Question about Dryers
How do I redirect the vent on the Kenmore Dryer
Why do dryer sheets stick to the vent outlet on a Kenmore gas dryer?
The dryer sheets soften during the drying cycle to release the softening material. Air flow through the dryer drum causes the sheets to "glue" themselves to the vent outlet. If you have the dryer disassembled for service, you will find a sticky residue on the back of the vent.
Dec 31, 2014 | Kenmore 73952 Gas Dryer
How to clean lint out of a kenmore elite gas dryer?
Professionally Dryer need to be taken apart some.
by removing front of dryer and removing inner tub
.having a good shop vacuum. and a paint brush .We have a service and charge $65 come out and clean dryer and venting.
heavy lint build up in dryer normally means improper venting.
all domestic dryer venting should never go over 8 ft vertical venting the less turns the better and if vent go's up you need induced venting another fan to help dryer push air Sears website will have brake down on your dryer not a hard job if your good with tools
Jul 05, 2014 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore dryer 70 series
Check the vent for clogs and kinks. Could be something in the blower wheel causing the noise and blocking the vent.
Remove the vent from the back of the dryer, unplug the dryer, and reach inside the dryer vent to check for items lodged in the blower housing.
Feb 04, 2014 | Dryers
Moved dryer to a new home. Dryer vent comes out of the middle of the dryer. New home vent is next to the outside wall so i have a bend off the dryer vent and then a bent to the out side vent, Can you...
Some Kenmore dryers have a knockout at the back, lower corner that can be "knocked out". If you have one of these it can be vented out through the side. If the knockout is there, a kit is available for the venting. Just go to www.sears.com and under the parts direct tab enter your model number aka 000.00000, and search out the kit.
Aug 29, 2010 | Kenmore Dryers
Kenmore dryer w/back vent, need to make it vent into floor/bottom
you will go to any hardware or home depot and purchase a metal ductwork elbow. that will direct the vent down 90 degrees
Jul 14, 2009 | Maytag PYE2300AY Electric Dryer
MY DRYER GETS HOT ON TOP OF THE DRYER (KENMORE) COULD IT BE THE VENT?
start dryer, go outside and see if vent is blowing hot air. If not then vent is clogged with lint, esp if vent has a curve or elbow in it. unhook vent at dryer or os vent and run a vacumn hose in as far as you can. easy way to determine if vent is to unhook at dryer and see if dryer blows air, could be just inside at vent opening
Jul 11, 2009 | Kenmore Dryers
My kenmore 70 series dryer will not dry clothes, but it does heat up inside and lets hot air out the dryer vent on the outside of the house.
make sure the dryer vent and the house vent are not clogged with lint this will slow down the drying process-mike
Mar 14, 2009 | Kenmore 62802 Electric Dryer
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Kenmore dryer series 70 won't turn on
most of the time it is the door switch that goes bad,also you can check the main fuse inside the dryer on the blower box,and always make sure your dryer vent and wall vent are clear to vent,let me know what you find-mike
Oct 26, 2008 | Kenmore 63942 Dryer
Dryers Logo
16 people viewed this question
Top Dryers Experts
