Wat is the best method to keep back-up of data in hardisk
  • ramanandshet Jan 22, 2009
    I have 80GB hardisk now, which is nearing full now
    putting a new hardisk of 500GB and paritioning it into 250 making backup of each other is a good idea?
  • 3,940 Answers
Depending on the volume of information and how often it changes you have several options.
Small amounts of data, USB thumb Drive or CD-R
Larger amounts DVD-R or External USB HDD
There are digital tape backups for very large amounts of data.
If the data being backup up is updated/changed oftern, then a HDD or tape backup is best
Posted on Jan 22, 2009
    Sergeant:
    Champion:
  • 259 Answers
It depends on how old your computer is and how big your HD is for small amounts use DVDs and the other way i do it is have a secound hard drive in the computer so if something happens to the system it usually does not effect the second hard drive Another way is to have a large USB portable hard drive I sometimes use this as I take information to another location
  • John
    John Jan 22, 2009
    If you are going to use a 500 Gb I would not partition it as if something happen to your system it may also effect the other data on the same disk
The computer does not boot into the operating system and displays "Operating System not found."
For that problem, do this first check-up your bios setting.
Power on your PC laptop
, when screen popped up ( press F2, delete etc. ) to get into standard bios Setup you see there if your hardisk drive detected or not detected. if not detected try to open your Laptop PC ( need power off. open cover at the back of your laptop ) check-up your hardisk drive for loose power cable, data cable hardisk Some burn , noise hardisk sound ) if detected, your operating system corrupted. you need to Reinstall your operating system like windows xp, windows 7 or linux base operating system. try that Solution first.
Just let me know if not yet working your laptop PC.
Regard.
Aug 26, 2011 | Toshiba Satellite M30 Notebook
Hardisk tidak bisa terdeteksi oleh BIOS apa penyebabnya dan solusinya untuk memperbaiki ?
Hardisk tidak terdeteksi bisa di sebabkan oleh :
- Bad sektor
- Hardisk sudah lemah
- Cabel data rapuh/rusak
- Power Supply tidak mencukupi untuk keseluruhan Daya PC
langkah yg pertama :
- coba ganti cable data hardisk, dan periksa PIN Hardisk masih utuh atau tidak
- Ganti Power Supply yang Daya-nya lebih besar
- Scanning dengan hardisk lain dengan menggunakan Norton Disk Doctor untuk mengecek Bad Sektor
Mar 02, 2011 | Maxtor Hard Drive
I tried connecting my iomega prestige hardisk to my ps3(I just bought) but it is showing no icon or any notification of my hardisk being connected.What should I do to view its contents on ps3? about my...
You need to format your drive as FAT32.
If you are using Windows Vista or 7, you will have to google search for a FAT23 formatting tool. So take your data off the drive. Format the drive, put your files back on the drive and your good to go.
*************CAUTION************
There is a 4GB per file size limitation with FAT32!
Dec 14, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
Software problem
SMART is the system that monitors the health of a hard disk, in your case  it's close to complete failure. Follow immediately what that warning message says - copy all your data to some DVD's, replace the hd and reinstall.
Oct 31, 2009 | Toshiba Satellite U300-ST3091 Notebook
Start
Some missing data or corrupetd data, that is the cause, try to re-install your OS.
HP Proliant ML110 Server RAID setting
if you have the RAID 0+1 or 1 ,beacause of the mirroring ,2 disk will be the same.you should be attention ,if you transfer data on the first disk,you must boot your server with that disk.when the system boot completely then you put the second disk ,beacause of the Raid 0+1 or 1 the data of the first disk automatically write on the second disk.
Jun 24, 2009 | HP ProLiant ML110 Server
Hard disk error
Try Spinrite at grc.com
Apr 30, 2009 | Maxtor Hard Drive
Shut down computer restarted hard is not listed or doesnt read
Hi
This Danish Khan
i am gonna solve out ur problem cetrtain
first of all u must check out ur Data cable which is called as a interface data cable
which attch ur hardisk to ur motherboard.lets change it by new one.still it show same error thn
u change ur hardisk jumper setting,whish is printed on hardisk.when u takeout ur hardisk from ur computer then u will find a jumper settings of hardisk over there.
i sure that u problem will be solved out by these steps.
Jan 28, 2009 | Western Digital My Book Essential Edition...
REMOVE WRITE PROTECTION FROM EXTERNAL DRIVE
insert your memory stick or your external drive / go to My Computer / right click your drive / go to properties / under the Security tab, just check the Full Control under permission / click apply then ok
hope this helps
Nov 04, 2008 | Western Digital (WD3200JS) 320 GB Hard...
Data not copy other hardisk
Maybe your secondary hard drive is write protected due to third party software during the old installation of the system such as norton data recovery.
Hope this will be helpful to you.
Oct 26, 2007 | Apple Drive Module 180 GB ATA-100 Hard...
Computers & Internet Logo
David Payne
David Payne
