Question about Logitech S200 Computer Speakers
Inside subwoofer Help for the non-techy pls?? If you look down the hole in the front of my logitech X230 subwoofer, the bit that is attached to the hole has become dislodged. How do I get inside the speaker to realign it? I have tried to remove the panel at the back, but the power suppy lead is too tight/short to allow me to remove the panel completely. I have tried to remove the circular grill/speaker on the side, but it is either unmovable, or extremely tight, and I daren't force it. Any suggestions, pls?? Di
Ok, i had the same problem. i dont think the stinken back comes off. i was however able to loosen the control panel enough that the cardboard tube ( the rattler ) was wedged up against the back. i put all of the screws back on and presto, no rattle.
Posted on Nov 30, 2008
I had the same problem, but mine are still under warrenty, you should check if the speakers you have are too?
btw, this seems to be a common problem with the x-230's whereas I had a pair of z-340's running strong for a good 4 years, upgraded to the x-230's and soon as I opened the box I found the rattle in the sub-box..
Posted on Jan 22, 2008
  • 84 Answers
Most likely the whole thing is glued together. You'll probably have to use force to get it apart, and it probably won't look as good when you put it back together.
Posted on Jul 06, 2007
Schematics for logitech x230 speakers
Hey Jaime,
Unfortunately, Dell does not have any available schematics for wiring the x230 speakers available. You would have to maybe contact Logitech.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 06, 2014 | Dell Dimension 2350 PC Desktop
Subwoofers not working on Logitech R-20 speakers; worked until recently
did you fix it? I have exactly the same problem, I'd appreciate any help please
Jun 03, 2009 | Logitech R-20 Computer Speakers
My x230 wont work it work for a min then cut out and dont work!!!
Try and twist the jack which is connected to your PC, the solder inside could have snapped. If it has a diferent pwer source for the sound system, then power on, hold the jack and short the ends with your fingertips. If the speakers dont respond then its not getting any power, which could be simple loose connection too. Test both and then decide. If you dont have the correct driver then download from: http://www.new-drivers.com/files/speakers/Logitech/?gclid=CM_a2oOjtpkCFcQtpAod6hp-5Q........sodeep
Feb 23, 2009 | Logitech X-230 Computer Speakers
X230 logitech not working.
i did the same to mine,
just replace the power transformer with one that accepts 110-240 volts
easy to do, but check cost might be better to buy a new set depends on your situation
Aug 20, 2008 | Logitech X-230 Computer Speakers
Crap sound, subwoofer no longer working
Guys try to reinstall your audio drivers, because i had the same exact problem, so find out what sounds card you have and go on their website and download the latest sound card driver
Mar 03, 2008 | Logitech X-230 Computer Speakers
Service Manual for X-230
I used a Radio Shack D-Sub 9 Pin Connector #276-1427
Pin 1-Empty Pin 2-Purple Pin3-Yellow Pin4-Red Pin5-Shield Wire & Green
Pin6 & Pin7-Gray Pin8-Blue & Black Pin9-Brown
The pin numbers are on the face of the connector and are hard to see.
Feb 17, 2008 | Logitech X-230 Computer Speakers
Subwoofer control
No there are no adjustments to that model as far as I know thats why they call them sub woofers my nephews would break their hearts getting at one of those and they would have the bass full bore...hahaha!
Aug 28, 2007 | Logitech Z-2300 Computer Speakers
Logitech Z-5500 Speaker stand problem
The stand was held on with a nut on the inside. There is not longer a nut on the inside of the hole, so there is now nothing for the stand screw to attach to. The nut is now stuck to the magnet on the speaker. You will need to disassemble the speaker housing to remove the nut from the speaker magnet and reattach then stand. peace. Paul.
Dec 31, 2006 | Logitech Z-5500 Computer Speakers
Logitech x230 speakers
Reinstall sound card drivers.
Jan 11, 2007 | Logitech X-230 Computer Speakers
Logitech S200 Computer Speakers Logo
239 people viewed this question
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
