Question about Beam Vacuums
I have a beam adjustable wand with an attachment on it meant for hardwood, or linolium floors. The wand is broken so I would like to take the attachment off and put it on a new wand. How do I get t
The end is grey, there is no screw or push button release.
reddevil6
  • 1673 Answers
SOURCE: Cannot disconnect the wand from the power cleaner
Looks like you will have to replace the quick disconnect asm. part # 38646086, you should be able to order this thru a shop that repairs Hoovers. If this is less then 1 year, then it is under warranty. You can call Hoover's 1-800 #. should be in your owner manual and on the metal tag on the cannister to find out where you can get part.
Posted on Feb 17, 2008
  • 97 Answers
SOURCE: Nedd power head wand for Fantom Model BPSRLC51
the best bet would be to look on ebay. the fantom line was discontinued
Posted on Jul 29, 2009
  • 4 Answers
SOURCE: vaccuum shuts off when i turn the brush off to use
in the crease where the vacuum handle meets the vacuume the cord may be getting pinched off so check that first and if it is make sure there is no damage to the cord so that you don't get electrocuted.
Posted on Aug 27, 2009
renevacdoc
  • 84 Answers
SOURCE: can we use the bissell dirt lifter powerbrush on
Yes, it won't harm it at all.
Posted on Nov 15, 2009
  • 264 Answers
SOURCE: White & grey model Roomba is moving much
You need to adjust the "Brush Height String" The new battery is a bit heavier than the old ( by 10 ounces if you got the new battery) dis assemble the roomba and you will see a string attached to a screw which allows the brushes to rise and fall with different surfaces. Move the string 1/4 " and re tighten the screw. Good to go!
Posted on Mar 27, 2010
Canister vacuum Sears model 116.59229210. The suction is coming through the vac for the hardwood floor setting, but the light on the power head will not work and the roller is not turning. I have...
Kenmore canisters are famous for melting the connection between the hose handle and the upper wand. They also sometimes melt between the lower wand and the power nozzle neck. Take it to your local vacuum repair center and get a diagnosis.
Dec 19, 2014 | Vacuums
Why won't my floor attachment attach to Dyson wand
Contact Dyson regarding the fault.
There is a 5 year warranty on parts their customer service is amazing . They may send you a part to fit if faulty .
Sep 18, 2014 | Dyson DC25 All Floors Bagless Upright...
My kenmore progressive canister vacuum turns on only if the hose is attached to the floorwand. It seems that the canister motor is not working because I can't hear anything coming from the caniste
If the floor wand is powered, there may be an electrical connection that is broken when the wand is disconnected. This is part of the design, not necessarily a fault
Jan 05, 2013 | Vacuums
How do I remove a hardwood floor polish safely from a laminate floor
www.hard-wood-floor-cleaners.com
and select the best chemicals and use for your hardwood polish laminate flooring.
God bless you
Aug 02, 2012 | Vacuums
White & grey model Roomba is moving much slower on carpet since I replaced battery and filter, but moves normal speed on linolium. How do I fix this?
Mar 19, 2010 | Roomba Robotic Floor Bagless Vacuum
Need Hoover cannister vacuum floor brush & filter bags
Hello, if you GOOgle Hoover you will be able to find your nearest Hoover center, they will then be able to help you with parts and bags. We did this last year and it was emensely helpful. Hope this helps.
Nov 04, 2009 | Vacuums
On/Off switch.
because floor means for lanolium it may have a sensor that detects carpet or linolium
Feb 11, 2008 | Kenmore 35821 Vacuum
Rainbow e series vaccum/scubber
If you are talking about the hard wood floor brush you hook it at the end of the one slightly bent wand. Look at the end of the brush that you would hook to the wand. In the circle opening there are two slits. On the end of the wand there are two bumps. You need to line them up, push the brush on then twist it around so it stays on. then you attach the straight wand to that and the other slightly bent wand at the other end of the straight one. It will go like this Wet hose, slightly bent wand, straight wand, slightly bent wand, and floor brush. I hope I helped. Leave the basin empty. put your water or cleaner on the floor scrub it around then turn machine on and suck it up.
Nov 30, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
32 people viewed this question
Top Beam Vacuums Experts
cazo06
Level 1 Expert
Beamvacman
Level 1 Expert
Thatvacguy.com
Are you a Beam Vacuum Expert? Answer questions, earn points and help others
