Question about Vizio CT14-A0 - 14" - Core i3 3217U - Windows 7 Home Premium - 4 GB RA
Getting into bios screen - Vizio CT14-A0 - 14" - Core i3 3217U - Windows 7 Home Premium - 4 GB RA
Unable to enter Asus 6850 BIOS
I would start by resetting your bios settings to default; turn off your system, remove the side cover and gently pry out the board battery (round "button battery" such as cr2032). Leave it out for about one minute, and reinstall. Then see if you get a post screen.
Dec 29, 2013 | ASUS Computers & Internet
How to go to the setup page
I assume you want to get into the BIOS setup page. Usually when you switch on the PC you will get a screen with the Samsung Logo and a small message at the bottom of the screen telling you which button to press to access the BIOS. This is usually F2 for Samsung PCs. If you press F2 before the logo screen disappears then you should be taken to the BIOS setup screen.
Aug 12, 2013 | Samsung 300E Notebook
When I switch the laptop (HP Compaq nx8220) on I get a black screen with this on it: 163 time and date not set. I can't get past this screen and have been looking online (another machine) for information...
to get to the bios screen
turn the laptop on and at the same time hold down the delete button until the bios scree appears
you will have to get the back off to get to the battery ( 1" round and 1/8 " thick)
May 29, 2017 | Computers & Internet
Hi have a dv8225nr laptop. did bios upgarde to fix keybroad problem after download restarted laptop and gets to hp logo and stops.can't get in to bios. can get to screen to set was goiging on with esc keep...
when you make the update bios you back up the old one?if yes then restore if not find the battery on the motherboard remove it end put it back this should reset all then you should go in bios to see the version of bios is active.
Dec 08, 2009 | Computers & Internet
Can't get into the bios for a presario 4716
This is what the Compaq site had to say about the BIOS utility for your system (Source: Compaq): • • • •You may have difficulty accessing the BIOS Setup utility screen, because you must press a specific key(usually F1) very quickly before the Windows screen appears. If you do not enter the BIOS Setup screen on your first try, repeat the following steps until you are successful.
To open the BIOS Setup screen:
1. Turn off the PC and wait about 5 seconds.
2. Turn on the PC.
3. When the first screen appears, press the F1 key on the keyboard. (You can press the key more than once.) The BIOS Setup Utility Main menu appears.
NOTE: On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
4. Use the keyboard to navigate through the menus.
You may need to remove the battery and then back in.
Jul 21, 2009 | Computers & Internet
Toshiba laptop 2 years old, the screen is black. The laptop turns on but get no screen.
You can try connecting an external monitor and if you can get to the CMOS/BIOS you can verify that the active screen is your laptop screen. If everything is OK on the BIOS, then probably your laptop screen is broken. To enter the Bios use F2 or F10 (depending on model) when booting.
Jul 19, 2009 | Toshiba Equium 7100S PC Desktop
I was trying to go through recovery thinking I could get more speed on laptop and I messed comp. up. Only get a blank black screen. tried powering down, rebooting, still can't get on. Help!! i was trying...
Flashing the Bios is a LAST DITCH effort to resolve Hardware issues. You should NEVER flash the bios unless you are absolutely certain it's the correct bios for your computer, also NEVER flash bios from within windows..
There may however be a solution for you, Acer laptop computers with the Pheonix BIOS sometimes has a " flashback" feature, allowing you to revert to your original Bios..
You will need to contact Acer to get a Crisis Bios recovery disk from them. Or ask for further information on how exactly to recover from a bad bios flash.
May 30, 2009 | Acer Aspire™ T180 PC Desktop
Trying to reformat my PC but can't get into BIOS set up.
Hey,
Seems the screen is slow to start up, right after pressing the power button, keep tapping on f1 or f10 untill the bios screen or something else comes up. that will definitely get you into the bios and dont mind if the computer starts to beep, slow down a little and keep tapping.
Thanks,
Ekse
Aug 30, 2008 | Computers & Internet
ELITEGROUP K7AMA
How far does the Boot get? Is your keyboard active (is it polled?), do you see the BIOS boot screen? Can you access BIOS?
Can not boot from CD or HD, with BIOS screen showing, is one thing.
Can not get BIOS screen showing, is another.
Both are, can not boot from CD or HD.
Dec 20, 2007 | EliteGroup K7AMA Motherboard
Vizio CT14-A0 - 14" - Core i3 3217U - Windows 7 Home Premium - 4 GB RA Logo
26 people viewed this question
Top Vizio Computers & Internet Experts
Jessi Singh
Level 1 Expert
Electroboy
Electroboy
Are you a Vizio Computer and Internet Expert? Answer questions, earn points and help others
