Sampo PME-42S6 42 in. HDTV-Ready Plasma Television
Problem for Sampo PME-42S6 42 in. HDTV-Ready Plasma Television
Alarm led on samsung pcb model #lj44-00025a
By ralopez_satx on Jan 22, 2009
I have a sampo plasma tv that I paid 3 grand for back in '02. The model is pme-42s6, which I'm am somewhat of a hobbyist and really don't want to trash the tv even thought I already bought a new lcd tv. When I opened the back of the unit and plugged back in the power cord, at first 3 green led's lite up then a few seconds later a red led lite up. Next to the red led is the word alarm. So I unplugged the cord, and searched on forums as to what the cause may be. One forum said it could be the ceramic fuses of which there are 3, one on the power supply board and 2 on the auxilary power supply. After hunting down these two fuses and local tv repair shops who also were unwilling to sell these, without asking a bunch of questions, I was able to get all 3 fuses for $6. I replaced all fuses plugged in power cord and again same red led lit up. So here I am asking if anyone else has had this same problem?
Best Solution
posted on Jan 22, 2009
Helpful)
lone99star
Rank: Guru
Rating: 88%, 232 votes
Hi ralopez satx,
I have provided a link to the service manual, with a multimeter you should be able to track down the problem. Let me know if I can help and please rate this solution. Lone99star in Texas also
Comments:
Jan 22, 2009
- Sorry forgot to add the link, here it is.
http://support.gateway.com/s/Manuals/HomeTheater/GTW-P42M203.pdf
Was this helpful?
Yes
No
Solution #2
posted on Feb 18, 2009
Very Helpful)
supageek
Rank: Apprentice
Rating: 100%, 1 votes
Ok this problem was alot more simple than i thought, it's the relays that you hear clicking. I took out my board and took it to my friends shop where he fixes plasmas and lcds etc.... We tested all the capacitors on the board... tested good Then tested the two transistors i saw someone speak about chaning in another post.. tested good Now the last thing i tested were the two relays on the board you have to take them out the board to test them here's how. Get a 9 volt battery and a multimeter that beeps when it detects continuity. Using the 9 volt battery put power on the coil end of the relay this is the end with the pins directly opposite each other, now you should hear it click leave the power on it then using the multi meter test the pins on the other side of the relay if it beeps it's good, if not bad. I purchased both relays from www.mouserelectronics.com the part # is JW1AFSN-DC5V they only cost $2.58 each it's best to change both even if one tests ok.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Apr 06, 2009
Not Rated)
mercompany
Rank: Guide
Rating: 100%, 6 votes
We have identified a common problems with theses sets manufactured by, SVA, Gateway, Viewsonic, Sampo and a few other brands. They all have a Samsung power supply board (LJ44-00025A), which has cause these units to lose power. There is a easy fix, replace the power board. But you ask why should we? That's the right question. If these boards all have the ability to fail with various parts and within various displays. This has to be a defective part. As of now, there is no recall on this part. Therefore, we are generating a list of customers, who own these displays and are requesting a refund for previously purchased parts or a replacement part at no cost to the customer. We are in the prelimary stages, so please be patient with our efforts.
If have indentified your unit is salvage by an power issue an wish to purchase the indentified part (LJ44-00025A, we recommend you purchase from http://www.adc-ast.com/.
We cannot guarantee that any monies will be refunded by this claim.
Thanks
Shawn Moffett
Samsung Claims Administrator
If you are interested in participating in this claim, please email the requested below to samsung.lj4400025a@yahoo.com
<NAME>
<ADDRESS>
<PHONE>
<EMAIL>
<MODEL>
Was this helpful?
Yes
No
Solution #4
posted on Feb 07, 2009
Not Rated)
Chaallenor8D
Rank: Apprentice
Rating: 100%, 2 votes
You need a power supply board Fix it for $139.00 can do it your self unplugg the unit put keep the new fuses i have a phone # they have the board gatway & samsung will not gave you the parts.
Was this helpful?
Yes
No
Solution #5
Not Rated)
Abrsvcs
Rank: Guru  Televisions & Videos  Expert
Rating: 88%, 1818 votes
When the set is first turned on, there is a startup sequence that occurs. There are problem detection circuits throughout the set that once trigered, cause the set to shutdown. What you are seeing is the set entering its protect mode. There is an internal problem that is causing this shutdown. Were there any problem symptoms prior to this shutdown problem? That may provide a clue to the problem. Plasma sets don't usually just stop. There is the possibility that the power supply is defective. Since it is what is called a "switch mode" supply, defective capacitors can prevent the supply from starting up properly. Without seeing the unit and taking measurements inside, it will be difficult if not impossible to resolve this remotely. I would suggest that you invest in a detailed repair estimate from a local service shop. This should not cost more than about $50 or so. Post the estimate details here and we should be able to guide you through the actual repair.
Good luck.
Dan
Was this helpful?
Yes
No
Popular Solutions for Sampo PME-42S6 42 in.
Questions and Unsolved Problems for Sampo PME-42S6 42 in.
Do you recommend Sampo PME-42S6 42 in. HDTV-Ready Plasma Television?
Answer
Answer
my sampo PME-42S6 ha trouble powering on. It will start (blue screen and hour glass appear the turns... (More)
Answer
we have had our tv 4 about 7 years and over the past few months it has been going red! basically if... (More)
Answer
The T.V has all sorts of pink lines and other distortions on the screen if you hit the side of it,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sampo PME-42S6 42 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 733
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
