Question about Kenmore 24032\24036 Top Load Washer
Washing machine won't drain or spin
My Kenmore 80 series stopped draining and would not spin. What is the problem? Is it difficult to repair? Should I have it repaired or get a new one? How much does the repair cost approximately? Thanks.
  • angamek Jan 22, 2009
    You're right! I actually found the solution last night. I taped the thing back and it ran. Would it be possible to buy the part and put it in myself? Is it difficult to do? Thanks a million.
  • angamek Jan 23, 2009
    Thank you for the answer. Do I need to take the machine apart in order to install the switch?
  • 61 Answers
Sounds like a broke lid switch is is an inexpencive repair the switch run about 30.00 -40.00 dollars plus the labor to put it in shouldn't be much must that just the service call to to come out.
Posted on Jan 22, 2009
  • Shawn Smith Jan 22, 2009
    yes you can buy the part and put it in yourself.
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
How do i determine if my switch is working on my kenmore 70 series washing machine
i think there is some problem in wiring of spin and drain. thats y it works only for washing. current stops after washing. or otherwise click below link and check the manual may be its timer problem
http://www.askmehelpdesk.com/appliances/kenmore-washing-machine-70-series-repair-manual-479481.html
http://www.askmehelpdesk.com/appliances/kenmore-series-70-washer-manual-445690.html
Jan 04, 2012 | Kenmore Washing Machines
Kenmore washer 80 series stopped draining
So it will agitate and fill but the motor won't run during drain and spin?
If so, the likely cause is a bad lid switch. The paddle that the probe hits when the lid is down moves a small switch. That switch can do two things
1. fail internally. It will look fine outside but it won't close the circuit
2. the screw holes snap and it hangs off the wires, the probe no longer hits the paddle and the switch stays open.
The lid switch is cheap and very easy to repair.
Nov 10, 2011 | Kenmore Washing Machines
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
I have a Kenmore 80 that doesn't spin
You may not have given me enough information, but here goes. If the washer drain some water and then does not spin, the washing machine clutch assembly needs to be replaced. If it is not draining at all then the water pumps needs to be replaced. Water pump replacement is easy, but the clutch assembly- you better be very experienced. Unplug the appliance before you attempt these repairs! You will need the model number to get the proper replacement parts.
Jan 16, 2010 | Kenmore Washing Machines
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Mar 13, 2009 | Kenmore Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
105 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
