Question about Whirlpool Refrigerators
Refrigerator model no. ED2VHEXV001 how to remove water filter and new filter part number ?
milten1
  • 1304 Answers
SOURCE: How do I change the water filter in the Whirlpool
the water filter is in the toe kick on the bottom
it is a push twist type and should almost pop out when in the right position.
the best buty online right now i know of is at appliancepartspro.com
your looking for part number AP3182816
29.00
tell them you want the dealer discount and order 3
you will use em and you might get an additional
15 percent off no guarentee
have a great day
Posted on Oct 06, 2009
FreshWaterSy
  • 13 Answers
SOURCE: What is the part number for the water filter for a
The part number is 4392922 for the water filter. You can purchase this water filter at the below link for $ 34.49
http://www.freshwatersystems.com/p-3051-whirlpool-kitchenaid-deluxe-filter-4396510.aspx
FreshWaterSystems
1.877.335.3339
Posted on May 19, 2009
  • 286 Answers
SOURCE: Do all ice maker refrigerators have filters on the water line
Most refrigerators dont have one, Usually you can install on in the supply line. If there was on it might be behind the frig
Posted on Jun 11, 2009
aasc
  • 1606 Answers
SOURCE: Kenmore
I would suggest , home depot , or , a hardware store , which supplys a filter , with replaceable cartridges . Usually runs about $ 50.00 . This filter , will mount to the wall , and not the appliance itself . If you " bypass " the filter , it may stop the dispensor flow , and / or , the ice maker water flow .
With the new filter , you can use , calcium filter , charcoal filter , or calcium filter replacements . Even lime , I believe , is available .
As far as removing the filter , I suggest , trying , to see if the water / ice maker still works , after removing .
Posted on Dec 15, 2009
SOURCE: water leak at filter
I had this with a Kitchenaid Superba and wanted to get rid of the filter holder assembly entirely as I have an undersink unit which serves the fridge. I removed the plastic line (nut) at the back of the fridge (which led to the filter holder at the front) where the flexible copper tubing inserted (this was a 3/8' compression fitting-plastic) and also the returning line (1/4" copper compression nut on a plastic line) at the manifold (again in the back of the fridge) where it gets split between the water line and the ice line. I then just connected the 1/4" flexible copper directly to the manifold (1/4" nut, compression sleeve, male-male connector) using a pre-made 1/4" flexible compression line. Sounds complicated but after seeing how the water routes it was fairly quick work.
Posted on Mar 07, 2010
Kenmore elite 596.735 .water leaking from rear of water filter unit.
What is the complete model number of your unit? Look inside the refrigerator section.
Oct 21, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
I own a fridgidaire side by side. the model number is FRS26W2AW9. WE CAN NOT FIND WHERE THE WATER FILTER IS ON THIS UNIT. DO YOU KNOW.
Removing and replacing a water filter - upper right hand corner inside location
Filters situated up front in the refrigerator compartment of Frigidaire-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Open the door of the refrigerator compartment of your Frigidaire brand side-by-side refrigerator. The filter is located in the upper right hand corner. It has a push button for quick release just to the right of the filter.
  2. Locate the icemaker On/Off power switch and place it in the OFF (o) position.
  3. Push in on the filter release button and pull the filter all the way out to remove it. Remove new filter from its packaging and remove the protective plastic caps. Insert the new filter in the same manner it was removed. Make sure to push in firmly on the filter until you hear the filter cartridge click in place.
  4. Return the icemaker's power switch to the On (l) position.
  5. Condition the filter by running water through the dispenser for about three minutes. This will flush the filter of all fine carbon particles.
  6. In some models, you will have to reset the filter status light. It is located on the ice and water dispenser control panel. Push in on it for ten to fifteen seconds until the green, red, and amber lights flash. If your refrigerator model does not have a filter status light, you should make a note on a calendar, or place a month sticker on your filter to remind you to replace the filter again in six month's time.
Sep 04, 2011 | Refrigerators
Jenn-Air Refrigerator JS42SEDBDA Model 12606032GJ was in house when I brought house. No user manual. Does this model have a water filter? The refrigerator has the words water filter,and underneath that...
Remove the compressor cover to locate the filter.
www.appliancepartspros.com has the filter.
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-refrigerator-water-filter--puri-clean--item-number-ap4343710.aspx
Aug 20, 2011 | Jenn-Air JS42SEDBDA Stainless Steel Side...
What is the model number for the water filter for the KitchenAid #KSRG25FKSS16 refrigeator and where is it found in the refrigerator? thank you.
Hello pssutherland,
I understand that you need to locate the water filter on your KitchenAid fridge. The water filter is located at the bottom of the fridge in the grill. There is a eject button that you will need to press next to the water filter in order to get it to release.
1. Press the eject button
2. pull the filter straight out
3. Remove the cap by turning it clockwise (you will need to install this on the new one)
4. Reinstall the cap on the new filter
5. Push the filter in until the eject button pops back out.
6. Purge the system run three full glass of water thru the water dispencer and throw away.
7. You are done
Thank you for choosing FixYa.com
Justin
May 11, 2011 | KitchenAid Superba Architect KSCS25INSS...
Where is the water filter on the amana #scd25tw
The Amana with model number SCD25TW does not have a water filter. You would have to install an in-line filter on the water supply line if you want to filter the water. If your talking about the model number ARS266ZBS, then open the refrigerator door and look at the top right hand side. You should see a filter housing with a tab to release. Once released you have to remove the filter from the housing to replace it. When finished be sure to run about a gallon through the dispenser, to flush any air out of the system.
Mar 23, 2011 | Amana ARS266ZBS Side by Side Refrigerator
Side by side refrig - ice maker and water don't work after replacing the filters. is there a re-set?
Removing a water filter from the inside of your Frigidaire brand refrigerator:
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator or shut off the water supply when replacing it. Also, this filter should be replaced every six months.
Oct 31, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
How do you get the water filter out of refrigerator so you can replace it
Without knowing your particular model number, I checked and most 25 cu.ft. side by sides have the water filter in the grille. You just push a release button and it pops out. There is a cap on the filter, do not through it away as you will need it on a new filter. Also ensure the O-ring protective covers are removed on the new filter prior to installing. You can run the water dispenser without a filter as well. Here is a link to the PDF for one type of 25 cu. ft. Whirlpool side by side.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GS5VHAXWA_Use%20and%20Care_EN.pdf
Jul 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Pure Source Water Filter inside the refrig. is overflowing
most likely you have a bad filter holder the part the filter connects to,next time send the model number off of the machine so whoever helps you can look up your model and send part numbers to you.
Dec 23, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
"change water filter" continues to flash when dispensing water
I believe your new Jen-Air has an old model number placed above your post. If you had a newer model nuber I could see if changes were made to the solution. The ods are no changes. I it possible you may have missed removal of te flilter plug? It also is your first time and to press the 2 buttons at same time for 8 to 10 seconds may be a little confusing. I bet after this time you will have this down to an art! here is what I could find without the vorrect model number if that is what happened or not.Jenn-Air
Press and hold the light and lock buttons until the change filter light flashes.
It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the filter light flashes (usually 5-10 seconds).
Mar 05, 2010 | Jenn-Air JCB2059G Bottom Freezer...
Refrigerators Logo
447 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
