Question about Kenmore Washing Machines
Kenmore he3t model 11042922100 leaking water
Leaking water part broke inside??
jsrock516
  • 5911 Answers
SOURCE: Water Leak inside drum
That's because the water fills from around the door bellow via the dispenser. Any small water leakage will probably go unoticed because it drains into the seam in the rubber boot into the wash tub UNDER the wash basket. As it accumulates, it will eventually fill to a point where it is visible in the wash basket. It sounds like you have a water inlet valve that is failing. That's the only way water gets into the washer. It passes from the the water taps, through the inlet valve, through the flowmeter and into the dispenser. If the inlet valve is leaking, you probably have a diaphragm in the valve not closing properly, or a bad solenoid. I would recomend replacing it. To access, you will need to remove the top panel of the washer by removing the three screws in the back of the washer that hold the top panel in place. With the screws removed, the panel slides back, then off. The water inlet valve is located on the left-hand side in the rear of the washer (facing from the front) where the fill hoses connect. You will need to shut off the water supply, disconnect main power, remove the electrical connections to the solenoids, remove the any hoses and finally the mounting screw to remove. If you post back with your complete model number (located aorund the door opening), I can provide you with a part number. If you have further questions, please let me know. I hope this helps you.
Posted on Jun 16, 2008
SOURCE: Kenmore Elite HE3t model 42922
After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
Posted on Oct 02, 2008
SOURCE: Kenmore Elite HE3t Front Load Washer leak from dispenser
I was just about to call the service teck when I decided I shouldn't be this stupid and try and fix it myself.
I took the tray out and looked in with a flashlight.
Saw nothing.
Cleaned the tray and then checked the drainage hole inside the opening where the tray normally feeds the machine the soap.
I found a inside of the liquid XXXKing laundry cap partially blocking the drain.
Took it out and works fine.
Posted on Oct 29, 2009
  • 1937 Answers
SOURCE: Kenmore 80 series Model 110.28812790 - water leak inside tub
It's quite possible. First see the Sears parts list for your washer with diagrams of all major parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.28812790&pathTaken=partSearch
Then see the Whirlpool / Kenmore Service manual for these washers and check the troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Mar 27, 2010
Testimonial: "Thanks! Very helpful."
jsrock516
  • 5911 Answers
SOURCE: Water leaks into tub of Kenmore he3t
This problem is commonly attributed to either a leaking water inlet valve, or a pressure switch malfunction. The following link explains how to diagnose the problem and repair as necessary:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
Replacement parts (if required) can be purchased at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Mar 31, 2010
My HE3t Kenmore washer will not start. All the lights come on and you can select the cycle but the start button will not start the machine. We did unplug it to reset the machine but that did not wor
This may be a stupid question...but is the water turned on? Stranger things have happened!
If the drum inside doesn\'t turn, it may be an electronic issue. Hopefully the washer is under warranty. Best of luck!
Oct 09, 2014 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore elite he3t where is the lint trap?
Raise up your washer slightly or feel for 3 screws right under the front, bottom. Unscrew these and pull down - you will find the lint trap. Be prepared for water, and since the model is 2002 - immense junk too!
Pl say so if helped!!
Apr 01, 2013 | Kenmore Washing Machines
repairclinic.com
Mar 31, 2010 | Kenmore Elite 45986 Front Load Washer
My he3t washer when water goes in tub it leaks
most liklet to be a split pipe under the mashine lay it onits side and look under it at all the pipes replace the loos or split one
Oct 25, 2009 | Kenmore HE3T Washer
Saw nothing.
Sep 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have a Kenmore HE3t 2002 model washer that the buttons light up but the washer will not start when the start button is pushed. You can select any cycle ad it lights up.
There is a black plastic piece that sticks out from the machine. It is located at about
2 o'clock. You probably broke off the piece as I did with mine. If you have a wooden skewer (or something like it), stick it in and depress the button. You can glue the skewer in place.
That should fix your problem.
Aug 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
13 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
