Question about Denon AVR-2307 Receiver
Shuts off after only a couple of sec.
Receiver shuts off after only a few sec on use. Then the on button flashes red several times.
  • bigdaddy4ros Jan 22, 2009
    every thing unpluged from back except power, still shuts off
  • Anonymous May 21, 2009
    I had my Denon less than 1 year. It did the same thing. Denon fixed it saying the amps filters were weak, yes weak! I added cooling fans the **** out excess heat, so my filters stay strong not weak. But I have a 1969 Sansui with less power and gee the filters are original! Todays gear is just over-priced ****.
    Scholar:
  • 140 Answers
Your reviever is "clipping". You need electronics service from a professional repair shop.
If you are savy in the world of electronics... Most likely you have a bad cap or preamp circuits that are overdriving the amp supply.
Posted on Jan 22, 2009
I have the same problem.. I have a sony blu ray hooked up to my denon receiver and it keeps shutting off after about 2 minutes of play. Extremely frustrating. This is the second Denon I have owned an I'm not pleased with either one. Not worth the money.
Posted on Oct 11, 2009
Red light flashes 3 times
hold in on the power button for 10 sec make sure you put the cover on it good first if that dont work unplug it for a few sec then try to hold the power button down for 5- 10 sec that should work
Jan 06, 2013 | Sony Grand WEGA KDF-55WF655 36" Rear...
I just purchased a Voyager Pro. When trying to pair it with my Blackberry, I turned the device on and held the button down waiting for the LED to flash red/blue. The device turn on blue, then flashed red...
You will need to turn off your headset and then press and hold the power button until the LED starts to flash red/blue, red/blue, it will stay in this state for a few minutes.
Good luck from Headsets Direct - 800-914-7996.
Aug 08, 2011 | Plantronics Voyager PRO Bluetooth Headset
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
When Spa heater is turned on,Fan comes on but burner never lights
this is typical of a dirty flame sensor.your model does not have a thermo couple.remove sesor and clean with steel wool or fine emory cloth
May 11, 2009 | Sta Rite Sr200na - Max E Therm - Pool &...
When I turn on my receiver, it automatically turns off and the power button flashes red. Prior to shut down, the receiver display notes "Tuner Ext. In" What's the problem? It has worked p
Protection circuit turns off the unit because of critical conditions- wrong power supply voltages or one of the power amplifier channels is bad. First, visual inspect the power amp board near the heat sink for burned resistors, test outputs for a short. If there are no problem you may try to turn the unit on and you have several second before it shuts down to check power supply voltages and power amp output voltages and bias, then ... Long story you'd better take it to a repair shop or repair at ebcelectronics.com
May 09, 2009 | Denon AVR 2808Ci Receiver
Receiver shuts off when trying to play a dvd in the dvd player.
Just a hunch - what's drawing power from the two convenience outlets on the back of the receiver. They're only rated for 120watts, that is, nothing like a TV.
I doubt this has anything to do with the source you're playing (unless you have it cranked to "11"). If I understand you correctly you said turning the TV on and off causes the problem. There's a clue.
Apr 07, 2009 | Denon AVR-1803 Receiver
Thomson DT!6300-16 has stopped working
Usually to fix most odd problems on the Thomson digi box you should do a hard disk format every couple of months, select menu, setup, help,
press green button on remote
this shows advanced menu, press blue button, warning should show,
press green button to proceed
takes about 2mins you lose all recorded programs
If the problem is the box stays at red, and won't switch on,
pull the mains plug wait a few secs then push and hold the the standby
button on the main box (not remote) then insert mains plug, as soon as the
red light flashes release the standby button and very quickly press
menu and OK in that order, don't hang about, it has to be done very quickly
I had to do it several times before I got it right, this loads a preloaded firmware
and the box will come alive again the box will upload new firmware in a couple of hours.
good luck from Ron.........
Dec 04, 2008 | DTK PRM-0031I Motherboard
Flashing protector
Psgolfer ...I pretty shure you dont need that. It just needs to be reset, its in protect mode.....hold the power button down and the A n B speaker buttons down at the same time for 30 sec.....ok , Radricktip
Jan 01, 2008 | Denon AVR-887
Denon AVR-2307 Receiver Logo
874 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
