Question about VDO X1DW CAD Digital Wireless Cycle Computer - Grey
It doesnt work and than it does
Its not connecting to sensor when i ride , but it starts ok indoors before or after ride
Tip
Pc can't start and beep in cpu.
when this problem, you cand do below step:
1st:remove all cable in cpu cabinate (power cable, monitor cable,etc.)
2nd:open cpu & remove ram
3rd: Clean it.
4th: push properly ram
5th: now 1st step opposite (Connect all cable)
6th:check it.
if your problem still not solved you can check other ram slot.
otherwise you can check ram other pc. if ram not work, it's problem in ram. otherwise you motherboard's ram problem. ok.
on Dec 05, 2009 | Watches
VDO x2dw cycle computer, sensor 2 doesn't work
Is the sensor properly spaced from the magnet on the spoke? Will the sensor pick up slow revolutions but not fast ones. Do you know that some of the sensors have two batteries in them, one on the top and one on the bottom, and both need to be changed at the same time?
Feb 01, 2014 | VDO X2DW Digital Wireless Cycle Computer -...
Daewoo damas
fixya doesnt sell products --do online search for parts or check with a dealer
Jul 07, 2017 | Watches
Polar ft40 watch doesnt work. I have replaced the battery and nothing happens.
This heart rate monitor has a generic flaw with the sensor. The touch sensor fails after a few months of use. It is not a battery issue. Return to where you purchased it. Buy another brand. All of the drug stores carry this watch which has an abnormal return rate. The sensor fails after a few months while the watch function is fine. Seems like planned obsolescence.
Sep 07, 2011 | Polar Electro Polar FT40F heart rate...
I dont know how to turn the alarm off on my casio protrek triple sensor watch and it alarms each midnight!?
Scroll through the screens until you get to the alarm screen and select the barometer button to turn alarm on and off.do not go into edit mode.
Sep 03, 2011 | Casio Protrek Triple Sensor Prg 110T 7VDR...
I have no speed or trip distance showing, cadence is normally ok. also my watch strap has broken and because it is glued on i cant get it fixed!
Since your Cadence is working then there is a problem with the actual speed/ distance sensor. First make sure that in your settings you have speed turned on. If so then...
1) Your battery may be dead = Replace CS sensor
2) The distance of the sensor and magnet is not set correctly = make sure magnet on spokes and sensor are within 1-2mm of each other.
Polar can fix the strap, you need to send into an authorized service center. They replace the entire strap unit. If you send into Polar to get the strap fixed, then you can send in the sensor unit as well for diagnosis if you want. But if #2 doesn't fix, then it's #1 and they will just tell you to buy a new one anyway.
Nov 29, 2010 | Polar CS300 Cycling Computer and Heart...
Tissot prs 516 will not wind. doesnt work. Could it be overwound? I ride a motorcycle. Would the vibration overwind it?
This watch is described as "quartz chronograph", so it is not a self winding watch.
Go to http://www.tissot.ch/?mod_collections/action_getsubfamilies/colid_0002/famid_0012/refid_T044_417_27_031_00 for a description of the watch.
If it has stopped working, cold the battery be dead *have you had it for more than a year)?
Sep 28, 2010 | Tissot Prs516 T91141731 Watch
Luminox 3100 series stops working at night
Sounds like there could be a bit of foreign material floating about inside, or the new battery was not up to scratch. Take it back for checking.
May 29, 2008 | Luminox Navy Seal Dive 3001 Wrist Watch
VDO X1DW CAD Digital Wireless Cycle Computer - Grey Logo
19 people viewed this question
Top VDO Watches Experts
Ansel Alberto
Ansel Alberto
Are you a VDO Watch Expert? Answer questions, earn points and help others
