Question about Samsung Digimax S730 Digital Camera
The Camera Will Not Come On
I have tried several pairs of good batteries and the camera will not turn on. The screen will come on for a second, and the green light comes on. Sometimes it goes right out, sometimes it stays on. The last time I used it, the batteries died right away. The lens didn't even have time to close.
  • 1 more comment
  • Anonymous Jan 26, 2009
    Hi, I have the same problem!!!the lens is came out and when I turn on the camera the LCD turn on for less a second and the green light sometimes turns off and sometimes remain on.
    Can someone help me!!!
  • Anonymous Feb 09, 2009
    je ne comprends pas pourquoi quand je veux faire des photos il me dit de changer les piles elles sont neuf ├ža me saoule
  • CapNormative Feb 21, 2009
    Quite simply, I have the same problem. I just got new batteries and now it turns on for about three seconds after which I hear three solid "beebs" and the camera shuts off. It's quite irritating.
Some camera require batteries that are made for digital cameras. I have a samsung s730 and i use energizer rechargeables and havent had the problem since.
Posted on Apr 02, 2009
I have the same problem, is there a way to send the camera to the company directly ?
Posted on Jan 24, 2009
Power turns on but will not stay on .
If you haven't already...I'd try new batteries and use good ones like Energizer Lithiums. Some electronic devices are sensitive to lower battery voltages.
Jan 15, 2018 | Vivitar Vivicam T324n - 12.1mp Digital...
I have a Sony Cyber-Shot camera and when I turn it on it says to turn off and then turn on. I have done this, several times. The battery is fully charged but I did try a new battery with the same result....
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 08, 2011 | Sony Cameras
Camera will not take pictures and I can not see anything thru
Found this on another web site. Worked for me
Turn the camera on in shooting mode.
Turn the mode selector to shutter priority (“Tv”).
Use the four-way button on the back to set the shutter speed to 15 seconds.
Press the shutter release. Count to seven, then pop open the battery compartment. (I discovered that the camera will beep when you do this.)
Wait several seconds, then close the battery compartment.
You may need to repeat the above sequence several times to unstick the iris. If that does not accomplish it, you will likely have to send the camera in for repair.
May 13, 2010 | Canon PowerShot S2 IS Digital Camera
Flip Ultra - freezes at initial Flip screen - will not shut off
I found a fix that worked for mine.
It was doing the same thing, freezing at the "Flip" screen and would not turn off. I did the remove the batteries deal. It worked once but issue reoccured 2 months later and the battery fix didn't fix it.
What did fix it was...
With the camera off, hold down the Right Arrow button and the trash can button at the same time and turn the camera on.
A few seconds later, I was at the start recording screen!!
Good Luck!
Jul 21, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
1. Please make sure that you're using a fully charged battery.
2. Please try Initializing the Camera. To initialize the Camera.
First, press the Menu button on the Camera to display the Menu items.
Then, select the SETUP option under the Menu.
Then, select the SETUP1 under the SETUP.
Then, select the Initialize under the SETUP1 option to Initialize the Camera.
If the issue still persists, then try Power Resetting the Camera.
First, turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the Power switch for 30 seconds.
Then, reinsert the battery pack into the Camera and turn ON the Camera.
If the issue still persists after performing the steps provided above service of the Camera is required.
Jun 17, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Camera turns on for 2 seconds or wont turn on at all.
There is no hardware reset on this model. We have many situation on different make digital cameras that uses AA batteries that would not turn on with some other AA batteries due to Amp requirement on the batteries. Which means that some circuit design would work only with rechargable batteries because they have more power due to higher Amp power. So I would try rechargable batteries for the last resort. -James
Apr 12, 2009 | Fuji FinePix A820 Digital Camera
Sony cyber camera
The Camera is displaying the Turn the power Off and On again message when the Lens in the Camera is stuck or when any internal malfunction happened.
To resolve the issue turn the power off and on several times. If the issue persists, try power resetting the Camera. To power reset the Camera, remove the battery from the Camera.
Press and hold the power button on the Camera for 30 seconds.
Remain the camera without power for 60 seconds and re-insert the battery.
Also try resetting the Camera back to factory default. Press the RESET button located at the lower right corner of the control buttons using a sharp pointed object.
Good Luck
Thanks for using FixYa
Nov 19, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Turns on for split second
Same as above light flicks briefly will not come on tried several batteries that works in another camera please help Frank JJ Cali
Nov 12, 2007 | Sony Mavica MVC-FD200 Digital Camera
Samsung Digimax S730 Digital Camera Logo
206 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
