Question about Canon LaserClass 9000L Plain Paper Fax
Need phone code to accept fax
Need a phone code to accept a fax on my Dell 964. PLEASE>>> PLEASE can you help?
    Scholar:
  • 54 Answers
The phone code is DELL# (3355#)
Receive a Fax Manually - from page 57 of the manual.
1 Make sure your printer is on, and an active telephone line is connected to the FAX
connector ( — left side connector) on the printer.
2 Make sure the Auto Answer feature has been turned off.
a On the main screen in Fax mode, use the up and down Arrow buttons to scroll
to Auto Answer.
b Using the left and right Arrow buttons choose No or Scheduled and press
Select .
c If you selected Scheduled, the Auto Answer Schedule screen appears. Using the
keypad, specify the time you want Auto Answer to be turned on and be turned off.
d Press Select .
3 When the printer rings, pick up the telephone, and listen for the fax calling tone.
4 Press DELL# (3355#) on the printer operator panel.
NOTE: DELL# is the default answer code. However, you can change this to any four-digit code. For
more information about changing this code, see "Changing the Pickup Code" on page 71.
The site Machine83 suggested makes you sign up to download the manual, you can get the manual here for free: http://support.dell.com/support/edocs/Systems/PRN964/en/om/om_en.pdf
Posted on Jan 22, 2009
  • Justin Wolery Jan 23, 2009
    Thank you for using FixYa! Please rate my solution if you found it helpful.
    Let me know if you need any further assistance.
  • 8,197 Answers
Fax Problems
When you have trouble sending or receiving faxes, try these things to fix the problem.
PRINTER WON’T PRINT AND PRINT JOBS ARE STUCK IN PRINT QUEUE.
Print jobs may be stuck in the print queue if you have multiple instances of your Dell printer installed
on your computer. To check for multiple entries of the printer:
1 In Windows XP, click StartControl PanelPrinters and Other HardwarePrinters and Faxes.
In Windows 2000, click StartSettingsPrinters.
2 Check for multiple printer objects for your Dell printer, which might be shown as Dell 964, Dell 964
(Copy 1)
, Dell 964 (Copy 2), and so on.
3 Print a job to each one of these print objects to see which print object is active.
4 Set the active print object as the default printer by right-clicking it in the Printers and Faxes window.
5 Delete the other copies of the print object by right-clicking each and selecting Delete.
NOTE: Be careful not to delete any printers you still want to use. If you accidentally delete a printer
that you want to use, reinstall it using the CD or web drivers for that specific printer. To prevent multiple
instances of your Dell printer in your Printers and Faxes folder, make sure when disconnecting and
reconnecting the printer from your computer’s USB connector that you always plug the USB cable back
into the same USB connector that was originally used for the Dell printer. Also, do not install the Dell
printer drivers multiple times from your printer CD.
MAKE SURE YOU TURNED ON BOTH YOUR PRINTER AND YOUR COMPUTER, AND THE USB
CABLE IS PROPERLY CONNECTED.
MAKE SURE AN ACTIVE TELEPHONE LINE IS CONNECTED TO THE FAX CONNECTOR (
—LEFT SIDE CONNECTOR) ON THE BACK OF YOUR PRINTER.
  • 1 more comment
  • Jyackle5
    Jyackle5 Jan 22, 2009
    MAKE SURE THE FAX NUMBER, COUNTRY CODE, AND DATE/TIME ARE SET CORRECTLY.
    MAKE SURE THAT IF YOU ARE USING A DSL OR ISDN LINE, YOU ARE USING A DIGITAL
    LINE FILTER ON THE TELEPHONE LINE CONNECTING YOUR WALL JACK TO THE WALL.
    MAKE SURE THE TELEPHONE LINE IS NOT IN USE BY ANOTHER DEVICE SUCH AS A
    DIAL-UP MODEM INTERNET SERVICE. IF IT IS, WAIT UNTIL THE OTHER DEVICE IS
    FINISHED BEFORE SENDING YOUR FAX.
    MAKE SURE THE ORIGINAL DOCUMENT IS LOADED CORRECTLY (FACE DOWN IN THE BACK
    LEFT CORNER OF THE SCANNER GLASS OR TEXT-SIDE UP ON THE ADF) AND THE PAPER
    IS LOADED CORRECTLY (FOR HELP, SEE "LOAD PLAIN PAPER INTO THE PAPER SUPPORT"
    ON PAGE 22).
    MAKE SURE THE PRINTER DOESN’T HAVE A PAPER JAM. IF IT DOES, SEE "CHECK FOR A
    PAPER JAM." ON PAGE 94.
