Question about Sony PlayStation 2 (PS2) Console
Disc is trouble
My PS2 is working fine except on 1 game.The PS2 is reading the disc but when it goes into the gameplay it will not show anything.Boooooo!
  • 32 Answers
Ratbag: Check the following: 1. CD surface. If it has many scratches, should use a CD Fix kit. For it, if you consider that the game is worthy. 2. Clean the laser lens with a CD Lens Cleaner, most of us (and I should apply this also) do not clean frequently the Laser Lens, causing this kind of problems. SithPitt
Posted on Jul 04, 2007
SOURCE:
How can i get my ps2 to read the metallica guitar hero game
If it is a PS2 game disc it should read just fine. If it is not, it wont. If it is new, return it as defective. If a new disc does not work you will need the drive repaced or repaired. Call us for free phone support or a repair. 1-800-479-4620
I’m happy to help further over the phone at https://www.6ya.com/expert/jay_25de800b00457e27
Mar 18, 2013 | Sony PlayStation 2 (PS2) Console
The game cannot be read on our ps2, but the ps2 works for other games. the disk looks fine. what can we try to get this game to play?
Even if the game isn't scratched, you should try holding it under a light to see if there are any fingerprints or smudges on the disc. You can try cleaning the disc with a lint-free cloth if you've got one, though I've never had trouble with a cotton t-shirt. Wipe from the center of the disc straight towards the outer edge. Do this for the entire disc and try it again.
If that doesn't work, please update this issue with the error message you're seeing if any. Does the disc show up in the PS2 browser? Do you get a disc read error? Does the screen just go black when you try to play the game?
May 04, 2012 | Konami Yu-Gi-Oh! Duelists of the Roses for...
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
Had ps1 game resurfaced, no longer works on ps2
Sounds like you need to get your money back ..the resurfaceing can also do more bad than good
But a little trick lightly rub a crayon over the disk ,,old pantyhose works great rub it off from center out then try your disk ,,have saved many good games that way
Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
Playstation 2 cannot run some games
it might be a problem in the wiring which would have to be fixed by an expert. also you could tey cleaning the disk tray using a compressed air can. you can find these cans at most place like walmart or electronic stores.
Aug 06, 2008 | Sony PlayStation 2 (PS2) Console
Playstation 2 problems
The PS2 Works fine right correct?? If it does and you want to fix the Laser do the following :
Step 1 Turn off the PS2 if on.
Step 2 make the PS2 lie down on its back where the PS2 logo is not seen.
Step 3 Take off the Rubber Squares which are located from all 4 corners and take out the screws using a screw driver.
Step 4 Take off the lid of the PS2 after the screws are taken out.
Step 5 near the light of the PS2 were it shows the Green and blue light is a box where the PS2 disc runs.
Step 6 screw the top of the box and you should see a disc if not taken out and underneath the disc is the lens use alcohol and gently wipe the lens with a Q-Tip after doing so put the lid out of box back on and open the disc drive and put a game in it should work or just get a new PS2 Slim.
Jun 22, 2008 | Sony PlayStation 2 (PS2) Console
Config/browers shows on ONE game
try running it with the ps2 upside down? if not then the fault in the game if all the outhers work
Feb 26, 2008 | Sony PlayStation 2 (PS2) Console
Play station 2 will not work
You should try to get a ps2 disk cleaner and a cleaner for your system.
Jan 03, 2008 | Sony PlayStation 2 (PS2) Console
Won't load certain disc
Buy a new one. I try all thwe solutins you can bring up. none work except a new game!!!
Dec 28, 2007 | Sony PlayStation 2 (PS2) Console
My new ps2 game wont work
if your ps2 is old, it may not take certain disks e.g. purple backed disks, dvds and a disc read error problem will appear in the browser
Dec 04, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
