How to access USB socket on RHS of Asus k52d
The laptop was dropped on that side with a cord in the usb connector. Has not worked since. Think the connection worked loose or solder join failed.
  • 2,072 Answers
Yeah if you dropped it you most likely did break a pin or the dislodged the connector from the solder. Re-soldering it isn't that hard, taking the laptop for someone inexperienced would be.
Posted on Jan 11, 2013
  • 38 Answers
SOURCE: USB port loose
Unfortunatley, there isn't an easy way to fix something that is physically broken. Your only options are:
1) Replace the motherboard of the laptop. (would need to be done by a professional, and may cost as much as a new laptop depending on the model)
2) Learn to deal with it. :)
Posted on Mar 19, 2009
jg1426
  • 31 Answers
SOURCE: find someone to remove mother board from laptop
Here are step by step instructions on how to remove the motherboard from a latitude D600: http://support.dell.com/support/edocs/systems/latd600/sm/sysboard.htm#1000473
The instructions seem easy to follow, but let me know if you need any more assistance with this.
Serge
Posted on Apr 09, 2009
  • 4 Answers
SOURCE: Broken touchpad connector
I suggest you replace the motherboard. A recent search on ebay turned up three ranging in price from $18 to $85. Soldering a motherboard by hand has a very high failure rate. It's easy to bridge or scratch something and fry the board. You could of course try to do it and if it fails get a replacement board.
Posted on May 28, 2009
  • 26 Answers
SOURCE: Can I power my laptop through th usb port
I know you've either fixed your problem, or thrown the laptop out(still a "fix") but for posterity, and for anyone with a similar problem...
There are two answers, depending on your laptop.
First, NO, there is currently no way to charge your laptop battery by putting power into the usb port.
There ARE commercial external batteries. sadly, they will connect to your failing power-socket.(see http://www.laptop-battery.org/Power/External-Batteries/ENB003L.html)
If your laptop has a external battery charging dock, for spare batteries.... you could go that route.
you'd probably still want to follow the last suggestion.
GET IT FIXED!
Seriously... anyone with fairly good soldering skills can probably fix that powerjack. It probably pulled/pushed the traces off the main board and will require superglue, solder, and maybe a bit of fine wire, to fix. The biggest obstacle will be the dissassembly, and proper reassembly of the laptop case. It'll take a while, but once fixed, should return your laptop to 100% functionality.
I have saved 3-4 laptops with this technique. One, I even swapped the power jack to a more common size. This was to allow the use of a non-proprietary power brick(the original had fried itself).
Posted on Jun 18, 2009
issken
  • 1472 Answers
SOURCE: dell 1525 not charging. dc usb board replacement
rubberman
Sorry to hear that you are still having trouble. The only other thing to try is your battery on your buddies notebook. If it works there then it is the charging mechanism on your notebook and this would mean replacing the motherboard.
Issken
Posted on Jan 11, 2010
How to connect mouse to Toshiba laptop
First of all, I am assuming you are using a current laptop with USB connectors. For a corded mouse, insert the USB plug into a USB socket. After the computer recognizes the mouse, use the computer control panel software to set up the mouse. For a USB wireless mouse, insert the dongle into a USB socket. After the computer recognizes the dongle, use the computer control panel software to set up the mouse.
Mar 03, 2015 | Toshiba Computers & Internet
I have a rj111 cord jsrAA.where do i plug back in
On the right hand side after the USB sockets there is a drop down flap. Underneath are the RJ11 modem and RJ45 network sockets.
http://www.notebookcheck.net/fileadmin/_processed_/csm_Anschl._rechts_01_129c1d9a1d.jpg
Nov 09, 2013 | Toshiba Qosmio Computers & Internet
Usb drive
Does the drive work with other computers? What is on the Drive? File Format? What size? Have you done ALL your Windows and Asus updates? Remove ALL media, DVD,CD,USB, shut down, unplug, remove battery, leave battery out, plug in , reboot, insert USB.
