Question about Microtek scanmaker 3840
Scan material not found no. scan function will be performed
What is ceramic fiber and how does it functions?
Ceramic fiber board was made by desiccation, machining and refined through vacuum forming or dry process. It's an ideal energy saving material for kiln, pipe and other insulation equipment.
The advantages of ceramic fiber board:
1. High compressive strength and long service life.
2. Low heat capacity and conductivity.
3. Non-brittle materials, good tenacity.
4. Precise size, good flatness.
5. Easy to cut and mount, convenient construction.
6. Good performance at anti erosion.
7. Continuous production, uniform fiber distribution and stable performance
Characteristic of ceramic fiber:
Beside the fine properties of bulk ceramic fiber cotton, ceramic fiber board has hard texture, excellent toughness and strength and good performance at weather-proof. It won't expand when heated. Besides, it has light weight so that it can be constructed convenient and arbitrary shear bending.
The application of ceramic fiber board:
1. The backing insulation for kiln of cement and other building materials.
2. The backing insulation for kiln of petrochemical, metallurgy, ceramics, glass industry.
3. The backing insulation for kiln of heat treatment.
4. The backing insulation for non-ferrous metals industries.
5. The backing insulation for high-temperature reaction and heating equipment. http://www.ceramicfibermanufacturer.com/
Mar 07, 2017 | Computers & Internet
Where is the scan button and how do I scan?
The scan function can be performed by using either IJ Scan or ScanGear software from your PC and it is available from Canon support centre.
Follow this link and download the user manuals and software to set up the scan function.
Canon Support Drivers PIXMA MG2520
Aug 05, 2014 | Canon PIXMA MG2520 Inkjet All-in-One...
During slide scanning, after performing auto focus and auto exposure, get error message "there was an error in performing a post processing" any suggestions? using Nikon cool scan v ed
First suggestion would be to connect scanner to another PC to see if the problem persists. Might also help to try to scan with alternative material (mix if slides and negatives) to narrow down where the issue lies. You could also play with features such as Digital ICE on and off. I'm afraid if none of these produce a functioning scanner you will need to contact Nikon to arrange a repair. There is really nothing the typical user can do to fix these machines at home.
Oct 13, 2013 | Nikon CoolScan V ED Film Scanner
TMA doesn't work ;code 22
If 22 is blinking in the Scanner LCDThe Transparent Materials Adapter (TMA) may be attached incorrectly or is broken.
  1. Disconnect the scanner power cord.
  2. Disconnect the TMA cord from the scanner.
  3. Verify there are no bent or broken pins in the cord plug of the TMA. If the cord has bent or broken pins, it will be necessary to contact HP .
  4. Reconnect the TMA cord to the scanner.
  5. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  6. Check that the TMA is properly positioned on the scanner glass; either reposition the TMA in the positioning plate or reposition the positioning plate on the scanner glass.
  7. Reconnect the power cord to the scanner.
  8. Attempt to scan.
If 22 "The scanner could not scan" displays on the screen and the Transparent Materials Adapter (TMA) is being used
  5. Reconnect the power cord to the scanner.
  6. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  7. Attempt to scan.
  8. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
If 22 "The Scanner could not scan" displays on the screen and the TMA is not being used
  1. Disconnect both the scanner power cord and the USB cable.
  2. Perform a self-test on the scanner if it has a built in self-test. Click here for instructions on performing a scanner self-test (c00030441) .
  3. If the scanner passes the self-test, reconnect the USB cable and attempt to scan. If the scanner fails the self-test, it will be necessary to contact HP.
  4. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
May 05, 2012 | HP 4570C Flatbed Scanner
I have accidently gone past the automatic tune function when 1st turning tv on . How do I manual tune?
I think you mean perform the channel scan function. Every tv manufacturer has different wording in the menu, but basically this is what you would do:
Press Menu, then go to Setup or Installation menu (wording depending upon mfg).
Select antenna or cable (wording could be air or cable)
Perform channel scan
Hope this helps as you didn't mention model.
May 17, 2011 | Televison & Video
Who is production key
Options available with the play station device inlcudes first familiarising with the user guide to ascertain the feature functionalities. Among details provided on the users ownser guide are support expert contact, disgnostic material instructions. Important knowlagde about the playstation device that least requires product keys to perform functionalities. First the devices performs as video grame device once powered on to capturs functionalities requiring disk or cartidge media to commmnece funtionalities.
Mar 02, 2011 | Ubi Soft Prince of Persia: The Forgotten...
Document is scanning upside down
Easiest way to confront this problem is to rotate the material being scanned.
If you find the image of the item is being inverted then simply rotate the material being scanned by 180 degrees.
Additionally most scanning software will have a ROTATE function where you can rotate the image of the scanned material, usually in 90 degree increments which can be useful for editing purposes. You may find this function under Edit or Image in your scanning software.
Good luck! William
Mar 02, 2011 | Canon DR-2050C Path-Through Scanner
My Canon MP160 inkjet won't print. In trying to print a test page, I get the message that the ink absorber is full. What is the remedy for this?
A message display is common with insufficient ink cartrigges. Printers that perform several printing tasks is usually common to deplete the ink capacity. Alternately, installing an ink cartrige may have been a lasting duration possible need for a new cartridge replacement. However, perform a device functionality check by opening the compartments that contain replaceable materials. Ascertain the depleted material requiring replacement like ink, printing paper. Also, observe any malalligned materials like stuck printingn paper. Once every replaceable parts have been cleaned and restored, reconnecting the printer to the computer should request for an allignment functionality.
Jan 18, 2011 | Canon PIXMA MP160 All-In-One InkJet...
It's performing really slowly. How do I restore factory setting's i only have a blank recovery disc.
First do a virus scan and delete or quarantine any malware that comes up in the final results of the scan. Reboot the computer and see if it is running normally. If the computer is still not functioning properly you can use "Windows System Restore" to restore your computer's software configuration to an earlier date when it was functioning properly. The "System Restore" program is found under Programs/Accessories/System Tools.
Jan 22, 2010 | Acer Aspire L310 (ASL310UD631A) PC...
Microtek scanmaker 3840 Logo
Top Microtek Office Equipment & Supplies Experts
Tony
Martin Murray
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
