Question about Goodman CLQ36AR49 Air Conditioner
Too frequent on/off cycle
My Goodman awuf2 runs too frequently in heat mode, 1.5 min on, 3 min off.
Any selection points to change ?
pls advise.
  • 144 Answers
Is it reaching the temp. set on the T-stat? Is the T-stat digital? If so the differential on the T-stat(the temp.difference between where it turns on and turns off) is probably set at about .5 degrees. I recommend changing it to 1.5 degrees. The instructions to reset it should be in the T-stat manual.
Posted on Jan 22, 2009
Am I able to adjust the 'hysteresis' of my digital thermostat?
Some thermostats allow you to change the differential value - that is how far below the heating (or above the cooling) set point before calling for heat (or cooling in the case of air conditioning). The built in 1 degree differential setting provides the most even temperature in the space at the expense of more frequent furnace firing and stopping. Many people prefer this mode as opposed to allowing wider swings in temperature for less frequent furnace firing and stopping. If you wish to change this setting, you'll need to replace the thermostat as it is not user adjustable in this model.
Nov 02, 2015 | Honeywell RTH6350D1000 5/2Day Prog...
Heat Pump Cycling too frequently?
It should run until it reaches the temp. setting on the thermostat.
Do you have a make and model number so I can assist you?
Jan 11, 2014 | Mitsubishi MSH09TW Air Conditioner
Rheem split system condenser high pressure limit/safety needs resetting frequently before it reaches the set temp of 76 degrees faren. what's wrong and what do i need to check?
Is the outdoor fan running? The fan cools the coils and compressor, therefore keeping the high pressure low enough to run. Either the fan is not working or its not spinning fast enough. Check the capacitor, or just replace it.
Apr 18, 2017 | Heating & Cooling
Fridge seems to run too frequently
How old is the fridge? Newer units will run more frequently and make "running" noises.
Apr 30, 2012 | Kenmore Refrigerators
When in defrost mode my air condioner and electric fan motor comes on and off in about 1 min. time. I can here a rely cut in and out. whats gong on !!!
It's normal for that to happen.It uses AC system to help remove condensation for defrost. You'll notice it doesn't happen on heat, only defrost. AC may be slightly low on freon causing it to cycle on & off more frequently.
Jan 25, 2011 | 1994 Plymouth Sundance
Kenmore elite dryer runs for about 3 min. then trips the breakers
The circuit breaker may be tripping because of a fault with the dryer or it may be a fault with the circuit breaker being weak.
From the description you give the circuit breakers trip frequently.
I'd suggest you first try selecting the no heat air fluff cycle and run it to see if the breaker trips. If the circuit breaker doesn't trip in air fluff then there is likely a short in the heating element.
With a clamp-on amp meter you can read the amp draw of the dryer when it is heating. With the motor and element both working you would see approximately 25-26 amperes being drawn. The breaker is rated at 30 amps. If the breaker trips and only 26 amps are being drawn then the breaker is the problem.
Try the air fluff cycle first and see if the breaker will trip. Then with additional details I may be able to help you further.
Jan 05, 2011 | Kenmore Dryers
Computer is turning off frequently,automaticaly.
IF it is windows it is something to do with power management go to control panel and in power management disable the restart option and diable the hibernation mode too and in BIOS reset to default
Jul 02, 2009 | Computers & Internet
Cold air out of register for about 3 min. until starting to warm
heat pumps generate heat from compressing freon and take a while to generate enough heat to be useful. never expect robust heat from a pump like an oil burner or a gas furnace, but they do heat great and are cheaper to operate. do this . if you are still using an old mercury bulb stat change it to a digital one. this will hold an exact temperature and time off between cycles will be less and the indoor coil will stay warm between short cycles, with an old mercurry stat you set it at 70 and it may run up to 73 and stay off till 68. thats a long off cycle and when call resumes the coil has gotten cold and has to start all over again. also dont wait till it gets cold to run a heat pump. turning it on and off as it gets cold is not correct. you should select a temp ,usually 71 for heat and set it and leave it on to do its may want to check the charge. hot gas discharge is usually 100 degreees hotter than outdoor temps after 15 minutes run time. for example if its 40 outside the big freon line outside thats insulated should be about 140 degrees. or you can run it 15 minutes and grab it with your hand . it should be almost uncomfortable to hold any length of time. careful some get quite hot. you also have the option of hooking up the electric strip to automatically come on if you push the stat up 2 degrees hotter than the temp in the room. that way you get heat pump and strips till temp gets within 2 degrees of set point and the strips shut off and pump maintains.good luck
Nov 01, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman split not responding to remote
First turn the main power off to the unit at the breaker, wait about five min. and switch the breaker back on, then see if this solves the problem. In the instalation manual that came with the unit on the last page you will see a code of the red blinking light, this will tell you the most likely problem if not solved by switching the breaker on again.............Hope this helps
Oct 14, 2007 | Hitachi RAS-09UH Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
69 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
