Question about Dell XPS M1530 Notebook
Can't eject dvd from dell xps 27 - Dell XPS M1530 Notebook
    New Friend:
I had this problem, talked to a Dell support person for two hours with no success. Went to bed, next morning, I powered the desktop off (not restart) with the power button. The first time, the DVD drive cranked up but didn't eject the disk. The second time I powered it off and then on again, the DVD drive ejected the disk.
Posted on Apr 01, 2014
5 Suggested Answers
T-Mania
  • 42 Answers
SOURCE: dell xps m1330 dvd won't eject
Does windows pick up the drive? If so right clcik the drive and select eject. Apart from that if theres no pin hole you could try re-installing drivers. Go to device mangaer and right click the dvd drive select uninstall then reboot let it re-install itself and try ejecting again. If the normal button doesnt work though it may be a physical issue.
Let me know how it goes.
Posted on Mar 23, 2009
  • 489 Answers
SOURCE: dvd drive wont eject the dvd.
find a thin stick but must be verry thin.  you will see a small hole in DVD uniit.  put the stick in it your dvd will eject.
Posted on May 29, 2009
  • 10 Answers
SOURCE: dell xps m1330 dvd slot
Update firmware version from the support site. support .dell.com enter your "service tag" to get proper device driver then flash or update latest BIOS software from the support site aswell
Posted on Sep 29, 2010
SOURCE: I have Dell XPS M1330
Is it a slot load?
this is a common manufacturing defect on slot loads. ask for replacement.
I had this problem on brand new macbook pro. there are thousands of other user with same problem.
solution= get it replaced before warranty expires.
Posted on Jul 14, 2011
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
Dell xps A2010 CD Will not eject
Manual eject on the XPS ONE A2010.
Remove back case 2 screws on the bottom. Now looking at CD/DVD drive remove the 2 screws for the led on the drive. And there it is the hidden manual eject hole....hope that helps
Jan 27, 2013 | Dell XPS One All-in-One TV Desktop with...
How do I get a dvd to eject from a studio xps 16 notebook.
I had this same problem. If this is a slot drive.. there is no way in,, so i'm told.I flicked hard / banged the top of the laptop above where the drive is whilst pressing the eject button.
Failing this, I would send it back (under warranty) or get a new drive, but I'd assume you'd have to say goodbye to the stuck disc.
N.B. I would not recommend to anyone to physically abuse their laptop.. but hey!.. it worked for me!
Good Luck!
Aug 15, 2011 | Dell Studio XPS 16 Notebook
CD or DVD does not stay in slot. Computer ejects it without reading.
The Dell™ XPS One™ A2010 system features an enhanced one-time boot menu that is easily accessible by pressing at the Dell™ logo during POST. The options in the boot menu are:
  • SATA:3M-WDC WD2500AAJS-75RYA0
  • CD.DVD:3S-TEAC DVD+/-RW DVW28
  • Network:IBA GE Slot 00C8 v1250
  • Dell Diagnostic Partition
Try to boot from a boot-able CD such as the Dell Resource CD. If it still ejects the CD then your CD/DVD drive needs to be replaced.
Jul 26, 2011 | Dell XPS One All-in-One TV Desktop with...
Dell xps m1330 dvd slot cannot load. if cd/dvd is inserted, it is ejected instantly.
Sep 29, 2010 | Dell XPS M1530 Notebook
CD Drive not Recognized / Wont Eject CD
There is a small pinhole in the face of the dvd drive. Use a paperclip to poke into the hole. It will force an eject of the dvd drive. You can also explore the computer, right mouse click on the drive letter of the dvd drive, choose "eject"....
If it still will not eject, unplug the ribbon cable from the drive but keep the power plugged in, then press the eject button. If worse comes to worse, four small screws, and you can remove the shell of the drive exposing the dvd inside....
Good luck!!!!
-------------------please vote 4 thumbs up 4 me!!!!-----------
Apr 25, 2010 | Dell Dimension XPS 400 PC Desktop
Need to replace the CD/DVD combo. It will not
Any SATA DVD combo should work they are all industry standards.
Jan 26, 2010 | Dell Dimension XPS PC Desktop
Dell xps m1330 dvd drive will not eject cd inside
Im a dell tech, and i hate those cdrom styles, but, that is what the consumer wants, so we make them. Try starting the machine, then press F2 to enter the BIOS. once in the bios, press the eject button. listen for any noises, (an attempt to eject). if you hear a sound, it means the drive should be capable of ejecting the disc, and perhaps the disc has not seated correctly. If the disc will not eject, you must contact Dell. This is from the DELL dcse site: " Optical Drive The XPS M1330 has a slot-loading optical drive instead of a conventional tray-loading module. There is no mechanical eject mechanism for the drive to eject stuck discs. This means you must replace the drive if a disc gets stuck in the drive. After replacing the drive, disassemble the old drive to remove the disc for the customer."
Jul 21, 2009 | Dell (0F146) Internal DVD Drive
Dvd drive wont eject the dvd.
May 29, 2009 | Dell Studio XPS 16 Notebook
CD Wont eject
Tried in Safe Mode Windows? Worst case is the shut it down, straighten a small paper clip, push it into the small hole on the surface of the DVD-ROM cover (It's a standard to have one). It should eject!
If system will not eject the CD due to a software locked it down, please list softwares the XPS have installed.
May 23, 2009 | Dell XPS One All-in-One TV Desktop with...
Dell XPS M1530 Notebook Logo
469 people viewed this question
Alun Cox
