Question about Mitsubishi WS-55411 55" Rear Projection Television
Mitsubishi WS-55411 55 in. No Power up
Mitsubishi WS-55411 2003, I went to power up and nothing. I have held the input and menu buttons 5 sec. and got a 1-2 code (1 light then 2 short (power light) but I don't know what that is telling me. I have checked the main fuse and the 5 others and no opens,(crap!)I have checked the crt's for coolent leakage on the boards and nothing. Any help would be great. Thanks Joe...
  • Joseph Munguia Jul 04, 2007
    I thank you so much! You were right!
    It sure payed off asking this web site for help, you saved me about 150-200$ having someone troubleshoot that problem.
    Thank you again!
    Joe...
  • rosy3572 Dec 28, 2007
    i have the same set ws 55411 and its very rarely been used.power button wont stay on and it gives the deflection protection code.any ideas??
    Novelist:
  • 192 Answers
Error code 12 means normal operation. On these models we have found that a switch is bad on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on set. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. You can use an ohm meter to find the bad switch.
Posted on Jul 04, 2007
SOURCE:
Mitsubishi Model WS 55511 was made in March of 2003. I turn it on and it goes right back off again. On the front of this TV I only have an Enter button, a menu button. an A/V Reset Button and a Device...
Device is the same as input--try the self check, when power light goes off press and hold it and menu at same time for five seconds and release.
Device means input.
Let me know error code and I will help you more than anyone else.
SD TECH
Sep 18, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi rear projection tv.. 55 inch made in june 2003... will not turn on... no lights blink nothing no sound.. push button nothing happens.... looked in back not knowing what to look for or look at...
IF power light on front comes on for a second or two and goes off do the self check this set has:
On front of set when power light goes off, press and hold both the Input and Menu buttons at the same time for more than 5 seconds and release both buttons.
Power light should blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat the code four more times.
If this information helps and you want to know what error code found means rate this solution as very helpful and comment here and I will tell you what it means.
SD TECH
Aug 22, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS 55807 wont turn on
SECONDARY POWER SUPPLY IS OUT
Dec 05, 2009 | Mitsubishi WS-55807 TV
Blinking green light on mitisubishi ws55813
error code. return to supplier. Possibly power supply
Dec 25, 2008 | Mitsubishi WS-55513 55" Rear Projection...
WS-55511
Press in together the menu button and the Device/input button on the set and hold them both in together for 5 seconds and see if the led will blink a two digit error code, then respond to this same post and let me know if it gave a error code and what the two digits were.
Aug 02, 2008 | Mitsubishi WS-55511 55" Rear Projection...
No picture
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is.
Dec 05, 2007 | Mitsubishi WS-55807 TV
Oval shaped picture problem with Mitsubishi WS55807
Nov 21, 2007 | Mitsubishi WS-55807 TV
HELP
Oct 20, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55411 55" Rear Projection Television Logo
294 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
