Question about Infinity BASSLINK Car Subwoofer
Subs make a noise
My subs make a whitles noise when the volume is low. but it kinda goes away when i drive and it is like it is playing a tone from the engine like when i i drive put it in reverse it make weird noises?
  • 56 Answers
If your sub or its amplifier is placed too close to the transmission box, this situation can cause interference. I suggest that you buy a ground loop isolator or an RCA filter. If the problem is about grounding, then you have to buy a ground loop isolator. Otherwise, an RCA filter can solve your problem. First of all, the problem has to be diagnosed.
Posted on Jul 04, 2007
SOURCE:
LOUD HUMMING NOISE COMING FROM SPEAKERS
Could do with a service.
Check the turntable motor and drive plus check the cartridge and signal wiring.
Sep 14, 2017 | Wurlitzer Jukebox CD Player
I've had the Tonebone Plexitube since January of this year, but have only played through it a couple of times. I recently took it out to really experiment with it and get to know the pedal. Right away...
It sounds like somehow the pre-gain is very high while the volume or post-gain is very low. Try turning the volume high on the effects unit and the gain low, and don't have the amp volume too low either.
May 18, 2011 | Radial Tonebone Plexitube Effects Guitar
Popping noise on my 12" type r subs
The subs are making that sound when the bottom out + when they reach full excursion be careful if it keeps happening eventually your subs will fail because you will end up damaging the subs voice coil.
Happy Booming
Apr 20, 2010 | Alpine Type-R SWR-1222D Car Subwoofer
Low sound and buzz from speakers / Hum noise from sub-woofer
Select Start > (right click) My Computer > Manage
In the Management window select > Device Manager
Next to Sound, Video and Game Controllers click the + sign
A yellow triangle will signify a problem so if one is present, right-click that device and select Properties
You can then choose to update the driver
For more details check Dell Xps 420 Manual.
Dell Xps 420 Manual
Apr 14, 2017 | Dell A525 Computer Speakers
I have Bose Companion 2 Series ones and the left makes odd noises
> I turn the volume to a low it still has the odd noise
If there is any drive to the speaker at all (volume not turned off), the rattle is probably coming from a broken 'surround;' the part that keeps the cone centered around the outer edge.
Another point of failure is a structure called a 'spider' that is located between the voice coil and cone that ensures the voice coil stays centered.
If there is hum with the volume turned completely down, the amplifier driving the speakers (internal or external) has a failing filter in the power supply.
Dec 14, 2009 | Bose Companion 2 Computer Speakers
Rockford sub squeaks
Hello markwasicki,
You did not specify what type of enclosure the subs are in or if they share the same airspace. But the sound you describe sounds suspiciously like the enclosure is at fault and not the sub itself.
Remove and reverse the subs in the box and test for the noise again. If the noise is still produced on the same side of the box, it's the enclosure. If the noise follows the sub, then you have a problem with that sub.
If the box is making the noise, and it's a ported box, you probably have "port noise". If it's a sealed enclosure, you could have either an air leak or flexing noise. In either case, repair the enclosure or put the subs in a new one. If the sub itself is making the noise, there probably isn't much you can do. Most likely some part of the voice coil assembly is touching where it should not.
Hope this helps.
Apr 18, 2009 | Rockford Fosgate (P212D4) Car Subwoofer
Jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
Feb 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
Road noise
you need a ground loop isolator! they are sold at radioshack and walmart and run about 12 bucks!!
Jul 11, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Problem with amp?
Give that new sub a chance to "break in". New speakers require a few hours of use before the voice coil(s) and spider break in and began operating at their best performance. Is the box within the operating specs of the sub? Is this a ported box; if so you will here some turbulance type noise from the port. What type of distortion are you hearing? Alternator noise(dentist drill like sound) would only be noticable through a sub at lower volumes due to the frequency response of a sub. Is the amps lowpass crossover turned on?
Mar 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Whining noise
The problem i had was when i would play my tv. I had it hooked from my dish to the sony then the tv. When i played a dvd,cd or the tuner it didn't make that noise. It seems my video/audio 2 channel was going bad. I disconnected my rca jacks and used the optical audio connection. The noise stopped and i got a better quality sound.
hope this helps
Oct 16, 2007 | Sony DAV-FC8 System
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
115 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Ekse
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
