Question about Nikon Coolpix L26 Compact
I purchased a Nikon Coolpix camera in July 2012 and have had problems with the memory card when installing and removing. It is stuck and will not budge. What can I do???
Memory Card is stuck in the camera.
SOURCE: Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Posted on Jun 10, 2007
robmcd27
  • 423 Answers
SOURCE: nikon coolpix L11
I'm sorry but you can't use the camera as a webcam. Here is why. There is no function on the camera to stream video.
Also, the camera goes into standby mode after 30 seconds (by default). And 3 minutes after that, it shuts off completely. It does that to save batteries. Again. I'm sorry. Good webcams average between $20. to $50. usd and they are made to work 24 hours a day 7 days a week.
You can use a 4GB memory card in your camera, as long as it's an SD card.
If you get that message, it means you haven't formatted the card for use in that camera. You have to format the card in the camera before you use it.
Even though the solution was not what you prpbably wanted, don't let it stop you from rating it a fixya. I would appreciate it. Let me know if I can help you with anything else, and thanks for coming to FixYa.
Rob
Posted on Feb 23, 2009
Lardzor
SOURCE: How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom.  Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
Posted on Sep 13, 2009
  • 102366 Answers
SOURCE: "memory card is write protected"?? but it's not the memory card!
It's not the camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Mar 09, 2010
SOURCE: Nikon coolpix 2100- out of memory- After installing 4gb CF card
4GB requires FAT32. Camera firmware only supports FAT16. 4GB won't work because FAT16 has a 2GB maximum size limitation. 1GB CF card is Nikon's "approved" maximum for this camera.
Catch: 22 1GB -and lesser capacity- CF cards are no longer manufacturered or generally available in 2010. When the current CF card dies, the still working camera also becomes throwaway unless you can source a CF card 1GB or under. 2GB may work, but with 'issues' per caution below.
CAUTION: Anecdotal evidence suggests the final release -& current- firmware for cameras of this generation is also encumbered by with a maximum picture number limitation of 999, realistic at the time of original manufacture when 256MB was a the largest capacity CF card but completely nonsensical now.
Summary: This is my first NIkon Digital camera and also my last.
Apart from the noteriety of the ubiquitous broken Nikon plastic battery latch, a major design flaw Nikon refuse to acknowledge or accept liability to rectify -since self-repaired better than OEM, Nikon policy on firmware support is complete abandonment of product within an unacceptably short service window. ie: a deliberate poilicy of enforced obsolescence.
Suggested Problem Remedy: Do buy a new camera supporting SD Cards of current capacities. Don't buy anything branded Nikon.
Posted on Mar 24, 2010
Nikon Coolpix S52C camera transfer pictures problem.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Sep 06, 2012 | Nikon COOLPIX S52c Digital Camera
I own a Nikon Coolpix 5700 and recntly I face a problem with the memory card, The memory card is Nikon Compact Flash 32MB and the camera shoes that I can have Basic 51 photoes, Noraml 26 Fine 13 and Hi...
Nikon Coolpix 5700 Digital Camera memory card failure:
This camera has capabilities which far exceed the data storage of a 32 MB memory card. Put what you can onto the Nikon Compact Flash card and purchase another, larger, 2 GB card for your other storage. This should easily meet both the needs of the camera and your own. The original card must have had data deterioration or a mistake was made in transferring the pictures.
Go to Google and download their Picasa App; it is great for anyone transferring their photography from one storage type to another and you can use it for publishing material to the Web or to your family group e-mail.
Please comment on the success of this solution!
Sciencewoman
Apr 15, 2011 | Nikon Coolpix 5700 Digital Camera
My digital camera has a lens error
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jul 24, 2010 | Nikon COOLPIX S570 Digital Camera
My nikon coolpix s51 show message memory card is
For the message that show's on your camera here's is what your need to do. 1. Remove the memory card and check for the physical lock toggle.
2. Toggle the lock on and off.
3. Try blowing on the memory card and the memory card port so it will be cleaned somehow. here is the picture of the lock toggle of the SD memory card 919a7e0.png
Apr 13, 2010 | Nikon COOLPIX S51 Digital Camera
My nikon camera coolpix 1600 memory card is write protected. Plea
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Apr 28, 2009 | Nikon Coolpix S51c Digital Camera
Nikon digital camera malfunction
Hey jackie jean,
If the two year extended warranty you are talking about is a performance service plan purchased at a Best Buy™ store then you could bring the camera into a Geek Squad® precinct in a Best Buy™ store, and they should be able to send it out for service at no charge to you. I am assuming you formatted the memory card in the camera, but if this is not the case and you have formatted the memory card using your computer then I would suggest formatting the memory card in the camera. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 29, 2008 | Nikon Coolpix S51c Digital Camera
Nikon coolpix 5700 shows no memory left after purchasing a new card & batteries
The largest CompactFlash card that Nikon approved for the 5700 is 256MB, which is what I'm using in my 5700. That's small by today's standards and you probably won't even find it in stores. I see some web sellers have 256MB cards for only $6 or so. Other commercial card sellers on the web claim that the 5700 will handle CF cards up to 1GB capacity. That's what I might try since online they're selling for as little as $8 plus shipping. Given that the 5700 was introduced in 2002, any cards bigger than 1GB probably won't work.
Jul 21, 2008 | Nikon Coolpix 5700 Digital Camera
System error showing up on Nikon coolpix 3200
A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
1. Use the memory card that originally came with the camera (or a Nikon approved card)
2. Remove and replace the battery
If the error is still displayed, contact Nikon's Service Department (below). If the above tips do not help the camera must be sent to Nikon Service, there are no user serviceable parts on Nikon Coolpix cameras.
Jun 13, 2008 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
May 07, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix L26 Compact Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
