Question about Cfm Daikin R410a Split System Air Conditioner
Daikin split system fty60gav1a year of manufatured
4 Suggested Answers
  • 41 Answers
SOURCE: i have a daikin split system about 4yrs old when i
you must check battery of the remote of the air conditioner
Posted on Nov 08, 2009
  • 901 Answers
SOURCE: daikin split system fine with cool air, not with hot air
Looks like thermistor problem. take service help.
Posted on May 27, 2010
heatman101
  • 43501 Answers
SOURCE: Daikin Inverter Split system turns
There are quite a few things that can cause the symptom you are describing there...
The most common would be for you to have a refrigerant leak in the system that is causing the outdoor unit not to run, but the indoor unit still will run...
Often there will be a diagnostic LED on the outdoor unit that will help with troubleshooting...
Of course also a good thing to try is to remove all power to the unit indoor and outdoor...and then reapply the power and see what happens...this may correct the fault...
here is a tip that also will give you some things to check....
Feel free to comment back with any more questions...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Feb 05, 2011
Can I run a daikin mini split heat pump 3MXS24JVJU with a generaton
It depends on the SIZE of the generator. If your generator is designed to supply 240-volt A/C and handle the FLA (Full Load Amps) rating of your Indoor and Outdoor units, then, YES, of course you can run it with a generator.
Aug 26, 2014 | Cfm Daikin R410a Split System Air...
Solution for u2 error
it sound like the outdoor pcb has failed, if your unit is less then 5 years old it will be under warranty. if your unit is a rxd50/60/71jvea it will be a fan motor and pcb
Mar 16, 2012 | Cfm Daikin R410a Split System Air...
Is there a reset button on daikin splits? If so where can I find it.? Fault code U4.
the fault code for daikin u2 is power supply is too low the reason for this is complexed and needs an expert to fix it
hope this helps in some way
Dec 02, 2010 | Cfm Daikin R410a Split System Air...
My split system just blink a green light when turned on--outside powerboard was recently replaced--worked ok for a while
try switching off and on circuit breaker if same you have fault somewhere, call daikin for assistance
Nov 22, 2009 | Cfm Daikin R410a Split System Air...
I have daikin split ac and it stops suddenly and blink the green light and after awile i turn it off then on and works again.. whats the problem ?
trying to get the panel to work. Its blinking and won't accept commands.
tried new batteries..still does'nt respond
Aug 29, 2009 | Cfm Daikin R410a Split System Air...
Cfm Daikin R410a Split System Air Conditioner Logo
57 people viewed this question
Top Cfm Heating & Cooling Experts
David Payne
David Payne
Brett Duxbury
Brett Duxbury
Thomas Woodburn
Thomas Woodburn
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
