Question about Kenmore 73952 Gas Dryer
Dryer won't heat up
Kenmore gas dry model 110 72602 won't heat up. how do I check the ignitor, where is it located? could this be the problem
    Novelist:
  • 101 Answers
It could be the problem, you are definitely on the right track. There are a lot of things though that could cause a dryer to not heat. I try to give the most common reasons as it is hard to determine without hooking up a voltage meter to the parts. One thing is that your vents may be clogged up somewhere between the dryer and the outside. A lot of people don't want to believe that the problem is that, but it is common and if that is the problem better to be that then something wrong with the dryer. Anyway, check outside where the vent is and feel if the air coming out is strong. If it's not that may be the issue.
Next, if the air is good, open up the bottom panel so you can watch the dryer working. Watch and see if the ignitor is coming on. You may just have a problem with the thermostat which tells the dryer when to shut off the heat when the temp in the drum has reached the max. It should go up to about 110 degrees and then turn off, when it gets down to about 70 or so it will come back on. That is the job of the thermostat, to regulate the temp. If it does not work though it just won't heat.
If your ignitor does come on and you see the flame and it goes right off then you need to replace the thermostat. If it doesn't come on at all though you will need a new ignitor seloniod. Let me know if you have any other questions and let me know if this was helpful for you. It might be wise to have a tech come out and fix it too as some of those things can become quite a pain to fix. Gas dryers are a lot more complicated then electric. Good luck and glad to help.
Posted on Jan 22, 2009
Kenmore elite gas dryer he3 model 110.95862402 won't heat
Since it is gas, you need to find out if the ignitor is coming on to ignite the gas (if you have gas getting to the burners). If you have gas, but the ignitor is not coming on, then you have to determine if the electronic contol is sending a signal for the ignitor to ignite. The most likely cause is the ignitor
Jan 16, 2012 | Kenmore Dryers
I have a Kenmore gas dryer Model 74812200. It is no longer heating up. When I turn it on, I hear a clicking sound for about 30 seconds then it goes off. Then about a minute later I hear the clicking sound...
You would not hear the click if the ignitor was bad. It won't click until the flame sensor get heated up by the ignitor. So that tells me the thermal fuse ain't melted. I would say them coils on the gas valve are the problem. themobilian_2943.jpg
Aug 30, 2011 | Kenmore 74812 Gas Dryer
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
My Kenmore 300 series gas dryer stopped drying with heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 20, 2010 | Dryers
I have Kenmore Elite Electric Dryer Model 110 63932101 and it is taking like 80 min to dry.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 20, 2010 | Kenmore 64952 Electric Dryer
Kenmore dryer, the dry runs, but does not heat
heatman101
Jun 11, 2010 | Kenmore 63942 Dryer
Kenmore dryer thats not drying
heatman101
Jun 01, 2010 | Dryers
Wet and cold clothes after cycle
heatman101
May 31, 2010 | Kenmore 72062 Gas Dryer
Wont heat up
heatman101
May 31, 2010 | Kenmore 75962 Gas Dryer
It takes 2 cycles to get load to dry. What should I do?
heatman101
May 20, 2010 | Kenmore 73952 Gas Dryer
Kenmore 73952 Gas Dryer Logo
213 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
