Question about Matrix Exercise & Fitness
Matrix treadmill how to change channels on tv
How to change channels on tv
Life of running belt in matrix treadmill
all depende how frequently you LUBE the deck belt, may you have a worn Deck. see the instr. manual and see the video.
God bless you
Aug 05, 2012 | Matrix MXT5 Treadmill
My Matrix T3X treadmill display doesn't work
tight the ribbon cable keypad, clean it +tight the wires connector from display board vs lower board and clean it.
2) adjust the reed switch, clean it and tight the wires connector.
see the diagram.
God bless you
Jul 19, 2012 | Matrix T3Xi Treadmill
My matrix MX-T5x start running and stop in seconds. With the error code E7. What is the problem ?
By E7 it means Speed sensor feedback missing. You have to check the speed sensor mounted near the motor pully. Remove the speed sensor and clean it well Then refix it then check the tread mill by powering ON. If then also the problem remains the same , You have to replace the speed sensor.
ok
Aug 02, 2011 | Matrix MXT5 Treadmill
I have a panasonic 48 inch plasma TV which has developed a fault. There is a yellow line down the centre of the screen on all channels. Is the TV knackered?
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help in solving the problem.....
Jun 15, 2011 | Televison & Video
Hi, i have an Error signal " 2 - 9 F " the treadmill stops and cant run anymore. thanks a lot!
I have a Matrix Treadmill t4. An error of "E1 and E3" occurs when it is started? Can you tell me the solution?
Mar 15, 2011 | Matrix T3Xi Treadmill
My tv stays on favorite channel menu and I cant get it to change to video. The remote only powers on the unit and wont change anything or turn off. The menu on the tv wont help. Please help
Sounds like you have a stuck button on the front of the TV or a bad protection diode in the keypad matrix that will need to be looked at by a technician.
Jul 23, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Exercise & Fitness Logo
Top Matrix Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
greg kinsley
Are you a Matrix Exercise and Fitnes Expert? Answer questions, earn points and help others
