Question about GE Profile Advantium SCB2001KSS Stainless Steel Electric Single Oven
GE Advantium Microwave PSB220INSS control panel issue
My control panel lights up with message without pushing any of the buttons. this has even happened while passing near the oven without touching any part of the oven and has happened when touching the metal around the LCD panel without pressing any of the control buttons
  • 1314 Answers
SOURCE: Built in GE wall oven
why are you trying to remove the panel are you talkin about the control panel
Posted on Dec 29, 2007
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
Posted on Mar 28, 2009
SOURCE: ge profile advantium 120, scb1001 oven, display panel out
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
Posted on Apr 06, 2009
Turned off breaker for 30 seconds. Display returned.
Posted on Jan 20, 2010
  • 3740 Answers
SOURCE: getting F7 code on a ge profile performance oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Posted on Mar 09, 2010
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    My GE Profile Advantium Microwave Oven runs (and heats) continuously. The only way to stop it from running is to open the door.
    Sounds like a defective door interlock switch or a broken switch mount. If it's not a problem with the door switch or door switch mount you will need to replace the magnetron and the touch pad as well.This will fix your issue.
    Please get back to us if you have further query else please accept the suggestion.
    Thank you for contacting
    Jul 27, 2011 | GE SCB2001FSS Advantium Electric Single...
    GE Advantium stopped working completely...indicates no power but it is on.
    It may be that your high voltage diode or capacitor has shorted.
    The fuse is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
    There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
    At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
    Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
    (if it is NOT shorted, it's probably fine)
    (continuity can be good even though it is bad!)
    To check the high voltage parts, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
    You can download GE owner's manuals and installation instructions here.
    Dec 16, 2008 | GE Profile Advantium SCB2001KSS Stainless...
    Hi my GE Advantium oven is displaying an error message and beeping. The Error is F3. Could you please help me with this.
    Nov 02, 2008 | GE ZSC2001FSS Advantium Electric Single...
    GE Advantium Microwave portion not working
    There is a fuse for the Hi voltage transformer and the magnetron tube. You have to take the cover off to access the fuse.
    Sep 02, 2017 | GE ZSC2001FSS Advantium Electric Single...
    Advantium zsc2001fss no power no lights
    I have same unit...power outage made unit come back on and it then requested user to set the clock, but the display shows the hours but won't accept the pushputton to lock it in. I had to look at the control panel today to see how hard it would be to replace.
    To take off the front vent panel: first take microwave out of the built-in space, disconnecting the power cord. Then the top outer metal skin can be unscrewed and removed, which exposes the screws that hold in the front top vent and the control panel in place.
    Feb 21, 2008 | GE ZSC2001FSS Advantium Electric Single...
    F3 Error
    This is due to a Defective control board..You have to get it replaced..
    Oct 15, 2007 | GE Profile Advantium SCB2001KSS Stainless...
    Unit has no power.
    I know what you mean. I was cooking with this appliance tonight and suddenly it displayed an f-3 code. My advantium oven is less than 8 months old. Not sure how this happened or how to fix the problem. In order to sleep tonight (the constant beeping) I had to shut power off at the breaker pannel. Is this representative of the the type of quality that GE stands for???? I am sooo frustrated. I cook with my advantium oven all the time and love the dual abilities of this appliance. Like I said this is brand new and to have the f-3 code which apparently (from what I read) is a failed key pad. I am very dissapointed and am begining to think about pulling my stock from this company!
    Aug 22, 2007 | GE ZSC2001FSS Advantium Electric Single...
    GE Profile Advantium SCB2001KSS Stainless Steel Electric Single Oven Logo
    123 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
