Question about E-Machines eMachines Desktop PC
Emachines , shutting off on it's own?
My eMachines computer was shutting down on it's own after anywhere from 15 seconds to 3 minutes after turning it on. I replaced the fan tonight and it was doing great. It stayed on for over an hour. Then it shut off at 9:05. I turned it back on and it stayed on until 9:40. I turned it back on and it stayed on until 10:10. But this time it shut off and immediately restarted itself.
What the heck is going on with this thing? Do you think it could be the power cord?
Thanks for any help.
  • gina fanning Jan 22, 2009
    Thanks. I sure hope it's not the motheroard, the computer is only a year old.
    Scholar:
  • 54 Answers
While it is possible the power supply could be going bad, usually it would not work intermittently like this.
Most likely the motherboard is starting to go bad, I would do a quick visual inspection for any buldging or leaking capacitors, if you see any that is definatly what is causing the problem.
If you dont see any damage to the motherboard you can try replacing the power supply, if it still behaves this way then your motherboard is the problem (sometimes there are no visible signs of damage on e-machine motherboards even when they have completly fried)
Hope this helps :)
Posted on Jan 22, 2009
  • Justin Wolery Jan 22, 2009
    I hope it isnt as well, unfortunatly I have seen a lot of e-machines die after only a year or two, so it wouldent surprise me.
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
EMachines E19T6W monitor turns itself off and on.
First off, I would check the monitor, if it is getting very warm, I would use a can of compressed air to blow the dust out (make sure it is unplugged first!). Second, I would check for any sort of interference in the vicinity (speakers are a huge cause of problems in Monitors) such as magnets.
Oct 27, 2009 | Computers & Internet
The PSU fan does not run, computer shutsdown.
Check the CPU fan, it may be faulty and causes the CPU to overheat and shut down.
Sep 02, 2009 | E-Machines eMachines Desktop PC
PC SHUT down
three things i find to cause this,
one, the power supply is bad,
two, the power connector is lose or not push in
three, the heat sink on the processor has come off. This will cause the cpu to over heat and self shut off.
to test the power supply, pull the connector off the mother board and short the green wire to any black wire with a paper clip, this will switch on the power and see if it stays on.
if you need to replace it, you cannot use a regular atx power supply. E machines have a different pin out.
Aug 12, 2009 | Dell E151FPp 15" Flat Panel LCD Monitor
After installing hard drive, monitor, keyboard, mouse not working
Have you tried to enter BIOS? Are you able to enter BIOS?? There may be an option you have to hit to enable SATA, and to select the boot device order, which may be messing things up.
Also, remember that STATIC ELECTRICITY is your enemy! Ground yourself when working inside the case.
Dec 30, 2008 | E-Machines eMachines Desktop PC
I need to re down load my drivers on my emachines
Is your "Turn off Computer" shut-down option is greyed out?
Go to power options in Control Panel and click on Advanced tab. Check setting under "Power buttons".
Also check Power schemes on first tab, drop down box making sure "ALWAYS ON" is not selected.
Jun 28, 2008 | E-Machines eMachines Desktop PC
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
Want shut down
Click Start, then turn off computer, and make sure that your computer is not set to standby or hibernate. This works if you are running Windows XP or Windows 2000. Hope this helps!
Sep 11, 2007 | E-Machines eMachines Refurbished EMA...
E-Machines eMachines Desktop PC Logo
134 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
