Cant get fuel
My heater worked great last year now it seams its not getting any fuel
Well for starters, what kind of heater. what kind of fuel, and what exactley is the problem? how did you come to the conclusion that you do not have fuel?
Posted on Jan 22, 2009
I have a Hayward HD100ID natural gas heater that I purchased last year. It's been working great up until yesterday. Today, when I plug it in and turn thermostat to max, nothing happens. I don't...
Since this heater was only purchased last year, if it is faulty they should cover it under warrantee. If you call Hayward technical support they should be able to help you figure out what the next step is. I hope this helps.
Jul 23, 2011 | Hayward 100,000 BTU Pool Heater H100ID1 -...
HEATER CORE REPLACEMENT
I have very little heat in my '97 Dakota, but I did last year too. I haven't backwashed my heater core this year, which worked great last year and got me through the entire winter season. If you haven't done that to see if it will help, I would defenitely do it. It takes like 15 minutes total time to do it. This is far easier than pulling the dash out and replacing the heater core. Hope that would help, if not sorry. Changing the heater core is one problem I don't even want to ask my mechanic to tackle and he is a very great friend of mine.
Dec 14, 2010 | 1997 Dodge Dakota
My Dyna Glo heater forced air heater worked great last year. I run it on Diesel and ran it empty before putting it away for the summer. Went to fire it up and it wouldn't work. Replaced all of the cracked...
the filter in the tank line is partially clogged with gel from useing diesel fuel you should really use a anti gel agent when running a sulphur type fuel in a unit designed for white gas/ keosene
Jan 20, 2010 | Kitchen Ranges
I have a 4 year old Kenmore top freezer refrigerator. the defrost function is malfunctioning. the freezer frosts up, clogs the air vents, the fan runs nonstop, and everything melts. I've turned off the...
Should be covered alright. Sounds like the defrost therostat is open. Is you defrost heater coming on. It doesn't seam like it is. As you frig runs it's cycle it will turn off the compressor every hour or so and the timer will turn on the heater in your freezer to defrost. Do you feel this heater coming on. If you therostate mounted on the defrost ellement fails to close then your heater will not come on and ice will build up in you freezer. These thermostates seam to be failing more and more these days. I've replaced mine 3 times over the last few years.
Jul 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
96 Sierra died while running and wont start, i smell gas when i try. The truck turns over fine, when it runs it idles great, and the injectors were redone last year.
there must be some leak on the fuel lines, might as well change the sparkplugs to have an efficient fuel burning, you may be flooding too much fuel. hope this helps
Jul 09, 2009 | GMC Sierra 1500 Cars & Trucks
Heavy smell
This is a fuel delivery problem. Look for:
  1. always start troubleshooting fuel problems on a Hot Surface Ignitor heater by checking the pump pressure!
  2. restricted fuel filter
  3. air leak
  4. restricted nozzle
Troubleshooting tips
Nov 17, 2008 | Reddy R60A Utility Heater
Charmglow patio heater
Looks like the knob or the contacts are faulty.
Nov 07, 2008 | Williams 2509612 Ceramic Mid-Size Heater
My Ford Ranger
my 86 ranger heater core was behind the glove box, not to hard to replace, remove two hoses and access cover.
speedocable connects behind instrument panel and to the side of transmission. (electrical ones are easier, just a small component on the side of trans.)
i think you mean FUEL gauge? there is a sending unit inside the fuel tank (sometimes fuel level sending unit is combined with the fuel pump) buy yourself a Haynes manual #36071
Aug 11, 2008 | 1997 Ford Ranger SuperCab
All pro multi fuel
This may sound dumb, but is it full? i have a simupar one and if i start it out at 1/4 tank or ness it will not run long before it shuts off.
Dec 12, 2007 | All-Pro Forced Air Kerosene Space Heater...
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
