Question about Lasko 5520 Ceramic Compact Heater
I have a lasko 5520 oscillating heater that will not power on. is there some switch or fuse that may be on the inside
  • 59 Answers
There is a tip over swith that could be faulty
Posted on Jan 22, 2009
My Lasko 5307 oscillating ceramic tower simply does not "turn on" .... what's up?
Electricity is not suitable for use by you....
Check power point with another appliance. Check heater switch, high temp, etc....
Oct 16, 2013 | Lasko 5307 Oscillating Ceramic Tower...
The heater is less than two years old and it blows cold air, and not heat!
Make sure with a multimeter that the heater is having the continuity and the switch is contacting correctly . If so the heater must work.
If not the coil can be faulty or the switch can be defective.
Sep 28, 2010 | Lasko 5520 Ceramic Compact Heater
My Lasko E20739 blower fan works but does not oscillate. The small 120V motor that does the oscillating seems to be the problem.Please confirm and advise where can I buy s replacement motor Peter
i don't think it's going to be a motor issue, these fans have a round plastic gear in them that commonly go bad. remove the bottom cover by removing (5) phillips head screws, then unwind the power cord from the cord holder rembering the path, then remove the (3) large phillips screws, then just slide the base of the fan off and the gear is right there. if the gear is bad, you'll know cause there'll be pieces of plastic everywhere and the teeth on the gear will be rounded off. have fun. oh, for the part, i suggest contacting lasko at www.laskoproducts.com
Aug 21, 2010 | Lasko Heating & Cooling
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
How to reset Tilt Switch in LASKO Ceramic Heater 5540?
I don't have manual, it's a borrowed one. Several days later, I pushed the botton at the bottom several times, looks it solved my problem.
Feb 08, 2009 | Lasko 5540 Ceramic Compact Heater
Mod # 5532 When moved or knocked over will not turn off
Your safety shut off switch is bad. Usually it is not worth it to replace it, and honestly I have not found a parts store online or in the city that sells the part
Feb 08, 2009 | Lasko 5520 Ceramic Compact Heater
Heater won't get hot
I went on several websites until I located the company. Recieved a call from them to day and they are sendin me a manual.
Dec 15, 2008 | Lasko 5520 Ceramic Compact Heater
Absolutely no power to my Lasko 5540 heater
There is a thermal fuse in line with the power chord. Open your heater housing up and trace the power cord. It is located inside a white teflon sleeve. Locate the fuse and either replace it with the same value. Appliance repair shops will have them in stock. If you want heat right away, cut out the fuse and jumper the 2 wires together. Instant heat.
Nov 21, 2008 | Lasko 5540 Ceramic Compact Heater
Lasko 5520 Ceramic Compact Heater Logo
404 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
