Question about E-Machines eMachines Desktop PC
My computer won't boot up
I was using my computer but the next time I went on all I got was A disk read error occurred Press CTRL+ALT+DEL to restart. It says Master disk capability - none///Slave Disk capability - disabled.
  • 1 more comment
  • Colleen Schneider
    Colleen Schneider Jan 22, 2009
    I need free help I can't afford to take it back to the repair shop.
  • Colleen Schneider
    Ok guys I rebooted and held down the del key so now I have a Phoenix bios screen what next.
  • GOODHACK3R May 11, 2010
    Ok. First is it possible for you to open up your PC( are you capable) For maybe the IDE or SATA cables may have come off, are loose, or have been incorrectly wired.
  • 2,229 Answers
What it is telling you is that it can't read your hard drive. When I get this type of error, I try re-booting the system several times. I then push whatever key it is that your computer needs to get into the setup mode--to see if the system is set up correctly (with a hard drive identified). While in the setup, I choose the option to reset using setup defaults.
I then boot from a startup CD (usually the Windows CD) and see if it can find the hard drive. If not, I'm afraid you'll have to replace the hard drive--and I would hope that you've been backing up your data.
Posted on Jan 22, 2009
  • 15,935 Answers
Your hard drive has "crashed".
Sometimes removing it, placing it in a freezer 2 hrs, then letting it reach room tem, then installing again frees up the platen or mechanical arm, but it only works 30% or less of the times I have done it.
If you do get it to work, save any valuable data immediately... it is on its way out!.
This is a VERY typical problem with eMachines, as they use 100% refurb parts to make a certain pricepoint.
CLICK HERE for options you can try to save your drive. Depending on your abilities, some BIOS settings you may be able to change to disable error checking, or disabling IDE Master etc.
THIS PAGE is more brand-specific and may point you in a good direction.
Thank you for using FiXyA, a FiXyA rating is appreciated.
  • blueextc3221
    blueextc3221 Jan 22, 2009
    I've tried the following (and didn't work), but these are still
    > strongly recommended if you are having this problem:
    > - Reset your BIOS to Default Settings
    > - Put in an 2K/XP/2K3 CD and enter recovery mode and run the
    > following:
    > - FIXMBR
    > - FIXBOOT
    > - CHKDSK /R /P
    > Now, X hours of my weekend of free time, and still no luck. But I was
    > determined, and this was the answer to my problem...
    > BIOS! My Hard Drive was set to Auto Detect. I can however,set my hard
    > drive to different modes. It was on Auto, so I changed it to LBA. I
    > restarted my computer, and BAM! It continued to load passed the BIOS.
    > I restarted a few times (just to check) and I was rolling! So
    > hopefully, this will help about 1% of the people who have this
    > problem. Good luck to y'all!
    This post may be of help as well. You definately have a boot sector problem. By taking the drives off of cable select, and assigning a boot order, you may circumvent the error.
  • 3,940 Answers
You are having a classic indication of a hard drive failure.
Boot to the BIOS (System Setup) Usually F2, or DEL at boot) and see if the hard drive is seen by system setup (most likely it will not be seen)
If HDD is not seen, the power off, unplug and reseat the power and data cables to the drive. If still not seen, replace the HDD
Doesnt startup,but rather displays "A disk read error occurred.Press Ctrl+Alt+Del",it does that again and again
maybe a usb device plugged? if not try in bios\boot sequence to set cdrom - hd - usbdev. then try to boot with the puppy sturdust linux cd. if it work is just the internal hd; format it and reinstall. hope it help bye
Nov 16, 2013 | Acer Aspire one D270-1375 Intel Atom N2600...
Disk read error occurred, press ctrl+alt+del to restart, but it just takes me . ... press ctrl alt del to restart" problem, HOW TO SOLVE
Have you checked your bios to see what the system is configured to boot from first? Make sure your hard drive is the first boot device in the list.
Oct 28, 2013 | eMachines D620 Laptop
"A disk read error occurred Press Ctrl+Alt+Del to
Most likely the hard drive is failing, run diagnostics on the hard drive if you have a resource CD. Or you can download them from support.dell.com
Jul 21, 2011 | Dell Latitude C810 Notebook
Not booting. "disk read error occurred"
This means you HDD is either corrupt or faulty, try downloading a copy of Hirens BCD to try to access the HDD (or use and external HDD enclosure) and if you can, put it back in the laptop, if not reformat it and reinstall windows.
Aug 11, 2009 | Acer TravelMate 4200 Notebook
A Disk Read Error Occured. Press CTRL+ALT+DEL to restart
Since the bios hard drive test passed , ujr hard drive is ok and mostly all ur data is ok . Only windows went corrupt (normally it doest when u turn off that way ) reinstall it dont use the recovery disks , but use a windows installation cd to re-install windows , but take care that when u install ,install on a different partition and remember to take the option leave the current partition intact without changes , so that none of ur data is disturbed.
Jul 21, 2008 | Compaq Presario R3000 Notebook
Restart Error: "A disk read error occured Press Ctrl+Alt+Del to restart"
Turn the pwr off for 5 minutes
turn the pwr on and tap the F8 or press the F8, 8 times
and select safe mode and do a system restore
Jun 01, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Jan 03, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
233 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