    MAKE SURE THE MEMORY IS NOT FULL. DIAL THE RECEIVING NUMBER FIRST, AND
    THEN SCAN YOUR ORIGINAL DOCUMENT ONE PAGE AT A TIME.
    MAKE SURE THE POWER SUPPLY, TELEPHONE, HANDSET, AND ANSWERING MACHINE
    CONNECTIONS ARE SECURE.
    MAKE SURE THE SPEED DIAL IS SET CORRECTLY.
    MAKE SURE THE PRINTER DETECTS THE DIAL TONE.
    Good Luck
  • Jyackle5
    ON PAGE 22).
  • Jyackle5
    Sergeant:
  • 378 Answers
Http://www.retrevo.com/support/Dell-964-Multifunction-Printers-manual/id/261dj584/t/2/ just click this link and check out the fax setup it will solve your issue without entering any code.check out the fax settings in the above link set asd per that it will solve your problem. thanks.
What is causing a Phone Line Error when I go to fax?
Do you have the fax set to the proper setting? Check that and verify.
Jul 13, 2017 | Dell Photo 964 All-In-One InkJet Printer
Trying to print to a dell photo aio printer 964 from my laptop and it keeps telling me "communication not available; the printer cannot communicate with the computer; please turn on enable...
Bidirectional Printing - A means of printing by a computer printer which prints one line from left to right, then the following line from right to left. Such printing is faster than printing in one direction only, as there is no need to wait for the carriage or other imaging mechanism to return to the left margin before starting a line.
how to enable bi-directional printing.here's how:
  1. -click on start
  2. -click on printers and faxes (control panel->printers and faxes)
  3. -right-click on Dell Photo All in One Printer 964 All-In-One icon
  4. - click on properties
  5. -click on ports tab
  6. -down at the bottom there's a small box before bi-directional support
  7. -tick the box to enable it then click apply,ok
  8. -try printing again
note: in vista , printers and faxes is printers.in win 7 ,it's devices and printers.
and properties in win 7 is printer properties
Jun 05, 2011 | Dell Photo 964 All-In-One InkJet Printer
The dell photo printer 964 is not answering faxes
You are in MANUAL MODE. When the fax is ringing, press the start button.
Nov 28, 2009 | Dell Photo 964 All-In-One InkJet Printer
My Dell Photo 964 All-In-One won't receive faxes, but can send them just fine. All other features are alright. Spoke to Vonage (our phone service) for 2 hours troubleshooting and sending test faxes, and it...
First check a couple of obvious things:
Sometimes the presence or absence of a (DSL) filter on the line can affect fax reception.
Also check to make sure you have not enabled Fax Blocking.
Otherwise, I can only offer some information HP provides for support of VoIP fax setups, available by clicking here., and hardware setup options available here. Whether it is even remotely useful in your situation you'll have to judge.
You know there is also a Dell Forum where users
can pose questions and exchange answers. Have you checked to see if there are solutions posted there? Dell Forum 964fax error
I'm afraid I am not familiar with that particular machine or Vonage...sorry I couldn't offer anything more...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 08, 2009 | Dell Photo 964 All-In-One InkJet Printer
How to get the all in one fax / copier /printer to stop printing a report after each incoming and out going fax. It waistes ink and paper.
1 Click Start Programs or All ProgramsDell PrintersDell Photo AIO Printer
964
Dell All-In-One Center.
2 From the Dell All-In-One Center, click the Maintain/Troubleshoot tab, and then click
Display the Printer Setup Utility.
Printer Setup Utility Tabs
On this tab: You can:
Send • Enter your name and fax number.
• Select a maximum send speed and a print quality for outgoing faxes.
• Choose whether to scan the entire document before dialing the number.
• Choose whether to use error correction.
• Select when to print a fax usage report.
• Select when to print a fax activity report.
this information is from the manual found here
http://support.dell.com/support/edocs/systems/PRN964/en/om/om_en.pdf
I hope this helps
Mar 12, 2009 | Dell Photo 964 All-In-One InkJet Printer
Heard lexmark makes Dell printers. If so,could you tell me the equivalent Lexmark to the Dell all=in=one 964?
Dell's Photo All-In-One Printer 964 uses internals similar to the Lexmark P4350's, with corresponding inks and driver software, but adds an automatic document feeder (ADF) and color fax capabilities.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 08, 2008 | Office Equipment & Supplies
Receiving fax
I have a dell photo AIO printer 924. Please email a solution. Thank you.
Nov 08, 2008 | Dell Photo 964 All-In-One InkJet Printer
Faxing/scanning from AIO 964
throw it in the dumpster and buy a new one
Mar 03, 2008 | Dell Photo 964 All-In-One InkJet Printer
Canon LaserClass 9000L Plain Paper Fax Logo
23 people viewed this question
old marine
old marine
