder, so you set the level for the rest of the fridge at what is tolerable.
Posted on May 14, 2009
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Foods freeze on the vegetable bin even the control was set very low
Hi,There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Aug 04, 2011 | Microwave Ovens
Vegetables are freezing in lower bin Model # rs22aqxmq
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Apr 20, 2011 | Roper Refrigerators
Vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Jan 07, 2010 | Amana AFD2535DES French Door Refrigerator
My Kenmore Elite freezes vegetables in the vegetable bin on one side. The interior temperature is set at 46. How can I keep food from freezing? The vents are kept open as well.....any suggestions?
Hi, this problem is going to be with the running thermostat (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 30, 2009 | Kenmore Refrigerators
PSS25S side by side is freezing vegetables. We
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 12, 2009 | GE Profile¿ Arctica® Energy...
Vegetables are freezing inside vegetable bin
Most likely your refrigerator is set at too cold a setting. Just turn the temperature adjustment to a warmer setting.
May 03, 2009 | Refrigerators
I have a GE side by side GS25LGM. The fridge side gets too cold that it freezes the vegetables. There is a humidity control on the vegetable bin. It didn't matter if I set it to high or low it still...
Mar 12, 2009 | GE GSS25LGM Side by Side Refrigerator
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
