Question about Necchi Sewing Machines
How To Use the Bobbin Winder for Singer 600 auto reel machine
How to Wind the Singer 600 bobbin winder
  • 3 Answers
SOURCE: Bobbin stuck on bobbin winder, how do I get it off? it will not budge!
Is thread under bobbin? can you turn it? can you pull the thread off the bobbin and then remove it? Bobbin that comes with machine may not be right one. Right one has a light blue tint and a slightly domed top.
Posted on Jul 08, 2007
  • 201 Answers
SOURCE: Bobbin winder is only thing that works
What model are you talking about? For my older Husqvarna machine you had to pull the bobbin winding bit out to wind the bobbin, then push it back in when you were done.
Posted on Jan 06, 2008
textile
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
  • 980 Answers
SOURCE: singer 328k bobbin winder replacement
Follow these instructions, undo the 2 screws on the right hand side plate where the balance wheel is and take the plate off, undo the screw on the chrome stop motion wheel, undo the stop motion and take it off, take off the 2 pronged washer and notice which way it goes on, not a problem if you can't remember, you should be able to pull the balance wheel back so you can get to the screws on the winder, if you can.t and if you have a problem getting the balance wheel all the way then go the very bottom of the machine and you will see 2 big holes and one of the holes will lead you to a big screw and nylon adjuster, slacken the screw and move the nylon adjust so the belt goes slack, you can not take the balance wheel all the way off to get to the screws on the winder, take the old one off and screw the new one on, whilst you have the balance wheel off it would be wise to put some thin oil on the shaft before you put the balance wheel back on, when you have the balance wheel on and the and the belt round the pulley turn the nylon adjuster so the belt is tight and tighten up the screw, put the side plate back on, put the 3 pronged washer back on, put the stop motion wheel back on and just tighten finger tight then tighten the small screw.
Posted on Nov 22, 2009
  • 16 Answers
SOURCE: Bobbin winder will not spin on sewing machine
If you take the top off you will see a tiny rubber tire that engages the winder to the handwheel. Over time they get really soft are really hard and disintgrate. If you have a local sewing shop take the old one in and get a new one to slip on it takes only a few minutes and cost usually less that $2.00
Posted on Jan 22, 2010
Singer Tradition - my bobbin winder has stopped winding so I have to wind thread on manually.
Check on a standalone bobbin winder called "Sidewinder." Make sure it is compatible with your bobbins--some bobbins won't work on the Sidewinder. If it is compatible, then for ~$30 you can wind all your bobbins. (I have one that is powered by battery or by electricity.)
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Simplicity SideWinder Bobbin Winder Walmart com
Jul 16, 2017 | Singer Sewing Machines
My 1130 bobbin threader turns, but will not wind thread.
Check that the bobbin winder is snapped all the way over.
Sorry, unable to provide more help, but a standalone bobbin winder may be helpful. You can find one brand (called "Sidewinder") at sewing stores like JoAnn's or online for ~ $30. Just verify that your bobbins will work (some Singer bobbins do not), but I assume your machine is a Bernina. Even if your bobbin winder is repaired, this standalone bobbin winder will save wear and tear on your machine--also, makes it so-o-o-o much easier to wind a bobbin without first removing the thread from your machine.
Oct 10, 2016 | Sewing Machines
Does a stand alone bobbin winder for futura singer bobbin exist?
A stand alone bobbin winder DOES exist, is commonly available, does a better job, AND is inexpensive. Just go to the WalMart site (even if you don't want to buy from there) and put "bobbin winder" as a search term. My favorite is a Simplicity, available for under $25, AND if you order it and pick it up at one or their stores or a FedEx facility, shipping is free.
Feb 08, 2016 | Singer Sewing Machines
Trying to wind the bobbin on my singer 6268 but the thread keeps winding under the bobbin. What am I doing wrong?
if the bobbin winder is driven of the end of the machine then you may have to guide the thread as it winds onto the bobbin
if you are allowing the thread to come directly from the reel and it is not in line to the bobbin then what you have is what will happen
Jul 21, 2015 | Singer Sewing Machines
Bobbin winder on singer 1725
Hai, Please change the new bobbin winder. Because bobbin winder and winding is very important.
Mar 20, 2014 | Singer 1725
My singer quantum 9940 bobbin will not fill even. What seems to be the problem?
There's a small screw on top of bobbin winder on your machine. Turn screw to adjust pressure where bobbin meets the winder when winder is pushed to right to wind it. Test with small turns until you are satisfied with appearance. Make sure nice, even fill- as you know, imbalanced bobbin will reak havoc. Jimmy
Apr 09, 2012 | Singer Sewing Machines
How do you thread the bobbin on the model 9805c?
To wind a bobbin, reel on top of the machine, take the thread to the left and go around the small wheel, back to the winder, bobbin on the windere and wind the thread round a few times, slacken the stop motion and wind the bobbin.
If you have a drop in bobbin, hold the bobbin in your left hand, thread on the bottom of the spool, drop the spool in, take the thread through the slot to the left and lay it across the bobbin with enough thread to be pulled through by the needle
Aug 05, 2011 | Singer 3343 Mechanical Sewing Machine
I have an old Singer, Model #6146 from the late 70's or early 80's, can't remember when my mom bought it, but I can't remember how to thread it and I don't know how to put the thread on the bobbin. Any...
Cotton reel on top, take the thread from the reel to the left and over the top guide, straight down throught the tension discs, back up to the take up lever making sure the lever is at the top, through the lever right to left, straight down through any guides and thread needle front to back.
To wind the bobbin, reel of cotton on top, bobbin on bobbin winder making sure it is pushed to the left, take the thread to the left and round the small wheel and back to the winder, wind the thread round a few times on the bobbin, push the windewr to the right, and loosen the stop motion in the balance wheel.
Mar 27, 2011 | Singer 2250 Tradition
I have a singer sewing machine model 4613 and cannot remember how to fill the bobben. Can you help
If I remember, cotton the reel pin, thread to the left and round the pretension and back to the winder, bobbin on the winder, push the winder on, slacken the stop motion, press on the foot control, if youy have a self wind bobbin let me know.
Mar 08, 2010 | Sewing Machines
Threading bobbin on singer stylist 522
To wind a bobbin put the cotton reel on the top pin, take the thread to the left and round the little wheel and back to the bobbin that should be on the winder, wind the thread round a few times to take a grip, release the stop motion in the balance wheel, turn the winder button so the winder moves to the balance wheel and press on the foot control slowly.
When you put the bobbin in the bobbin case make sure it turns anti clockwise.
Jun 27, 2009 | Brother CS-8072 Computerized Sewing...
Sewing Machines Logo
48 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
