Question about Motorola Mobility MOTOSLVR L72 Cellular Phone
Board problem My L72 was dropped in a water and then every time i open my phone and press a key it automatically shuts off. The technician says that the problem was on the board. What is the possible problem about it?
Go to a cellphone technichian then go for repair....
Posted on Sep 04, 2009
How do I fix my cell phone I dropped in water and is now frozen?
Quickly remove the battery and never switch it on. Meet your technician to work on it.
Sep 27, 2015 | Cell Phones
Cannot start the car because antitheft won't shut off, red lights flashing, how do I shut off the alarm?
Sounds like the key may be damaged or has lost the chip, has the key been opened or dropped
Aug 01, 2015 | 2004 Pontiac Vibe
Backlight on zte warp phone doesn't work
Try to reset the phone..1.Power off the phone.
2.Press and hold Vol+ key and Power key simultaneously for about 10 seconds until the some option appear on the screen which are reboot system now; apply update from sdcard; wipe data/factory reset; wipe cache partition.
3.Use Vol+ key and Vol- key to move the cursor to "wipe cache partition" and press camera key to confirm it.
4.After 5 seconds, the cursor will be on "reboot system now" again and press camera key to confirm it. The phone will reboot automatically.If it doesnt work then it needs a repair service.
Jan 12, 2013 | ZTE Warp
Nokia 6500 slide power button not working.
You know that every electronics device run with the power whether it is Dc/AC.So, when it gets wet with water or any liquid the current passes through the mother board/main board get sort.We have known that liquid substances like water has current conductor.Therefore, if we put or supply current to the device before completely dried the components inside the device can damage easily.Likewise, you have done,now the only thing is to dry your phone by using Rework Station (Heat Blower) which is used by the mobile technician.But, sorry I could not tell you that I will definitely works because this process should be done first (before inserting battery).Thanks for visiting fixya
Mar 19, 2012 | Nokia 6500 Slide Cellular Phone
My screen is not responding on every key
Did you drop your phone? Did water get into your phone? You need a technician to open your phone and check it. A simple cleaning may solve the problem or the keypad circuit board may need repair.
Dec 04, 2011 | Cell Phones
Dropped it in water about a month ago. got it shut off pretty fast opened up the case let dry for 2 days , worked when turned on EXCEPT keyboard letters somtimes dont work, battery says full charge then...
If you are above average in elctronics abilities, you know electricity and water don't mix well. You dropped your phone in the water, you did all the right things and you got another month from your phone. Since that time, the impurities in the water that were left behind when the water dried out have continued to errode the contacts and short out the traces not to mention the normal 'wear and tear' YOU put on the phone and your phone is showing its accelerated age.
I just got a LG Rumor, it was under $30.00 new on an existing account or free if I opened a new account and they would give me two more free if I would simply activate them and add them to any account. Now - admitted, that was in MY market - not yours. I think if you want to play around with it to see how it works, you should look for parts - like a key board, etc. Take a stab at the repair. If you want/need a phone, spring for the $30.00 (per my example in my market) and have a good, reliable simple phone that will work for you when you want it to.
Thank you for your interest in FixYa.com and thank you for your question ...
Aug 18, 2011 | LG RUMOR Cellular Phone
My nokia 6120 classic shuts down momentarily from time to time, several times a day. what could be the problem?
Hello :
I think that your phone has water damage .
If you are sure , that there's no water damage with your phone , then try this please :
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to switch on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
By restoring factory settings your problem will be solved for sure if there's no water damage .
good luck .
rate please !
Mar 20, 2010 | Nokia 6120 classic Cellular Phone
To my motorola SLVR L72
try this sites
www.modmymoto.com
www.zedge.com
this two should do for now
May 13, 2008 | Lands Phones
Shuts off on its own constanly
Try opening both ports and allowing the internals to dry. I had the same problem and traced it back to water and/or moisture in the phone. The phone is water proof as long as the keys aren't pressed underwater, which in my case ruled out text messaging in the shower...
Hope this helps
Mar 28, 2008 | Casio G''zOne Type S Cellular Phone
Some menu automatic update key not work
hi
i think thiers a prob in your switch. try opening your phone and try cleaning your keypad boards. maybe it is shorted or get dirty inside...
hope it helps...
Jul 10, 2007 | Sony Ericsson K510i Cellular Phone
Motorola Mobility MOTOSLVR L72 Cellular Phone Logo
48 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
