Question about ASUS A7N8X-E Deluxe NForce 2 Ultra 400 Motherboard (90M7A770GOUAYOZ)
Sata concetion I have a ASUS A7N8X-E Deluxe NForce 2 Ultra 400 Motherboard, and I am trying to use a SATA harddrive as the primary master for the OS. Thanks
  • Justin Wolery May 11, 2010
    You stated what you are trying to do but not the problem you are having that may be preventing you from doing it...Please provide more information on your problem.
    Scholar:
  • 54 Answers
SATA HDD's do not have master/slave/cs jumpers like IDE drives do because only 1 cable is connected to each drive, so you have to plug whichever HDD you want to be primary into the SATA0 port (or SATA1 if there is no SATA0) on the motherboard.
Also make sure you have your masterboot recrod installed on the drive you use to boot.
Posted on Jan 22, 2009
ASUS A7N8X-E Deluxe NForce 2 Ultra 400 Motherboard (90M7A770GOUAYOZ) When I built my PC in '05 I installed 4 HDD's on the A7N8X-E Deluxe. Now my main drive is failing so I've cloned it to a new HDD, but...
hi Memory,
You can try 2 things:
1. If the HDD has jumpers make sure to set the one you want to boot from as the master.
2. Go into your BIOS and choose which device to boot from first.
Also just to be sure disable all other drives and boot with the single drive to ensure that it actually works. There are bootdisks that can help with booting issues one being called ultimate boot cd but i wouldn't touch settings unless you know what your doing.
Hope this helps,
Omeil
Jan 31, 2011 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
I have recently bought a samsung SATA spintpoint 1tb hdd. The hdd gets stuck at the post. It says the name and no of the drive but nothing else. I have to reboot. Controller issues with the Sil3112A?? ...
No, the controller is just fine - but make sure that the RAID setting is disabled.
If the hard disk can't go beyond POST then it is damaged. Test it this way: put it in anther functioning pc, then install in it this free program
http://www.hdtune.com/files/hdtune_255.exe
Run the program and test the hard disk.
Oct 05, 2010 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
I get to the splash screen then it locks up!!!
does the hd disks and drives reconized on bios scren? problebly some hd drives has fatal failure, and lock bios, try remove hd cable, and test
if not try to change memory for new ones ( same types has manual spec.)
remove usb cables internal cards readers (low quality cards readers has normaly freezes bios)
Nov 22, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Can i replace supreme fx with fxII on my asus a7n8x-e deluxe
mother board as class as form factor this is a standard connector and mounting style if the two board you are trying to replace are the samr form factor then yes it should fit make sure the all you parts like the cpu and the video are compatable. if you using a agp video card then make sure the board has an agp slot and it the correct speed bou other then those type of checks it should work if thing match up the form factor
Jun 10, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Need diagram of how to hook up my western digitial sata harddrive to mother board a asus a7n8x-e deluxe
this motherboard does not support your new Hard Drive. SATA is a connection type required for your hard drive. Your motherboard supports IDE connector. You probably can get a pci card that allows you to attach the hard drive.
May 24, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Black screen after factory BIOS reset
Have u connected signal cable to the monitor? Is it ON?Try with different monitor
May 07, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
I need to know where the power and hdd led jumpers go asus a7n8x
Don't you have a manuall for your motherboard ?
Check it here:
http://support.asus.com.tw/download/download.aspx?modelname=A7N8X-E Deluxe&SLanguage=en-us
Be sure for polarity of the connectors (not 'jumpers' as you say)
Regards.
Mar 28, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
What wireless card to connect to A7N8X-E deluxe ?
From Asus website:
"The Wi-Fi slot is specifically designed for the ASUS Wireless LAN add-on card"
Nov 05, 2007 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Asus a7n8x deluxe
Please make sure your HDD are in proper configuration. An IDE device have two cofigurations. Master and slave. Any motherboard will have two IDEs. Primary and Secondary. You can connect two drives to one IDE in Master and slave configuration. This is determined by setting a small pin called jumper setting. You should visit the following website to know more about setting jumper for a Hard disk. http://www.seagate.com/www/en-us/support/installation_assistance/jumper_setting_illustrations/ http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ATA_Jumper_Settings&vgnextoid=cbc974850ce0e010VgnVCM100000dd04090aRCRD This way you could solve your problem.
Sep 26, 2007 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
ASUS A7N8X-E Deluxe NForce 2 Ultra 400 Motherboard (90M7A770GOUAYOZ) Logo
133 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
