LG fuzzy logic, where is the softner compartment and bleach compartment
SOURCE: Water in bleach/fabric softne compartment
Purchased the duet washer and dryer sept 2004..have had the same problem with water staying in the compartments. while under warranty had to place 2 service calls..the last tech order a new bleach compartment...that helped for a few months, but back to the same problem with having to pull entire container out and empty..i do remember the tech saying that whirlpool duet was first introduced in germany...then the united states...they have had the same problem...and that whirlpool is awhere of it, but nothing can be done about...except keep emptying compartment when it fills with water...our neighbor bought a duet washer last fall...no problems like we are having..whirlpool must of solved that issue with the newer versions.... paying $1000.00 for a washer and having to empty the compartment everytime doesn't make sense to me.
Posted on Apr 06, 2007
SOURCE: Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Posted on Feb 05, 2008
SOURCE: LG FUZZY LOGIC
Are you sure it is the bowl and not inside the pump with the impellar hitting it on spin cycle? I just had the same problem and had to remove a dime from inside the pump.
Posted on Oct 10, 2008
  • 155 Answers
SOURCE: LG washing machine fuzzy logic 8.5 kg not agitating
The reason to this problem can be due to any one
of these reasons.
Lid Switch
Motor Coupler
Belts
Clutch
Drive Motor
Drive Pulleys
Transmission
Agitator
Posted on Sep 06, 2009
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
Fuzzy Logic 8.5Kg WF-T857 Turbodrum. How do you clean your machine and can you replace the fluff pockets?
Your owner's manual will show the amount of bleach your size tub requires. Run the machine on normal cycle that you use but do not add washing powder or fabric softener, only the bleach.
When the cycle has ended, open it up and allow to air dry.
The lint filters are replaceable and are available from your nearest LG service center or distributor.
Apr 16, 2015 | LG Washing Machines
My LG washer machine will not rinse thru the softer section in the cup, what can I do?
then the solenoid is not actuating to allow water into drawer. take top off, very easy, two screws in back, pull back, lift off. follow hose from softer cup to little round device/solenoid. check wiring. check hose, tho you would know there was a problem with hose, because you would see a water leak. replace solenoid. hope this is the issue. good luck.
Mar 02, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
Ii have a LG WFT9250PP Fuzzy Logic top loader washing machine. I keep getting dirty ****-like marks on my washing.
Run a hot wash with a Descaler which is available form most hardware stores.Marks on washing usually comes from a build up of detergent and softner between drums.
Oct 15, 2011 | LG WFT1071TP Top Load Washer
Lost manual to LG washing machine WF-T502c Fuzzy Logic. Just want to know where detergent and softener go?
I do not know this model. However, on other top load LG washers, the powdered detergent goes in a box at the back (top) of the washer, and the fabric softener when diluted gets poured into a spot near the left side of the top of the washer. (The bleach goes near the front of the washer.) For front-loading washers, the detergent and fabric softener are poured into the detergent drawer. The largest compartment is for detergent (wash cycle) and is usually on the left. The smallest compartment is for fabric softener.
Manuals for most LG appliances are available at their site. Start at http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WF-T502C&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WF-T502C&initialTab=documents&targetPage=support-product-profile . The manual is in a DjVu format.
A partial manual is also available here: http://monitor.diplo-best.com/review/LG/WF-T502C . You will need to review the washer or enter a code.
I hope this helps.
Jun 13, 2011 | Washing Machines
Which part does the powder go in the first from the right or the left LG WD-8013F
should be the left then the next compartment is for bleach and the right for fabric softner. Good Luck
Dave
Oct 13, 2009 | Washing Machines
Water left in bleach and fabric softner after running load
You must take out the compartment and empty it out before adding any bleach the next time, there is a type of button way in the back that you press down on pull out the entire door and empty the water for the next washing. You must press down very hard the entire door does come out check out your book for instructions it is way in the back on the left hand side. This happens to mine once in a while not all the time.
May 05, 2009 | LG WM1812C Front Load Washer
Oily substance
most common is lint build up. a good hot wash with a good bleach...check your manual for manufacturer's recomendation. There's various products available..bleach is the most in-expensive and works well. make sure its set on high water level...pause machine for 10-20mins...let me know how you get on
Jan 03, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
