Question about Baxton Studio Vinnie Cradle Chair Blue
Assembly instructions for baxton studio cradle chair
How do you attach the legs to the body?
Need the printed assembly instructions for the "Kidkraft Floral Fantasy Doll Furniture Set Cradle & High Chair".
Sorry we do not have these instructions. Call the manufactuer and see if they will email you a set of them
Oct 27, 2016 | The Toys
How to assemble executive swivel high back chair
Usually you screw the base to the bottom of the chair and then attach the back and then arms. If it did not come with instructions return it.
Sep 28, 2014 | Boss Traditional High-back Executive...
What are the health benefits of rocking chairs?
Rocking chairs are known to be providing a number of health benefits that many patients suffering from dementia relieved from the pains and got some good changes in their moods. Here are a number of health benefits that you get from using rocking chairs.
  1. Increased Well-Being Of Dementia Patients.
  2. Decrease in the need of medications.
  3. The motion of the rocking simulates the body to maintain balance. Thus, it may result in greater balancing capabilities of the body.
  4. Improved Muscle Tones.
And there are a lot more benefits that you may feel by using rocking chairs for your selves.
Aug 29, 2012 | Alex Furniture
NEED COSCO FOLDING CHAIR FEET/CAPS - OVAL W/GRID BOTTOM
Q. Where can I get replacement Leg Tips or Cradle Tips for my Chairs?
A. Leg Tips and Cradle Tips can be ordered directly through us by calling our consumer relations department. Contact a Cosco representative at 1-800-544-1108 Monday through Thursday 7:00 AM to 6:00 PM EST and Friday 7:00 AM to 4:30 PM EST. You may email us at www.coscoproducts.com or fax us at 1-800-207-8182. Please provide the model number and manufacture date from the sticker on your product when contacting us.
Jun 18, 2012 | Health & Beauty
How do I keep my dining room chairs from scraping my parquet floors?
You have a few options to keep you chairs form scrappingyour floor. Although not necessarily astaticallypleasing, you could put an area rug under your table and chairs. The most popular remedy is little plasticdiscs that use self-adhesive to attach to the legs of the chair. You can also get "fabric backed coaster cups"which are little bits of fabric that are attached to the legs. The other option is clear plastic mats thatthe chairs sit on top of (like for swivel chairs in offices.)
May 29, 2012 | Furniture
Don't have the directions to put evenflo exersaucer together, need help. Is there somewhere I can get the directions? reg. number 07T-0538604
Instructions
    • 1 Place the large, round base on the floor. The outwardly curving edge should be facing downward.
    • 2 Attach the three pedestals to the base. To do so, insert your finger into each pedestal and loop the spring within around the hook found on the base in the appropriate holes. Insert the three plastic tabs on each pedestal into the base, locking them into place.
    • 3 Press the wider end of a lower leg assembly onto each pedestal piece. By wiggling the lower leg assembly side to side, you will eventually snap the pieces into place.
    • 4 Hold the seat ring in your lap with the open edge facing upward. Press each of the six wheels into the wheel holders around the edge of the seat ring. Each wheel will snap into place when positioned correctly.
    • 5 Insert the cloth seat into the seat ring, aligning the diamond on the cloth seat with the triangle on the seat ring. Each plastic tab lining the edge of the cloth seat attaches to a peg on the seat ring. Snap these connections into place.
    • 6 Hold the Exersaucer tray on its side and press the seat ring into the center. Once the seat ring snaps into place, it should be able to spin in place.
    • 7 Attach the three spring caps to the Exersaucer tray. These spring caps cover the three large holes in your tray, and are attached by a firm clockwise twist.
    • 8 Attach the upper leg assemblies to the upper leg crowns. These crowns act as the "socket" and the upper leg assemblies act as the "ball." By pressing them together with a click, the upper leg assemblies can twist and rotate in place.
    • 9 Turn the tray upside down and press each upper leg crown base into the round holes in the tray with a firm twist. Each upper leg crown features a height adjustment hole, which will face outward when properly attached.
    • 10 Turn over the tray so that the upper leg assemblies are facing downward. Insert each upper leg assembly into a lower leg assembly, being sure to pull away the height adjustment tab to allow the assemblies to slide together.
    • 11 Press each toy into its respective port on the surface of the tray. The toys each have a distinct base, which clicks into the correspondingly shaped tray port
May 10, 2011 | Toys
Need assembly instructions for gardenline double glider bought at Aldi.
Hi, I know this probably won't help whoever posted this because I'm really late, but it will helpfully help out those still searching online.
1. Attach one leg brace (E) to the leg (F) using two M6*40 screws (K), four washers (P) and two nuts (Q). Repeat this step to attach the other leg (F). See Fig.1
2. Attach the other leg brace (E) to the legs (F) using one M6*40
screw (K), two washers (P) and one nut (Q). Repeat this step to
attach the other leg (F). See Fig.2
3. Attach one rocker connector (G) to the leg (F) using one M6*55 screw (M), two washers (P), one spacer (O) and one nut (Q). Repeat this step to attach the other leg (F). See Fig.3
4. Attach the other rocker connector (G) to the leg (F) using one
M6*60 screw (N), two washers (P) and one nut (Q). Repeat this
step to attach the other leg (F). See Fig.4
5. Attach the left arm (B) to the chair back (C) using two M6*35
screws (J) and two washers (P). Repeat this step to attach the
right arm (A). See Fig.5
6. Attach the chair seat (E) to the arm front side using two M6*20 screws (I), two washers (P) and two large washers (S). Attach the chair seat (E) to the arm rear side using two M6*35 screws and two washers (P). See Fig.6
7. Attach the assembled chair bucket to the lower end of the
rocker connector (G) using one M6*50 screw, two washers (P),
one spacer (O) and one nut (Q). Repeat this step to assemble
the other three connection points. See Fig.7
8. Fully tighten all screws using wrench (T) and Allen Key (U).
Cover all hardware with screw caps (H) and nut covers (R)
respectively. See Fig.8
May 08, 2011 | Garden
I need a leg for the dwell studio silver lake crib in espresso/white. mine came with two of the same sided legs and the bed can't be put together until I find the opposite leg. Does anyone know how to get...
I am also missing one leg, and mine came with two of the same legs. I am missing part D. I contaced the manufacturer and they said it will take 4-6 weeks to get the part!!!
Mar 20, 2010 | Storkcraft Baby DwellStudio for Target...
I dont have the instructions to turn my simplicity 4 in 1 crib to a toddler bed
Install Safety Rails
Mattress support must be in lowest postition
Remove the Front Panel Contoured Top rail and Front Panel
Loosen connector pieces on the end of the leg of the Safety Rail to the End Leg using two of the Allen Bolts (11/2 in). Loosely attach the leg of the Safety Rail to the underside of the Mattress Support using one of the short Allen Bolts (3/4 in) through connectors. Tighten all three of the bolts holding the safety rail to the unit.
Repeat procedure with the other safety rail.
These are the instructions in the manual. Basically, you take off the front cross board and rail, attach the safety rails to each of the front legs. They kind of go 1/3 of the way across the front with about a 1 1/2 foot opening in the center.
Apr 08, 2009 | Simplicity for Children Ellis 4 in 1 Sleep...
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
Baxton Studio Vinnie Cradle Chair Blue Logo
71 people viewed this question
Top Baxton Studio Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Baxton Studio Furniture Expert? Answer questions, earn points and help others
