Question about Whirlpool GEW9200L Electric Dryer
Whirlpool GEW9200LW0 Not heating
I have a Whirlpool Duet, Model # GEW9200LW0 that does everything but the heating element is not getting hot. Is there a way to verify the element is bad? And how do I replace it?
    Scholar:
  • 93 Answers
Hi
You need to remove the back panel first then with a multi meter the easiest way is to put the meter on continuaty test (beeps when contact is made then with the dryer switched of and unplugged put one probe on the one side of the element and the other on the other side if it beeps then your element should be ok if not one of two things (1) Your element is blown or (2) there should be a fuse around the area of the back support plate it may be a normal round fuse or a ceramic round fuse or what looks like a brown rectangular piece of plastic with a wire out each side test the fuse in the same way as you tested the element if blown replace if not then put in a element.
Posted on Jan 22, 2009
I have a whirlpool duet gew9200lw0,it will not heat. I replaced the thermistor, thermostat,termafuse and multiple other parts and still will not heat. I need help please.
You changed all these bits without establishing whether the element was faulty? Find a local appliance engineer.
Nov 15, 2014 | Dryers
My duet drye will not get hot but runs
check your heating element if gas test regulator
Aug 25, 2012 | Whirlpool Duet WFW9550 Front Load Washer...
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
Dryer is not getting hot its a whirlpool duet?
IT SOUNDS LIKE THE HEATINGS ELEMENTS HAS BURNT OUT REPLACE THEM AND YOUR DRYER SHOULD WORK FINE.
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet dryer is getting too hot
YOU NEED A NEW THRMO KIT
STEVE'S APPLIANCE
516-300-3249
Mar 15, 2009 | Whirlpool LER5636P Electric Dryer
Whirpool duet dryer mod GEW9200LW0, working but not heating up
If it's starting and not heating it's usually one of two things. Take off the bottom panel. 2 screws hold it in place. If you have a way to check the element with a meter or something that would be ideal. It should read about a short circuit. The other part that goes out a lot is the thermal fuse located in the front on a pipe it's long and narrow. Here is a link to show where things are in there. Let me know if you have any more questions
http://www.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=GEW9200LW0&productCategoryId=0151200&brandId=1198&modelName=DRYER
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Heating Element for Whirlpool Dryer: GEW9200LW0
I think on this one you can take off the bottom panel on the front and get access to the heating element.
Dec 16, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Oct 27, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool GEW9200L Electric Dryer Logo
779 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