Jun 01, 2013 | ASUS Computers & Internet
What arethe compatible components of this kind motherboard
CPU P5KPL-AM empty.jpg Valuable Intel G31 uATX solution with FSB overclocking 1600MHz!
- Intel® Core™2 Quad Ready
- Intel® 45nm CPU Ready
- FSB 1600(O.C.)/1333/1066/800 MHz
- Intel® G31/ICH7
- Dual channel DDR2 1066(O.C.)/800/667
- EZ Flash2 & CrashFree BIOS3
- 8 Channel High Definition Audio
Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron® E1000 Series and Celeron 400 Series Intel® Hyper-Threading Technology ready
*Refer to www.asus.com for Intel CPU support list
Chipset Intel® G31 Intel ICH7
Front Side Bus 1600*/1333/1066/800 MHz (*1600 is overclock speed) Memory 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Overclock speed
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
VGA Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:85Hz Storage Southbridge
1 xUltraDMA 100/66/33
4 xSATA 3 Gb/s ports
LAN Realtek RTL8102EL 100/10 LAN
Audio VIA VT1708B 8 -Channel High-Definition Audio CODEC
Anti-Pop Function
Jack-detect & Multi-Streaming
Support S/PDIF Out connector USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel) Overclocking Features SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 600MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS MyLogo 2
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Fan
Back Panel I/O Ports 1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x internal speaker connector
1 x S/PDIF Out connector
1 x CPU/ Chassis/ Power Fan connector
1 x Front panel High Definition audio connector
1 x Chassis Intrusion connector
1 x CD audio in connector
24-pin EPS 12V Power connector
4-pin ATX 12V Power connector
1 x System Panel connector
BIOS 8 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.5
ACPI 2.0
Manageability WOL,PXE,RPL,WOR ,PME Wake Up Accessories User's manual
1 x UltraDMA 133/100/66 cable
1 x Floppy disk drive cable
1 x SATA cable
1 x SATA power cable
I/O Shield
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Form Factor uATX Form Factor
9.6 inch x8 inch ( 24.4 cm x 20.3 cm )
hope this helps
Jul 18, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
The A8V-VM MB has 4 physical connectors on the rear and risers to connect additional USB conectors. I have two USB sockets connected to one of the risers. However no matter which of the 6 sockets I use I...
the new er version of the motherbords have the usb 2.0 version if the motherboard asks for newer version i thin its better to get an usb add on card there are softwares available in market to make 1.0 to 2.0 but the result is not good
Dec 30, 2010 | ASUS A8V-VM Motherboard
My asus motherbord usb not working error "usb not recoznised"
If you mean the USB panel in the front then I should say that that cord of that panel is not connected to the motherboard, to solve you problem open the case and look for that cord maybe your forgot to plug it or you plug it in a wrong socket. If you find trouble finding it please refer to the motherboard manual its everything there.
Sep 07, 2010 | ASUS P5PE-VM Motherboard
Wd connected with a usb to laptop, not responding, pls help ,steady white light on
Try it in all the USB sockets available in your laptop. Try it in a desktop computer. Try a different cable.
Sometimes the USB connectors in a laptop are unable to deliver the full current rated in the USB specifications, and the drive can't start.
Also cables sometimes add to the problem, as they have too thin wires causing too much voltage drop.
Jul 08, 2010 | Western Digital WD Passport 250GB Portable...
I'm installing a card reader that has 5 wire connector tto the mb. The old card reader has a 7 wire connector that fits the mb. Its an Asus m2n68-vm. Thanks
These card readers normally fit the auxiliary USB socket on the motherboard. They usually take up all nine pins, four on one row and five on the other with a 10 socket plug. One pin missing on the end of a row.Such card readers have an additional external USB port as well as card reader slots. If it is just a straight five pin plug but with four wires it just fits over one side of the nine pin USB socket on the motherboard. The black wire goes at the end with the missing pin.
Mar 29, 2009 | ASUS P4P800SE Motherboard
USB cord Wont Fit?
The S730 has an uncommon USB input socket. You MUST use the USB connector which came with THIS camera.
Jan 07, 2008 | Samsung Digimax S730 Digital Camera
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
