Question about Frigidaire 24 in. GLDB957A - Multiple Color Energy Star® Built-in Dishwasher
Lower spray arm heat shields fell off
The two metal clips (heat shields?) fell off the end off the lower spray arm. Solution?
5 Suggested Answers
SOURCE: Dishwasher upper arm does not spray
possible ball valve problem
Posted on Jan 03, 2009
SOURCE: broken nozzle and upper spray arm
Thanks for the help. Like the other guy said the "ninga star" thing unscrews and using the plastic part inside I just pop the spray arm back on. Screw it back and it works again.
Posted on Aug 29, 2009
SOURCE: Upper spray arm fell off, can not repair nor find part
I had the same problem, but was able to find the replacement part at http://www.partselect.com/shipping.aspx. My old arm also has the number 1544681 on it. If needed use model number PLD2855RFC1 to locate the same part. Good luck!
Posted on Oct 11, 2009
  • 401 Answers
SOURCE: ther top spray arm fell off the dishwasher
THERE IS PROBABLY A BIG PLASTIC NUT THAT IS STILL SCREWED ON THE UPPER TUB.THIS WILL UNSCREW AND WILL COME AS ONE PIECE IN A KIT.
Posted on Mar 01, 2010
Lower spray arm dislodged during wash cycle
Hello Megan Quintas,
I have had the bottoms of the Frigidaire DISHWASHER rotted out AND their center-shaft NEVER LOST IT'S vertical alignment...
So my personal opinion...
You are good once you replace your defective spray arm..
Put your model+make+spray+arm
or better yet the ORIGINAL PART NUMBER to get three estimates...
Good luck, happy hunting!!
- Some example parts houses:
Sears (priciest... but improving)
appliancepartspros.com
partsselect.com
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
May 12, 2016 | Frigidaire Dishwashers
Top water outlet doesn't spin
Not sure of the vintage of your Maytag dishwasher, but this may work for yours.
1. Remove the upper rack by releasing the stop clips on the ends of the rack rail; push the ends of the clips towards center of machine - this may require the help of a small screwdriver.
2. The upper spray arm assembly is mounted to the ceiling of the wash chamber by large (2" diameter) fluted nut that butts right against the ceiling sheet metal. Simply remove that nut by hand, and the whole assembly will come out.
3. Looking into the top of center feed hole, you'll see 4 plastic clip ends holding the 3 pieces together. Use a 1/4# socket or nutdriver to press all 4 clips inward until they come free.
4. The spray arm halves are welded together, so you'll have to clean out any clogs using a pointy tool and some water flushing.
5. Reassembly is the reverse order.
- Mike
Apr 17, 2014 | Maytag Dishwashers
Maytag Dishwasher-MDBH945AWW
About the only things that move in the cabinet other than the water pump is the spray arms. The lower arm should be screwed down fairly tightly (plastic screw), but the upper arm is held in place with a plastic friction plug--it tends to wobble more. Spin both arms by hand to see if either hits something (have the drawers in). The lower arm has metal clips on the ends which may be coming loose. They are just clipped onto the arm edges. Hope this helps!
Apr 06, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Upper rinse arm fell off. How does it reattach?
usually it will clip to the basket that holds cups and the like, and engages with the water outlet when the basket is slid into position. Some spray arms have a locking ring that, when the spray bar is held in place, rotates clockwise (if viewed from underneath) and locks the spraybar in place.
Nov 06, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Lower ball joint fell out and pulled out the axle
replace the lower control arm, the axle just pops in and out of the trans, it is held in by an internal spring clip on the axle end.
Sep 10, 2009 | 1997 Honda Accord
Spray arms clogged
Top: Remove the upper tray by releasing the clips on the ends of the runners. (Squeeze the top of the clip and pull upwards). Remove the spray arm by holding the round plastic clip that holds the arm and turning the arm. It will unscrew.
Bottom: Grab spray arm in centre and pull sharply upwards to unclip.
Wash in warm water and solvent-free detergent.
Jun 11, 2009 | Samsung Dishwashers
50Hz noise appears at the end of the disc
the needle or arm is going bad, try this put a penny on the head and play, any difference? we used to do this as kids
Oct 02, 2008 | Sony PS-LX350H Turntable
How to remove Sprayer Arms
metal sleeves at the end of the lower spray arm?? dont remove them they only protect from hitting against heate and melting. should be a center thumbscrew in spray arm loosen that nut and should come right out, pokin with wire or toothpik willwill clear joles but you gotta remoe the debris from the arm other wise first run will shoot right back nto holes
Feb 22, 2008 | Jet Tech Systems STEALTH Dishwasher
Need to remove wash module
a screw fell into the wash moduel. How do i remove the lower spray arm, ect Thank's
Feb 08, 2008 | Dishwashers
DISASTER! PLEASE HELP. WOKE UP THIS MORNING & DISHWASHER MELTED!!!
Amsanta, sounds like something got hung up on the heating element, stopped the lower spray arm and things started to melt. The lower spray arm, part number, 154414101 is easy to change out. There is also a lower spray arm support 154294101, don't know if you will need that. I believe on your model the lower spray arm just snaps on. There is a tab on the filter screen that will rotate to unlock and the filter screen will lift out. Now the lower spray arm support is accessable. If it's less than a year old, you may be able to get it fixed under warranty. Catriver.
Jun 09, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Open Questions:
Frigidaire 24 in. GLDB957A - Multiple Color Energy Star® Built-in Dishwasher Logo
24 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
