Question about Kenmore 12502 Top Load Washer
The washing machine wont spin or wash or anything. it stopped in mid cycle. what should i do?
  • adeleaoyam Feb 04, 2009
    Right before the rinse cycle, the machine stopped and now the machine is filled with soapy water and the dial won't move into the spin cycle.
    Scholar:
  • 140 Answers
Sounds like your lid switch is not working properly.
Posted on Jan 22, 2009
SOURCE: Faulty Hotpoint WMA76 washing machine
it may be 1) a connection loose at the motor 2) motor brushes are worn out 3) a pcb fault check in that order.
Posted on Feb 16, 2008
appldoctom
  • 311 Answers
SOURCE: my washing machine wont drain water
if waser wont drain it cant spin and some contorl boards get confused about that situation.check your pump,is it clear will it funktion.other wise i dont know a lot about this proticular machine god bless,tom
Posted on Jan 01, 2009
  • 135 Answers
SOURCE: Zunussi zwf1437w Keeps stopping during programmes
This sounds like a drainage problem. First thing is to check the filter behind the flap on front of machine.
Please post back your findings for further assistance.
Thankyou for using Fixya.
Posted on Jan 23, 2009
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
dblred
  • 68 Answers
SOURCE: Washing machine stops mid-cycle, water doesn't drain
Sounds like you have a bad lid switch, or the plastic plunger on the lid that engages the lid switch is broke. if the plunger is broke, it is cheap, and only 2 screws to remove and put new one on. if that is not broke, check the lid switch. This model is a lid switch, and lid lock in one. You can test it before replacing it if you have a meter. you need to hinge the lid up to check and replace the lid switch. use a putty knife, on each side between the top and top of the front panel. slide the putty knife in one side, it will hit a bracket if your in the right spot. press in, and lift on that side of the top. do the same on other side, just don't let go of the first side or it will latch again. then swing the top back, the back side is on hinges. the lid switch is on the right side attached to the top. unplug washer, remove the 2 wires on the switch and check continuity. there should be continuity, or "open" when the lid is closed, and no continuity, or "closed" when you open the lid. if it is "closed" even when lid is closed, replace the lid switch. let me know if you have any further questions, shane.
Posted on Sep 12, 2009
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Forty cycle takes some water in then stops
    Beko WM5100W Washing machine wash/spin problem ...
    ? 3:59
    https://www.youtube.com/watch?v=rih6H1cpu9Q
    Jun 12, 2012 - Uploaded by ilona ilona
    problem in washing cycle. fast spin for few seconds and cut off .... I have same machine, it starts up fills half way with water then stops :'.
    Jan 10, 2016 | Beko Wm & Wma Models Washing Machine Motor...
    Doesn't work. Why does it stop mid-cycle?
    washing machine stopped mid cycle, won't drain : DIY - Reddit
    https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
    RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
    Troubleshoot - washer stops mid cycle, won't drain or spin ...
    ? 1:58
    https://www.youtube.com/watch?v=6Gc0ZgLD6a4
    Jun 20, 2012 - Uploaded by searspartsdirect
    Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
    Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
    Why does my washer stop half way through cycle - Ken
    Dec 18, 2015 | Washing Machines
    Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
    Repair needed on Maytag Neptune washer - Home Improvement ...
    www.dslreports.com > ... > Home Improvement
    DSLReports
    Aug 5, 2007 - 19 posts - ‎8 authors
    Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
    How To Fix A Washing Machine That Is Not Spinning or ...
    removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
    May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
    Maytag Washer Troubleshooting - YouTube
    Dec 02, 2015 | Maytag Washing Machines
    GE WBSE3120 Washer stops mid cycle
    if it makes a grinding sound when in spin this is the tub seals or bearing and basically you'll have to replace the washer.very common with this ge washer,not one of ge's best product,also why it stops mid cycle could be anything,this washer has a computer board biult on top of the motor that also failed,if your having all these issues i think that washer sold for like 500 dollars,it would cost more just to repair it,i wouldn't put 5 cents into it,do yourself a favor and get a new washer.
    Dec 04, 2017 | GE Washing Machines
    Water pumping out at a trickle. stops in mid cycle
    The timer seems to have gone out on you. Try to manually set it on spin and if that works then the timer is out.
    Jun 30, 2009 | General Electric WSSH300G Front Load...
    Jan 23, 2009 | Zanussi ZWF1430W Front Load Washer
    My washing machine wont drain water
    Jan 01, 2009 | Candy Washing Machines
    KitchenAid Washing machine stops mid-cycle and stays stopped
    sounds like you need to replace your lid switch asssy part number 285671, unit not recognizing the door closed so for safetyreasons stops after first rinse and wont drain/spin. your tripping the switch by bangin on it
    May 12, 2008 | KitchenAid KHWS01PWH Global Horizontal...
    Kenmore 12502 Top Load Washer Logo
    Sal De
    fordexpert
    Whirlpool
    Whirlpool
